Question about Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV
How to replace pull cord on a troy built TB320BV leaf blower
4 Suggested Answers
  • 736 Answers
SOURCE: troy bilt tb320bv 31cc gas blower starts and runs
inside the fuel tank you will see a flexible fuel line with a filter attached to the end ... that filter acts as a weight to position the fuel line in the lowest part of the tank no matter what postion the blower is in ... make sure the fuel line isnt broken .. also make sure the filter is still attached .. you can replace the fuel line and filter but both have to be able to handle achohol (in the gas) .. most of the older fuel lines cant and they go bad in a short time .. its actually hard to find the correct fuel line ... the size is not usually a problem but the material its made of has to say its suitable for modern gas .. most i found at local shops are the old type and wont work ..
Posted on Nov 05, 2009
rycgl
  • 1545 Answers
SOURCE: What spark do I use
Your 31cc engine uses a Champion RDJ7Y. The gap is .020".
Posted on Jan 08, 2011
SOURCE: Replacing the pull cord on
This is from the tech center at Troy-Bilt.......Take the spark plug out and stuff the plug hole with a piece of rope. I used 3/8 nylon,and stuffed it in until I couldn't get any more in....WA-LA!!!!! A few turns with my ratchet wrnch, and I was on my way to success! A breaker bar would be better if you have one.It will save the gearing
Posted on Aug 29, 2012
Pull cord
You could take the three screws off that hold the recoil on to the moter then see it you can pull it and pull it slow if so then you seased the motor if not able to pull still then you need a new recoil hope this helps you.
Mar 20, 2012 | Troy-Bilt 31cc 2-Cycle Gas Powered...
HOW DO I GET TO THE SPARK ARRESTOR ON A TROY BILT LEAF BLOWER TB320BV AND WHY IS IT IMPORTANT?
Go to parts tree.com and put your model # in and search you will see a Blow up of your blower. Looks like you just pull the 2 muffler screws out and muffler comes off or apart so you can check the screen,
Nov 22, 2011 | Troy Garden
Pull cord stuck - only out an inch or so
it sounds like it got cought around the recoil in wich the string rolls up in
Nov 23, 2010 | Troy Bilt Tb320bv Spring Assist Blower/Vac
The bolts holding the fan to the housing came off and it won't start. Is it worth trying to repair or just trash it and buy a better built blower
Troy built is a very good machine but you might have answered your own question especially if the machine is very old.
Nov 18, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Troy bilt tb320bv wont start. only two months old.he cord won't pull out completely like it used to and it won't let me start the thing any longer. It is like something is jammed in the system.
It seems to be a usual problem with troy bilt trimmers and leaf blowers. There should be a half moon piece of keystock that holds the flywheel on,sometimes its known to sheer off. Could also be one of the keepers that hold back the plastic disk for the cord comes loose,it gets in a bind. Either way,you have to open up the case and see whats going on.
Aug 05, 2009 | Troy Bilt Tb320bv Spring Assist Blower/Vac
My tro bilt model tb320bv gas leaf blower will not run at full th
The carburetor may need to be taken apart and cleaned or rebuilt. If you haven't taken one apart before your best bet is to see if you can get an after market carb for it, that would probably be the cheapest way out.
Jan 12, 2009 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV Logo
159 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
