Question about GE Spectra JBP78 Electric Kitchen Range
Power light staying on
I recently had an element blow on my Inglis range. Now as long as the range is plugged in the power indicator light for that element remains lit. The element seems to be working fine. I have power when the switch is on and it doesn't get hot when the switch is off. Do I need to replace the switch as the light is powered by a terminal off of the switch?
  • 115 Answers
Yes the switch does need to be replaced the contact has welded together please rate me
Posted on Jan 05, 2009
Element light stays on after all power control knobs are in off position?
Good Afternoon Cindy,
I see that you are having trouble with the element light staying on after all power control knobs have been put into the off position on your Frigidaire range, model# FEF366EC. The Element ON indicator lights will glow when one or more of the surface elements are turned ON. A quick glance at these indicator lights when cooking is finished is an easy check to be sure all control knobs are turned OFF. The Hot Surface indicator light will continue to glow AFTER the control knob is turned to the OFF position and will glow until the heating surface area has cooled sufficiently. I suggest resetting your appliance by shutting the power off at your home's circuit breaker for 2-3 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "clock" button, and then you will press and hold down either the up or down arrows until the correct time appears. Try turning the burner on that the indicator light stays on the most. When you turn it off if you are still having trouble with the element light staying on, I suggest contacting a local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 27, 2014 | Frigidaire FEF366EC 30" Freestanding...
The "element on" indicator light
It the indicator light on all the time? Or after cooking and you turn the elements off the light stays on for a long time but it does eventually go off?
Mar 04, 2011 | Ovens
Why did my oven light go off and then came back on then went out again,but the bake light stayed on?
I assume you mean the internal oven light when you say 'bake' light. If so, the oven light you are referring to is the oven indicator light. When the element is receiving power the oven indicator light will be on. When it's not receiving power it will be off. The oven thermostat controls power to the element and the power cycles on and off during cooking so as to maintain the required temperature. This is a normal occurrence.
Feb 26, 2011 | Kenmore 46123 Stainless Steel Electric...
All my burners and oven quit working after a power outage. Looking for a way to get them going again. I replaced all the fuses on top of the range but still no power to the elements. The indicator lights...
after power outages it is common for electronics to blow aftere the intial surge when power returns.. i would bet ur control board is blown..i would check that out for any obvious signs of damage
Feb 05, 2010 | Kitchen Ranges
Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
May 30, 2009 | Kitchen Ranges
Hot surface light indicator stays lit
The hot surface light is controlled by a part attached to the element called a limiter. For your model, the limiter is not available as a seperate item. The element/limiter assembly has to be replaced as a single unit. The top assembly, elements and limiters are all fragile parts.
If you are making this repair yourself, make sure the range is disconnected from it's power source prior to service.
Apr 27, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
The hot surface indicator light remains ON all the time.
Your hot surface indicator light might have a short that causes it to stay on all of the time. If you can, try unplugging it for a little while and plugging it back up. If the light is still on, you have a short. You can still use the stove, but the light staying on will not be any help to you.
Oct 22, 2008 | Frigidaire FEF366EC 30" Freestanding...
GE Spectra JBP30B0B4WH surface unit light stays on
If it's the light that indicated the element is on, replace the switch. If it's the light that indicated the element is hot, replace the element.
Jun 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
Hot surface indicator
The component that controls the hot surface light is part of the element. If there is a light for each element you just replace that element. If there's one for the whole surface or each side you'll have to figure out which element is causing the problem.
Oct 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
GE Spectra JBP78 Electric Kitchen Range Logo
206 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
