Flickering red spots
I have 50 inch Samsung Plazma TV and I have flickering red spots on the lower to center portion of the screen when the background is black or dark.
    Sergeant:
    Scholar:
  • 199 Answers
Its due to overheating of any component on the main board and needs to checked with a meter to locate the faulty and replace.
Posted on Jan 05, 2009
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Lg55lv4400-va 55" flatscreen tv ( not a plazma) has developed a wide flickering vertical flickering stripe down the screen. Has been fine . Goes away once in a while. An Ideas what is wrong ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Televison & Video
I HAVE A PHILIPS 50' plazma and the screen keeps freezing,flickering as it has some kind of interference but we have had an areial engineer to check the signal strengh and said its excellent.what else can...
If it is digital TV, change antenna(UHFonly), and change position of the antenna to get less inteference of digital signal. Signal strength is the TV station carrier frequency, does not help digital video signal integrity. Often if you change channels will reset the digital signal cache and get better pictures.
Mar 24, 2011 | Philips 50PFP5332D 50 in. Plasma...
Asus x83v monitor has a red flickering bar across the lower part of the lcd it is as thick as the task bar thats why i have to place the task bar on the top, its like a static flickering red to pink and...
The display hardware is damaged. Most likely you will need to replace your screen. In rare instances, this can be caused by a loose ribbon connector from the display to the display adapter board.
Mar 29, 2010 | ASUS X83Vm-X1 Notebook
SyncMaster 213T Screen quality
did you try change the VGA cable? if not, try it.
Dec 19, 2009 | Samsung SyncMaster 213 T 21.3" LCD Monitor
DLP TV keeps flickering
Please recheck component connections in both units and make sure to hook up them according to corresponding colors like blue to blue, red to red and orange to orange.
Dec 13, 2008 | Samsung HLN5065W 50" Rear Projection...
Screen problem
call samsung...had the same problem with my HP-R5072...and they cant seem to fix it !!!! ... If your lucky you should get a replacement TV within 2 to 4 weeks ... :(
Dec 24, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
TV Flickers red lines across tv screen
Sounds like you have an intermitant overdrive situation on the red CRT. This could be caused by a bad component on the Red CRT board, an intermittantly shorting CRT or the circuitry in the main board. You should not run it until the problem is resolved as you could damage the CRT if it is not already bad. This is something that unless you are a qualified tech you are not going to have any success resolving. It should not be very hard for a good tech to diagnose the problem. Costs will depend on the part which is bad. If it is the red CRT it probably is not worth fixing, but it could be a 50 cent capacitor. Certainly worth the cost of a service call. Good luck.
Jun 29, 2006 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
442 people viewed this question
Top Televison & Video Experts
