Question about Air Tools & Compressors
I need the manual for my husky ta1512 3 gallon compressor
Manual for husky 3 gallon compressor
RCtech
  • 55 Answers
SOURCE: manual for husky air compressor ''easy to go''
For what it's worth Compressors are intended to be turned on and forgot (except for the noise). just for grins lets assume you have the stapler and air hose. you need to hook up the air hose to the compressor there usually is one or to either couplers or npt fittings (threaded). attach the hose to the compressor and using a quick coupler (prefered because it allows the gun to swivel) connect the gun to the hose. turn on the compressor and wait for it to build up pressure and *******. at this point you will need to locate the regulator on the compressor. it will be a knob next to one or two dial gages. crank the regulator a quarter turn either direction while watching the gages. It (one of them) moved either up or down . now you know how the regulator works and your almost a contractor. on to the stapler, load it and find a bit of scrap (what your working on would be best.) now shoot a staple into something and see if it goes in far enough or to far. adjust the regulator to compensate. do this until one of three things happens A you find the right staple depth B the compressor kicks on again, wait for it to turn off C you run out of nails, beer or intrest in the project. once you have found the correct pressure for your needs. you may fire at will you don't need to wait for the compressor to cycle while running the stapler just during set up. now your a contractor go have a beer.
just a last tip if you find you don't have the correct couplers home depot, harbor freight or amazon (online) are great sources for parts.
good luck and mind your fingers
Rob
Posted on Dec 10, 2008
  • 1388 Answers
SOURCE: Makita MAC 5200 3 HP 5.2 Gallon electric compressor
Use non detergent air compressor oil. It can be found at Lowes, Homedepot, and even Walmart. It is sold in small containers for about $2-3 dollars. A synthetic blend air compressor oil is needed when the unit is used in severe conditions. Synthetic air compressor oil sold at Lowes $6.95 and other stores will take more heat. Second choice is 30w non-detergent motor oil. Engine oils tend to produce carbon on the reed valves in the head if used extensively. I have been using the Lowes Kobalt brand of air compressor oil for some years in my Makita and Rol Air compressors with good results. The part number for Makita brand of oil is 18112-A quart size. It is only available by special order where I live. Good Luck!
Posted on Feb 23, 2009
  • 47 Answers
SOURCE: Husky 1.5 HP 6 gallon compressor motor runs but
Your manual pressure release valve might be stuck open or blocked open by some debree. It should have a steel pull ring on the end of it. Exercise it and try running it again. Also the pressure regulator adjustment might have been backed off to zero. Crank it clockwise and see if this helps. Check the air output lines from the compressor to the tank for leaks.
Posted on Jun 22, 2009
  • 8404 Answers
SOURCE: belt broke on my husky,air compressor,22 gallon
Any good auto parts store can help you ...
Posted on Oct 08, 2009
digritz
  • 530 Answers
SOURCE: Need Manual for Husky Model 41214 Air Compressor
I can give you all the relevant data and specifications. I hope that is enough for you. Otherwise your going to have to go to Home Depot and try to get them to get or perhaps if you bought it from them copy one they have.
As for the Husky Tools web site it now redirects you to Home Depot.
Description:
1.5 Gallon Low Profile air Compressor. 1 Running HP, 135 Max PSI, Oil Free. Portable Lightweight Design with onboard storage. 2.0 SCFM at 90 PSI, 3.0 SCFM at 40 PSI.Ideal for Inflation, Cleaning and Fastening. 13 piece accessory kit included.
  • 1 Running HP, 135 MAX PSI , Oil Free
  • 2.0 SCFM at 90 PSI , 3.0 SCFM at 40 PSI
  • Portable Lightweight Design with onboard storage
  • Ideal for Inflation, Cleaning and Fastening
  • MFG Brand Name : Husky
  • MFG Model # : 41214
  • MFG Part # : 41214
Specs:
  • Amperage : 8 A
  • Assembled Depth (In Inches) : 16 in
  • Assembled Height (In Inches) : 17.5 in
  • Assembled Weight (In LBS) : 32.5 lb
  • Assembled Width (In Inches) : 14.5 in
  • Energy Star Compliant : No
  • Fuel Type : Electric
  • Height : 19.5 in
  • Horsepower : 1 hp
  • Maximum Pressure : 135 psi
  • Tank Capacity : 1.5 gal (US)
  • Voltage Rating : 120 V.
  • Width : 16.5 in
I have a large source to search for items like manuals and so far I have found only one Husky compressor manual. However I will keep looking. If I find it I will let you know. In the mean time if there is something you need to know more specific about you compressor please just ask and I'll get you an answer ASAP.
Hope this helps and Happy Holidays to you and yours.
Posted on Dec 21, 2009
Testimonial: "Thank you so much for responding. I am sure your information will do the trick. Thanks again the Happy Holidays!!!"
I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
Free Husky Air Compressor User Manuals ' ManualsOnline ...
powertool.manualsonline.com > ... > Husky > Power Tools Husky
Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
Sep 04, 2015 | Air Tools & Compressors
How to adjust cut in pressure on husky 60 gallon
what is the pressure switch model number, most of them have a nut with a spring under them, just turn the nut to adjust the pressure
Oct 21, 2012 | Husky Electric Air Compressor: 60-Gallon...
Husky 60 gallon compressor switch from 220 to 110
Try here, very good for asking problems http://www.about-air-compressors.com/husky-air-compressors.html
Jul 28, 2012 | Air Tools & Compressors
CAN YOU STAND THE Husky WL651004AJ UPRIGHT?
Your compressor will work in the vertical position however you will not be able to properly drain the water from the tank in this position.
Feb 18, 2012 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky Manual for TF291201AJ
Go to http://www.chpower.com/manualsearch/ (its the Campbell-Hausfeld website) and put TF2912 in the 'Find Model' search box and you'll get the operating instructions, parts lists and other information on your compressor.
Oct 16, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
My 1.7 26 gallon husky upright will not come on at all
Did you trip the reset button? It should be there someplace i a spot where you can't see it, just push it till it clicks, make sure the switch is on. Hope this helps.
Jul 04, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky 25 gallon air compressor turns on and off Y6020-WK
Pressure switch setting is off. Readjust to Mfg. spec. (on @ 60/off @ 8o...)
Sep 03, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
60 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
