Question about Olympus FE-290 Digital Camera
Olympus FE-290 mode settings--only some are correct--"P" no good
When setting the mode dial, some positions do not result in the proper settings. For instance, "movie" comes up twice, And "P" usually results in a shutdown.
Internally, there is a white multi-conductor strip which connects the mode selector to the circuit board.
At one (minute) location on that connector strip, the insulation corresponding to one of the individual conductors has been penetrated. Still, the "shadow" of the conductor can be seen (when back-lit) to be continuous past that point, and so appears to be intact. This could be an illusion.
I would like to have been able to try replacing this part, but don't know how to get one.
Now, when everything is together, that connector strip is pressed pretty tightly between the back and the circuit board...and at just the location that corresponds to the minute damage, there is a small, metallic, and sharply-cornered component or connection protruding from the circuit board sufficiently to have crimped the strip, and it is conceivable that that penetrated the insulation. The damage also could have been done with a tool the assembling technician used to install the strip.
But maybe all those things are just a misleading coincidence.
Any advice?
I did try placing a couple of layers of (scotch) tape on both sides of the strip at the critical location in hope of protecting it and to ensure insulation. That did not seem to help, and the conductor may be broken after all.
Before even looking so far as to find the connector issue, I started by examining the back of the thumb-wheel (mode dial) itself, and it appears to be perfect.
    Problem Solver:
  • 6 Answers
FixYa sent me an email asking whether the problem was solved, and if so, how I did it....Here is my response to that query...
The problem is solved....I decided not to wait for an answer (that I didn't expect would come---the issue was a bit "involved") and placed the item up for auction on ebay with a clear description of the camera's deficiencies. Bidding has already commenced as I write this. Someone ELSE may be contacting you soon about this, though!
Posted on Jan 07, 2009
Need correct day and time on Olympus FE 170 digital camera
How do I set the date and time on the FE-170?
To access the clock controls, turn the mode dial to any shooting mode except [GUIDE] and then press the [MENU] button. Next, press the Right arrow on the arrow pad to select the [Setup] icon. Using the Up or Down arrow, navigate to the menu item depicting a clock. Press the [OK] button to access the clock settings feature.
Set the year, month, day, hour, minutes and date format using the following procedure: Use the Up and Down arrows to select values, and press the Right arrow to advance to the next item. (The FE-170 uses a 24-hour clock.) When all information has been entered, press the [OK] button to set the values. Press [MENU] twice to exit the menu.
To set the time precisely, with the cursor on either "minutes" or "date format," press the [OK] button as the time signal strikes 0 seconds.
The date and time settings will be returned to the factory defaults if the camera is left without batteries for approximately three days. Custom settings may be canceled more quickly if the batteries were only loaded into the camera for a short time before being removed. Before taking important shots, check that the date and time are correct.
Oct 22, 2012 | Olympus Fe-170 6.0 Mp 3x Optical Zoom...
Need to correct the date displayed
Set the mode dial to something other than GUIDE. Press MENU. Use the cursor keys to select SETUP (wrench-and-hammer icon) and press OK/FUNC. Select the clock icon.
For full details see the "SETUP Menus" and the "Set the date and time" sections of the manual (page 26 and page 6 in my copy). If you need a manual, you can download one from the manufacturer's web site at
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1351
Aug 06, 2011 | Olympus FE-310 Digital Camera
MY OLYMPUS DIGITAL CAMERA FE-230 IS OUT OF FOCUS? PICTURES TAKEN ARE ALL BLURRED.
Try one of these tips:
>Hold your camera steady using both hands
>Hold your breath just before you take a hand-held shot
>Use a tripod, or a set your camera on a steady surface
>Set your camera's self-timer
Set the dial mode to auto ;
Turn off macro mode;
Turn on the camera's flash.
At the link below you will be able to download the instruction manual for Olympus FE-230 Digital Camera:
Click HERE
Jul 26, 2011 | Olympus Cameras
I have an olympus FE-290, and my sister borrowed it for a trip but when she brought it back the camera was messed up. it turns on but the screen is black except for information about the number of pictures...
I would try looking in the settings to see if the view finder option is enabled or disabled. I would also ask your sister if she change any of the settings.
Mar 28, 2011 | Olympus FE-290 Digital Camera
Olympus FE-290 camera...when i cut it on, the lens goes in and out twice then beeps 3 times and cuts off. It was dropped...
If your camera comes with a warranty, you have to use it. If not go to the nearest Olympus service center. Trying to fix the camera after an accident may cause even more problems.
May 07, 2010 | Olympus FE-290 Digital Camera
I have changed the settings somehow on my camera and don't know how to get it back to it's original setting, the quality of my photo's seem quite ***** like and very bright.. anyone know how to change it...
Press the MENU button to bring up the Record mode Menu. You can use this shortcut menu to quickly change image resolution, reset all settings to factor defaults, enter Panorama mode, enable Picture+Sounds, enable Silent mode, change the scene mode (when set to the SCN position on the mode dial) as well as enter the Setup menu.
Hope this helps.
Jan 12, 2010 | Olympus FE-230 Digital Camera
Idiot dropped my Olympus FE-220. Lens broke!
take it to a repairman .... he will be able to fix ....
Dec 07, 2008 | Olympus FE-220 Digital Camera
My Olympus FE-170 turns off
keep the camera in the auto on the mode dial
Dec 06, 2008 | Olympus FE-170 Digital Camera
Olympus FE-290 Digital Camera Logo
101 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
