Question about E-Machines eMachines Desktop PC
Hdd s.m.a.t. capability disabled
Emachins s2485 says the hdd s.m.a.r.t capability is disabled. how do i fix this the comp. wont start up it goes to the black screen and says that. it wouldnt reboot either. thanks.
    Problem Solver:
  • 9 Answers
You can fix the issue the issue by enabling the SMART feature in system BIOS.
Posted on Jan 05, 2009
  • 827 Answers
HDD S.M.A.R.T needs to be enabled in the BIOS, so just tap your Delete button or F8 through to F12, on bootup, to enter your Bios and enable it, Save and Exit.
Hope this helps
Chris (ziraffa)
D525 hdd password forgotten---frozen
The hdd password is stored in the firmware of the hdd, not in the bios. There is only two options available.
1/ type the password.
2/ purchase a new hdd as it is totally unformattable in that condition.
Jul 22, 2014 | Acer eMachines 520-2890 Notebook
Pxe-mof exiting pxe rom
If you are not booting from a network, PXE-boot is the wrong boot option.
You have to change the boot order so that the PC will boot from your HDD. This can be set in the boot option in your BIOS.
Depending on the type of BIOS, you will enter F2 or Delete during the POST( when the white letters appear on the screen after you turned it on). This will enter you into the BIOS setup. boot options are usaully the last tab. Either disable the PXE-boot or change the priority so that it boots from the HDD first. Please, if you are unformiliar with this, reference the manual or ask someone with some IT background.
If the problem still exists after you configured the boot options your hard disk drive might not be readable. The BIOS just goes to the next availible boot device.
Apr 24, 2012 | eMachines T5048 PC Desktop
I have just aquired a emachines computer and im wanting to connect it to a wireless router but its not allowing me to do this.
If you are using an eepc with a linux operating system you will need a wireless driver, go to the eepc support on another computer and download driver, alternatively get a copy of puppy linux, load onto usb and run directly from usb, it may have the driver inbuilt into puppy, a third prob is having to turn the wireless key on but as its a desk comp this wont happen, does the computer have wireless capability.
Feb 13, 2011 | E-Machines eMachines Desktop PC
I deleted too much stuff off my 1g emachine desktop and now it wont even start windows says its missing the boot manager. how can i fix it without a backup disk
Hi ,
Unfortunaly , you can't . You need the install disc . You can retreive existing data by extracting the hdd from your desktop and connect it to a healthy computer . Format the HDD afterwards , put it back into the desktop and launch install disc .
Jan 22, 2011 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
Having a problem with my gateway comp. using
  1. Boot to your XP CD, enter Recovery Console and run the command CHKDSK /R and see if that resolves
  2. Run diagnostics on the HDD, it may be failing, replace HDD if diags fail
  3. In-Place (Repair) reinstall of WIndows http://windows.microsoft.com/en-us/windows/help/install-reinstall-uninstall
Jan 25, 2010 | Microsoft Windows XP Media Center Edition...
I have a emachines s2485. Couldn't turn on one day so I replaced the power supply. Yhe power now comes on with the fans and light on the mother board but I see no activity on the hard drive light. Is it...
Try refreshing all the connections on the motherboard first like ATX power supply, SATA cables, RAM, etc. Then turn the computer on again, touch the HDD and feel if there's vibration, this means that your hard drive is active. Also, try resetting the CMOS, by removing the battery, but before doing this, make sure to turn off the PC and remove the power cable connected to the power supply. After approx. 10 secs attach the battery again, and turn on the computer, you may need to input the correct time and date. Hope this helps.
Sep 26, 2009 | E-Machines eMachines Desktop PC
Comp not reading montor
It sounds like the on board video has failed. I would try installing a video card on the motherboard. Then in the bios at start up, disable the on board video, so it will use the video card instead.
I hope this helps and thanks for using FixYa,
Eric
Jan 25, 2009 | eMachines T6534 PC Desktop
Emachine wont start, just beeps
This is probably a problem with your DIMM(RAM) Did u recently install an extra RAM?If yes then remove it because the beep sound is due to the mismatch of frequency of two DIMM's. If not open your computer and check if the DIMM is loose just push it in and powerup your comp..Let me know if its fixed..
Oct 08, 2007 | E-Machines eMachines Desktop PC
Hard Disk and Booting issue
go into your BIOS and on the bottom of your screen there should be a (last good config) of (fail-safe config) value for one or=f the F1 to F12 buttons. also. are you running a 4gb hdd??? or is that a typo? anyhow, XP REQUIRES 2GB at all times free if your hdd is running at less that that (cause its full) your boot up could be messed around. finally make sure that the little plug on your hdd is across the Master or cable select pins not the slave as this can cause probs too. good luck.
Sep 22, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
E-Machines eMachines Desktop PC Logo
261 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
