Question about Lenovo (40Y8623) DVD±RW Dual Layer Burner
I have Dvd drive problem
I have a more then unwanted sounds and Some Dvd's can not able read the data's. This is my main problem.
    Scholar:
  • 62 Answers
Manually delete the registry entriesNote Before you use this method, uninstall all CD or DVD writing or recording programs. Deleting the corrupted registry entries might cause problems with any other CD or DVD writing or recording programs that are installed on your computer. Uninstalling these programs before you start will help you avoid any problems that removing the registry entries might cause. You can reinstall these programs after the problem is resolved.
This method provides step-by-step instructions for how to use Registry Editor to delete the following corrupted Registry entries:
  • UpperFilters
  • LowerFilters
Step 1: Start Registry Editor loadTOCNode(3, 'whattotry'); click on Start menu : Run : type regedit : press enter
Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
  1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
  2. Expand SYSTEM, and then expand CurrentControlSet.
  3. Expand Control, and then expand Class.
  4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  6. On the Edit menu, click Delete.
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'whattotry');
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
    Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
    If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  2. On the Edit menu, click Delete.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer loadTOCNode(3, 'whattotry'); Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
If you cannot access the CD or DVD drive, or if you receive an error message, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions to the problem.
Regards
Chittaranjan
Posted on Jan 05, 2009
Seagate 3tb external hard drive gives beeping sound when powered on and not recognized by computer
There is a possibility that your hard drive has been physically damaged. I am saying this because unwanted sound and not being recognized are one of the symptoms of hard drive failure . So if the data is very important for you consult the data recovery specialist they will for sure help you out.
Feb 11, 2013 | Computers & Internet
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Aug 28, 2012 | Ahead Software Nero Express 6.0 (NERO6OEM)...
How do i erase unwanted things off the cd-rw?
By the nero software you can write or erase the program from the cd or dvd RW. You can erase from the cd but cd is so sensible then dvd so that it might have dangerous to do that. Because it can lost all the data you have created before you have tried to erase the unwanted data. My safely instructions to you that take up a dvd and burn the data from the cd to dvd that you want.
Dec 28, 2010 | Computers & Internet
My samsung combo drive is only reading dvd movies but not dat DVD
Does it show the contents of the data DVD. Try atleast 3/4 DVD's , it sounds very unlikely.
Jul 04, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
I can read data cd but cannot read data dvd
Are you sure that the drive you are trying to read the DVD with, is actually a DVD drive and not a CD drive? Check on the front of the drive draw, it should say DVD on it. If not you will need to purchase a DVD drive to read DVD's. Nik.
Jun 30, 2009 | Computers & Internet
When I put DVd in sounds like its loading then I get disc error playback not on this disk
Several possible causes
1. Laser read lens dirty - clean it
2. CD has become damaged & data cannot be read (does it read in other cd drives?)
3. Intermittent malfunction of laser read circuitry.
4. Process of elimination - if CD is readable on other drives, the problem is with DVD player. If cleaning does not solve the problem, the problem is DVD internal electronics.
Jun 18, 2009 | Electronics - Others
The dvd rom drive does not read nor write
Sounds like it could be a faulty drive. Will it play any CD/DVD like a data or music one?
Mar 22, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
CANNOT READ DVD MOVIES
You need a DVD decoder installed to play DVD movies on your computer even with a DVD Drive.
Learn more about DVD decoder software, use the link I have provided:
http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx
Please rate my solution
Jan 15, 2009 | Dynex DX-DVDR100 (DXDVDR100) Internal DVD...
DVD READING PROBLEM
Hi , look in software store having a cd cleaner , to clean the optic laser of the dvd./ something block the reading of the data of the dvd disc.
Jan 16, 2008 | Sony (1-796-293-13) Plug-In Module DVD...
Unwanted files
DELETE UNWANTED FILES Download and Install, Watch out for the Yahoo setup! http://www.ccleaner.com/download Hope this helps
Sep 20, 2007 | Panasonic Combo Drive - DVD-ROM & CD-R/RW...
Lenovo (40Y8623) DVD±RW Dual Layer Burner Logo
88 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
