Question about GE (PSS26MSRSS) Side by Side Refrigerator
The auger on my ice dispenser is broken
The aguer on my GE Profile ice dispenser is plastic and the fins are breaking and the ice will not dispense. I would like to replace the auger with one with metal fins...or at least find a new auger...GE tells me I need to buy a whole new ice dispenser unit...
  • 1 more comment
  • michaelrlars Jan 09, 2009
    part number and where would I order it from?
    PSS26MSRSS
  • Anonymous Feb 10, 2009
    My fridge is 2 years old and the plastic auger broke apart. GE must know that this is a recurring problem and step up to the plate and offer an improved replacement.
    Is there any movement in this direction?
  • 115 Answers
That is not true you can buy the parts seperately if you want to I will get the part # tomorrow for you just please rate me
Posted on Jan 05, 2009
  • Steven Carter Jan 09, 2009
    what is your model#
  • happytexas Sep 06, 2010
    This is the part number for the auger in my GE side by side (the fins broke on ours as well).
    WR17X11263
GE FRIG has stopped dispensing crushed ice, just cubes
test auger solenoid. unusual problem, usually other way around. clean out ice bin and check for anything broken.
Oct 15, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE Profile Artica. Dispenser is not dispensing ice even though ice bin is full. When i press the for ice to dispense , the light dims and the compressor stops.
Try taking out the ice bin press the door light switch and dispense ice button at the same time and see if the motor bracket turns without the ice bin in place. It is possible you have ice in the bottom of the bin that is frozen and jamming the movement of the auger. If not the problem may be a defective auger motor=> WR60X10259 Auger-Motor
I will be here should you have questions, Sea Breeze
Mar 01, 2013 | GE Refrigerators
Ice dispenser
THere is a plastic "hub" at the back of the bucket which attaches to the auger. THE "hub" catches a "fork" like device at back of ice maker which turns. The "fork" turns and in turn is supposed to turn the auger. That plastic hub could be torn up, broken, jammed, or otherwise not working correctly. That is what is wrong with mine.
Jul 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ge Profile Stainless Steel 26 ft Refrigerator ice maker dispenser
try pulling out the ice bucket, remove all ice and look for signs of damage on the auger mechanism... most of the time the ice tends to clump up and that prevents the auger from moving freely.
Mar 24, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice dispenser auger does not work.
Hi, On GE refrigerators the motor is not quiet. Open your freezer, remove the ice bin, press the door switch, make sure it turns off the light, and then press the ice dispenser lever. The solenoid will click, which also opens the ice door and the auger motor will turn on and you can definitely hear it. If the motor runs then inspect the auger connection on the rear of the ice bin, its plastic and they break. On some models, like my GE Adora there is a switch just for the ice maker behind the ice bin. If you need more help let me know as with all long distance troubleshooting we try with the information we have. Thanks and Good Luck!
Feb 15, 2009 | GE Refrigerators
you should be able to get it in metal mine is in metal check with your apliance parts dealer in your area thanks from gilles
Feb 04, 2009 | GE GSS20IEP Side by Side Refrigerator
GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Nov 21, 2008 | GE GSS25LGM Side by Side Refrigerator
Ice Dispenser not working on PSS26SGPA Stainless Side by Side
This is a common problem with this GE and "lookalike" models. The dispensers first break the front plastic drum that holds to the auger and eventually cracks the rear circular sleeve as well. Pieces from the drum usually fall off and are even dispensed with ice ... eventually the drum is damaged enough that the auger no longer operates. The motors on these units, however, continue to operate.
You can receive the replacement parts needed to make the ice maker auger operate again by visiting the GE parts website. A usual repair will run $40-60. Unfortunately, the design of the replacement drum has not changed, so be prepared for this to happen again.
Best of Luck.
Apr 24, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
241 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
