Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Moving deckpullies,mounting and spring application for troy-bilt riding mover model 13bx60kh011
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: The deck belt keeps falling
Either the belt is stretched out and needs to be replaced or there is an idler/tensioner pulley that may be weak and not putting enough pressure on the belt.
Posted on Jun 30, 2010
Need diagram to replace tension spring for drive belt
Go to the manufacturersame website, enter in the the model number and look under diagrams for the pic of your tractor. My troy Bilt has 2 belts, one for the cutting deck and the other is the drive belt. I would replace both as the cutting deck needs to be removed and it's fairly simple and will save you time. It sounds let the drive belt is the reason for the tractor not moving. Hope this helps.
My tractor is a 2007 troy Bilt super bronco with a new fresh installed motor.
Nov 03, 2015 | Garden
The spring at the underside rear of the Troy Bilt riding mower that I have is broken and the mower won't go in gear.
May need to shop it. It moves and has a blade...u can buy serviceguides...read safety first
Oct 07, 2015 | Troy Garden
How do i adjust the drive belt on my troy belt bilt pony model 37120
most of the time there is no adjustment either replace the belt, replace the spring or shorten the spring ,ive shortened the spring many times and had great results this allows more spring tension to be applied
May 18, 2014 | Garden
Adjust clutch pto
normally they work by spring lock system, follow the bar under the hood or engine and check if any broken or missing spring or parts often bended by running over things
Aug 08, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
Deck belt broken, l need a diagram to replace new belt on a Troy bilt riding lawnmower, 42 " cut 20 Hp, model # 13AP60TG563. Thanks
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Troy built riding mower runs at low speed and
Probably an engine problem.
Does it run at max rpm with mower deck disengaged?
Apr 18, 2010 | Troy Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
23 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
