Question about E-Machines eMachines Desktop PC
Adding ram, but computer freaks out.
OK, I have an E machines desktop.
3.2 GHz Intel celeron D
512 cache
533FSB
whatever all that is..
It came with 512 Ram DDR2
I'ts supposed to be able to have up to 2 gig of ram.
I bought two 1 gig sticks.
Put em both in, and the computer fan kicks on high, and never slows down, and the monitor acts as iff its not connected to the PC.
Take one stick out and put the old 512 in, and it all works fine, the comp says it detected new RAM and the system stats show 1.5 gig RAM.
I tried installing the other stick again, and had the same problem.
I then reinstalled the old 512, and replaced the 1gig stick that was working fine with the other 1 gig stick.
It all works fine.
But it will not work with both 1 gig sticks.
Whats up with that?
Am I just not holding my mouth right or what?
  • 5 more comments
  • Danny Clark
    Danny Clark Jan 05, 2009
    The two 1 gig sticks are the same brand as each other, (purchased in a package from tiger direct new.)
    But not he same brand as the old 512.
    A jumper? Ok, where and how do I find it? what is the correct way to remove/disconnect it?
    Please understand you are talking to someone who knows very little about computers. To me, a jumper is something that I use on an airconditioning system.
  • Danny Clark
    Thanks, I'll look into this, and don't worry, I will rate your solution after I get a chance to try it. Probably tomorow.
  • Danny Clark
    OK, I see one three pin with a plastic removable tab.
    It is labled biosconfig.
    1 2 normal
    2 3 config
    no jump/rcvry
  • Danny Clark
    OK, so what do I do with the jumper?
    I'm not sure which one is 1, 2, or 3.
    I ASSUME its currently on 1 and 2 but hate to go on assumptions.
    What should I do with it, and should I leave it in the new position permanently or what?
  • Danny Clark
    Danny Clark Jan 06, 2009
    You folks ROCK!!
    That worked and now I am up and running. Thank you.
    I rated you all FIXYA, but for diffferent reasons. I will explain to each of you why.
    Now, as a fellow FIXYA expert and also an asker, I appreciate feedback on my solutions and only feel it fair to provide the same.
    I will tell you each what I liked about your posts, and constructive criticism that will hopefully result in more fixya's for you in the future. The constructive critisism comming from an asker who is completely comuter illitiarat and indeed quite helpless it seems when it comes to computer stuff. (Much like most all askers are LOL)
    So.... coming from a computerly challenged asker.......
    @FWADLEY
    You responded quickly and followed up VERY well. Also, your answers turned out to be correct and solved the problem.
    The only areas of improvement I could see are as follows.
    Your answers were to short.
    Computer techies probably would have gotten it right away, but me, being clueless, I didn't have the foggiest idea if your solution was accurate before trying it, and was quite aprehensive to follow it at first. More details, and expliation would have helped TREMENDOUSLY! The answers seemed almost .... amature due to lack of detail. Thats bad considering the info was actually right on the money.
    @Rachelgeek23
    Your answer helped very much. It backed up Fwadleys posts and gave me more confidence in that actually being the solution. You explained and described the items to look for, in detail. That REALLY helped considering I didnt have a clue. Your post made you sound proffesional, and experienced.
    There is only one thing I see that you could have done that would have really made a big difference. It would have made your post a slam dunk candidate for FIXYA!!
    That is "Follow up"!!!!
    Without the input from others I doubt I would have been able to rate any of these as FIXYA, considering my level of computer proficiency. Had you followed up, yours would have stood alone.
    @Mike258
    You reffered me to another expert that could help me. Thats good, I appreciate it. You also refferenced an actuall thread of solutions that I could research to help with my problem.
    The only reason I hesitated to give it a FIXYA rating is because there was no link and it almost seemed more like a "comment" than a "solution". Personally, I fear that askers who are new to Fixya and not familiar with the way it works would have rated it lower.
    Over all, all the comments together led to a great FIXYA rating.
    Thanks to all three of you!
  • brunotak Feb 07, 2009
    I have an Emachines T3882 and have a similar problem. I upgraded from 256mb to 2gb and it all worked fine for about 2 months. Then I had a problem with windows and had to format and reinstall. Now my 2 identical 1gb sticks wont work together, I get the blue error screen. i tired this solution, but it doesn't work. I only found one jumper and moved it to a new position, which takes me to the Bios setupp page, so then what? HELP!!!
  • Rachelle Aviles
    Rachelle Aviles May 11, 2010
    Are the 1g memory sticks of the same brand?
  • 1,498 Answers
Hi meB,
You should ask Hokuwho. He and I had an informative discussion in the lounge involving eMachines just before the Holidaze. I tried to find it so I could put the hyperlink here, but no joy.
The good news:
He supplied many e-references. He probably could rattle them right off for you.
The bad news:
Most of the references were eOwners who were real ePissed at eM. So much so that they were organizing a class action eSuit.
Really, Steve is a good bet on this one
Mike
Posted on Jan 05, 2009
  • Justin Case
    Justin Case Jan 06, 2009
    I liked your procedure for Laptop Password removal. You cracked me up.
    Thanks for the rating.
    Mike
  • Justin Case
    Justin Case Jan 14, 2009
    Being inundated with lounge posts. I missed your critiques until now.
    Explaining the reasoning of rating, supplying a positive feedback, What an excellent concept.
    Allow me to defend myself. lol
    At the time I answered, the three of us were conversing in the lounge. I figured you'd contact him there. Anyone else and a link would certainly have been included.
    So you see, I deliberately treated you worse than I normally would anyone else. Feel better?
    Seriously, excellent effort, example of what should be a common practice.
    Mike
    Scholar:
  • 155 Answers
Try to update your bios. It's possible that the motherboard cant handle 2GB or reseating the jumpers may do the trick. Look for a set of 3 pins sticking out of the motherboard with a plastic wrapped around 2 of the pins. The pins are about 3mm long. There should be a label near the pin. You may find 2 sets of 3 pins. Just post back the labels you found for both.
    Master:
    Sergeant:
  • 482 Answers
There is a jummper on the mother board you need to take off.
  • 3 more comments
  • farren wadley
    farren wadley Jan 05, 2009
    the jumpers are on the motherboard, small black, turn computer off, put the new ram in, you will need to remove 1 jumper at a time then try to turn on computer, if does not work replace jumper and keep doing this till you find the right one.
  • farren wadley
    OK, Thanks. they are small black caps that cover pins
  • farren wadley
    thats them
  • farren wadley
    new position, yes
    you wont hert the computer
    try them all, move them around till you find the right one, you will need to take one off
  • farren wadley
    farren wadley Jan 07, 2009
    Thanks,
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
I need the processor
Hi.
The emachines t2958 has a celeron D processor 2.66ghz with a 256KB L2 cache and 533 FSB.
The fastest processor that you can go with is a pentium4 3.06 ghz, with a 1 MB L2 cache amd 533 FSB.
Not a huge improvement, but an improvement none the less.
I would go with uphrading the memory, it comes with 1 stick of 512 mb pc2100 ram, there is a second slot available, bumping you up to 1 gig of ram.
That will actually give you a better performance boost that the processor upgrade, and is probably cheaper as well.
I hope this clears things up for you.
Feb 09, 2011 | E-Machines (T2958) PC Desktop
I have a mainboard of model D845GVAD2------------------------AAC18931-104. It has already intall the Intel celeron processor of 1.8GHz. Now I want to upgrade my processor. So what high frequency processor...
The Intel® Desktop Board D845GVAD2 supports a single Pentium® 4 processor with a system bus frequency of 400 MHz or 533 MHz, or a single Celeron® processor with a system bus frequency of 400 MHz.
So you can install upto 3.06 GHz 533 MHz(cache memory) processor and also update the ram 2 GB 400 mhz.
Dont install Prescott processor.
Hope it will help you.
Dec 31, 2010 | Intel Desktop Board D845GVAD2 Motherboard
Je veux savoir les caracteristiques de mon pc
Merci pour votre demande.
Voila les details demander
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} desktop
i
OLIVETTI OLIVETTI
OLIVETTI DESKTOP AD200N-1245 OLIVETTI DESKTOP AD200N-1245
Processeur Intel® Pentium® Dual Core E2180 (2x 2.00 GHz, 1 Mo L2 cache), Chipset VIA® PM900, Mémoire DDR2 1024 Mo, Disque Dur SATA 160 Go Intel ® Pentium ® Dual Core E2180 (2x 2.00 GHz, 1 MB L2 cache) Chipset VIA ® PM900, DDR2 1024MB, HDD 160GB SATA
Prix public : 6100DHS Retail price: 6100DHS
OLIVETTI DESKTOP AD200N-1210 OLIVETTI DESKTOP AD200N-1210 Processeur Intel® Celeron® 420 (Core 1.60 GHz, 512 Ko L2 cache), Chipset VIA® PM900, Mémoire DDR2 512 Mo, Disque Dur ATA 80 Go Intel ® Celeron ® 420 (Core 1.60 GHz, 512 KB L2 cache) Chipset VIA ® PM900, DDR2 512MB, HDD 80GB ATA
Oct 19, 2009 | Computers & Internet
851 MHz Celeron Processor
*********** board will support a max of 1GB of RAM. Your processor is an Intel at 1.8 GHz. The preceding is only true if your PC is the Emachines T1840 as you chose in the category listing of your post. Again if that is true, you can achieve the max RAM by installing a 512MB stick in each of the two memory slots.
Good luck.
PS: Gdlkn84as528 is correct in assuming that a less than 1.3GHz Intel processor would be a P3 or equivalent processor. So which is it, it can't be both ways?
Sep 18, 2009 | E-Machines -T1840-CELERON-1.8GHz,40GB...
I have 256 MB RAM which is slow, can i upgrade it to 512 MB RAM
Depends completely on what motherboard the computer has and what it supports, I could check on it if you have and brand and model of the computer, or from the motherboard.
Sure the prosessor speed doesn't affect the memory amount possible don't worry about that, just need to find out how much is supported and at what speed etc.
Thanks,
Ekse
Jun 03, 2009 | E-Machines -T1840-CELERON-1.8GHz,40GB...
I have a sahara laptop system model 661MX, with 512 MB Ram,Processor Intel(R) Celeron(R) 1.40 GHz, Now could i integrate 2GB of Ram In This ?
yea but when u gone to shop for this there after setup 2 gb of ram u checked ur lappy.but its working too better
May 07, 2009 | Dell Dimension 8300 PC Desktop
Dell optiplex p4 1.8ghz: RAM
Best and easiest thing to do is go to www.crucial.com and run a scan of your computer. It will tell you what you have, how much it will hold, and what kind of modules.
Yes, it's safe.
Thanks for using Fixya!
If you have any trouble, comment back.
Jan 28, 2009 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
How much RAM can it hold and how much you do recommend?
its all about the motherboardthose mother board usualy suport fro 512 to 1024 MAX
Jan 01, 2009 | Intel (C733) Celeron A, 700 MHz Processor
Upgrade processor problem
http://support.intel.com/support/motherboards/desktop/D875PBZ/sb/CS-021825.htm
This website is the details of your motherboard from intel site you can have look in to that the processor 3.2 ghz is supported but L2 cache must be 512 kb only(you are trying with 1mb one it is not supported) your processor doesnt suits the motherboard specification as i have told it previously ..
here are list & details of supported processors below:
intel® Pentium® 4
3.40 GHz 800 MHz 512 KB P20 or greater All board revisions support these processors. 3.20 GHz 800 MHz 512 KB P06 or greater 3 GHz 800 MHz 512 KB P05 or greater 3.06 GHz 533 MHz 512 KB P02 or greater 2.80C GHz 800 MHz 512 KB P05 or greater 2.80 GHz 533 MHz 512 KB P02 or greater 2.66 GHz 533 MHz 512 KB P02 or greater 2.60C GHz 800 MHz 512 KB P05 or greater 2.53 GHz 533 MHz 512 KB P02 or greater 2.40C GHz 800 MHz 512 KB P05 or greater 2.40B GHz 533 MHz 512 KB P02 or greater 2.26 GHz 533 MHz 512 KB P02 or greater
so just try changing this processor to 512 kb L2 cache processor ..........
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 05, 2008 | Intel P4 3.0 800 MHZ Retail BOX
E-Machines eMachines Desktop PC Logo
113 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
