Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
My coffee machine says "ventilate"
It says "ventilate" and there's no steam.
  • 1 more comment
  • kidtami Jan 15, 2009
    yes i have the same problem what can we do
  • clast Apr 20, 2009
    It says ventilate, but in doing so...there is no steam. I'm thinking it could be plugged, but I'm not sure how to remove cover.
  • alihourani40
    alihourani40 Nov 19, 2012
    The machine will not work. The screen say The machine will not work. The screen say Ventilate and decalcify will nothing will work. How do I get the word Ventilate off. F
    Problem Solver:
  • 6 Answers
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Posted on Jan 24, 2009
    New Friend:
  • 3 Answers
You may want to try:
http://www.fixya.com/support/t2675737-ventilate_shows_nothing_works
Posted on Dec 10, 2012
    New Friend:
Posted on Nov 19, 2012
3 Suggested Answers
  • 1089 Answers
SOURCE: how to ventilate a saeco cafe royalecoffee machine
Hi
There is a water button you need to push. It has a water drop on it. This will clear the ventilate message.
Posted on Jan 22, 2010
  • 1089 Answers
SOURCE: ventilate message
Hi
Push the water button (the one with the drops) and that will clear the message. The pump slows to much and the flow meter doesn't spin fast enough, the computer thinks the pump is bad. If your coffee is taking too long to brew, then you grind is too fine. Move the lever to a larger #.
Posted on Jul 06, 2010
Testimonial: "Thx, but my Royal exclusive is an older model and I have no water button on it. Any other idea ?"
Ventilate problem on gaggia titanium coffee
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 27, 2010 | Gaggia Titanium Espresso Machine
Machine wont make coffeee, m,essage says ventilate...
May 20, 2010 | Saeco Stratos Coffee Maker, Espresso...
How do I ventilate my gaggia coffee machine
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 15, 2010 | Gaggia Syncrony Compact Coffee...
Keep getting ventilate message - won't ventilate and cannot operate steam or grinder w/ ventilate message
Try this run the hot water cycle for a few seconds, it that works, try steaming if you get the message again clear it by running the hot water cycle and then go to steaming, this time push in on the knob after you open it, it that works, then the tap rod or the valve assembly needs to be replaced.
May 01, 2010 | Gaggia Titanium Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Ventilate shows.
try prime water on steam valve couple minuts if you have again message ventilate,that can be two reason,or your flow metar doesnt work or cpu board,but you try first prime water.
Aug 28, 2009 | Saeco Royal Professional Espresso Machine
Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Ventilate warning came on and machine no longer works.
Hi The first thing that I would check is the tip of the steam wand for a plug. If that is clear then I would suspect a clogged flow meter. If you can get the flow meter out it twists apart and don't loose the parts and the dot on the turbine goes up. Clean out the small opening on the bottom pipes where the hoses attach. Look inside and make sure that they are clear before reassembling.
Mar 22, 2009 | Gaggia Syncrony Compact Coffee...
Does not come off ventilate mode. Re: S-Class incanto sirius mode
Try this push in steam knob when it calls for ventilate, especially if you are steaming or drawing hot water, if that works the the steam valve or the tap rod needs to be replaced.
Dec 28, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
VENTILATE ERROR
Make sure the steam pipe is clean, try to take off the steam pipe and open the steam knob to see if any water is comming out.
How old is the machine?
How often do you descale the machine?
Can you hear the pump start when you open the steam knob?
Jul 22, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
1,219 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
