Question about Sharp XLDV60H Shelf System
FAN LOCK my sharp radio/cd player keeps saying fan lock when i listen to it louder than 17 volume... help please!
  • Anonymous Mar 30, 2014
    I was listening to the radio when I heard a big pop, the sound was terrible and the volume went to maximum and I had no control of it. Please help with the problem and a fix thanks
    Problem Solver:
  • 18 Answers
Well it seems like you got a big problem, its because if its to high of volume the fan should start, read the instructions if that dont work, take a-part the unit look at the fan then if its not fixable buy a new fan
Posted on Jul 23, 2007
Ford 500 stereo no volume and put in cd and says no cd clock works
sounds like internal problem with stereo....may need to replace ??
Aug 18, 2012 | Ford Cars & Trucks
I turned the volume up the other day and it got stuck, it kept getting louder and louder. I turned it off, but now I can only use the CD player. I can't change the volume on the CD player. I also can't use...
You need to free the stuck switch. As long as it is jammed, it is going to send a signal to the microprocessor. The microprocessor can only handle one command at a time, so while the volume up switch is sending a signal to it, it will do nothing else.
Apr 07, 2011 | Sony CDX-R3300 CD Player
RCA RT2770 fan is making a lot of noise. Started off quiet, but it's been getting louder and louder, now more so than the volume of the movies I watch. Should I clean it? Replace the fan? Junk the...
Do one thing, Remove the fan from the player. In the fan there will be a specification sticker. Remove the sicker. Now you can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. You can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the player. power ON the player and watch. If available then try to replace the same. it will not cost a lot. just watch the following video for oiling the fan. its for a PC fan same for all dc fans.
ok
Apr 01, 2011 | RCA RT2770 Theater System
How to take off the volume lock off a 2gb silver ipod nano
On your iPod go to "Settings" then "Volume Limit," now change it.
Hope this helps!
Jul 05, 2009 | Apple iPod nano
Dell 3000 PC is extremely loud like a vacumn cleaner right next to your ear... and gets louder and louder throughout the day. Have ran disk clean, Registry Mechanic, and Disk Defrag. Lots of room left on...
Check your cpu fan, chassis fan, and the fan on the power supply. If all the fans are working then the bearings in the hard drive is about to go out. That is if you are not using a cd or dvd rom.
Mar 05, 2009 | Dell Dimension 3000 PC Desktop
JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Dec 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
Cd keeps ejecting
use a product called cd kleen it.you can find them on ebay.they take care of problems like this.
Sep 06, 2008 | JVC Arsenal KD-S6250 CD Player
Sharp-XLES50 Help...
If the unit stays on at a low volume and cuts off when volume is raised, then fan motor maybe defective. If it cuts off no matter what volume level it's on then output IC maybe at fault.
Nov 04, 2007 | Sharp XL-ES50 CD Shelf System
Sharp XLDV60H Shelf System Logo
189 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
