Question about Sony STR-DE475 Receiver
Optical in connector diagram
Need to see visual of optical in connector
    Scholar:
  • 73 Answers
This
http://en.wikipedia.org/wiki/File:TOSLINK.jpg
Plugs into this
http://www.m-audio.com/images/en/callouts/big/transit.jpg
Posted on Jan 05, 2009
I need a diagram showing how to replace the ignition control module on a 94 Ford Taurus 3.8 engine
There really isn't a step-by-step set of instructions with visual aid. It is simple to do a swap out. The module is located on the driver's side firewall under the rubber/plastic cover where all the wiring feeds into.. Two fasteners to remove the module with connector attatched and one more in the middle holding the connector to the module.
May 27, 2015 | 1994 Ford Taurus
It will not turn on e1 code
see the diagram attached, and follow the steps, clean it the speed sensor and tight the connector very well and clean it. \God bless you
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Dec 09, 2013 | Exercise & Fitness
BH treadmill error E 1 Whats the fix?
ERR 01 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
Test the speed sensor. clean it, and tight the connector very well.see the diagram attached.
God bless you
Apr 04, 2013 | Bh Fitness T8 Pro Treadmill Fitness...
E1 code on treadmill
Test it for open or faulty+ clean it, and tight vbery well the connector, see the diagram adjust it
Try to run the software calibration for troubleshooting and diagnostic too.
God bless you
Mar 22, 2013 | Triumph Academy Sports 400T Treadmill
E1 error. After 15 mins on tredmill
ERR 1 - Motor Movement
see the diagram. test for open or faulty. clean it and tight the connector very well
God bless you
Jan 21, 2013 | Exercise & Fitness
York aspire treadmill starts for a second then stops with ER1 fault
test the s. sensor for open or faulty, clean it, and tight the connector very well. see the diagram attached.
Test the input voltage motor, if there are the motor need repair
God bless you1_22_2013_6_08_24_pm.gif1_22_2013_6_08_38_pm.gif1_22_2013_6_08_58_pm.jpg
Error 1 MSG ..
See the diagram attached and adjust it, clean it, and test for open or faulty, and tight very well the connector.
God bless you
Jan 11, 2013 | Exercise & Fitness
No sound on my macbook
Check if there is any sound coming out of the headphone (using headphone and playing itunes).
If there is none. Goto System Preference > Hardware > Sound > Output ; check if the output is assign to internal speaker and it is not muted.
Do a visual check at the headphone connector, look into it, see if you see a red light emit from the headphone jack (indicate that the fault is in the headphone connector, it's trying to output optical spdif).
Nov 28, 2012 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Dvi port specification
The DVI [Digital Visual Interface] is a standard for high-speed, high-resolution digital displays.
Below is a 24 Pin DVI Female connector seen at the Computer. The connector diagram and pin-out table show a DVI-I Digital and Analog [RGB]; 29 pins [modified D style] connector. A DVI-D Digital only connector with 24 pins [modified D style] looks about the same with out the 4 analog 'C' pins.
The DVI interface is found on a number of devices including TVs, Computers, Monitors, and Video cards.
Digital Visual Interface [DVI] was developed by the Digital Display Working Group (DDWG).
Note that the Digital Display Working Group disbanded around 2006, so don't expect an up-grade for DVI.
Digital Video Broadcasting/Digital Audio-Visual Council (DVB/DAVIC),
developed by DAVIC [inactive] and DVB [dvb.org].
Adopted by European Telecommunication Standards Institute (ETSI) and
International Telecommunication Union (ITU)
DVI has a number of different types connectors:
DVI-D Digital only connector; 24 pins [modified D style];
DVI-A Analog only; [modified D style], I don't think this is part of the standard
DFP Digital Flat Panel, Digital only connector. Pinout is listed on the DFP page
Styles of DVI Connectors
Jan 13, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Sony STR-DE475 Receiver Logo
81 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
