Question about Kenmore Washing Machines
Kenmore model 110: 82673110 top load washer will not go thru spin cycle. The motor is running and the tub is draining, but it won't spin-dry the clothes.
Kenmore model 110 :82673110 top load washer will not go thru spin cycle. The motor is running and the tub is draining, but it won't spin-dry the clothes. What part needs to be replaced?
  • 1122 Answers
SOURCE: kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Posted on Dec 06, 2008
  • 4088 Answers
SOURCE: my top loading kenmore elite washer model #20972
No, this is probably a direct drive that has a faulty plastic coupling from motor to transmission. Go to:
http://www.fixya.com/support/r385252-replacing_motor_coupling_W... by jsrock516
Please give him a pat on the back for the help.
Posted on Oct 12, 2009
  • 1937 Answers
SOURCE: Kenmore top load washer last spin cycle problem
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Three possibilities: Ranging from easy to relatively messy but inexpensive.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a
rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be
damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
It's also possible that the Neutral Drain Assembly in the transmission is broken:
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for top load direct drive washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/
$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Ours had a similar problem.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams
in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2"
socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the
motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds
15Oz of 80-90 weight gear oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
All of the above sound more difficult than they really are. If you're comfortable with a socket set, pliers/vice grips and willing to get a bit dirty (oil) you can save some considerable money.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Jul 11, 2010
  • 1937 Answers
SOURCE: Kenmore hvy duty 90 series washer will not spin or drain
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
It also has a troubleshooting guide.
Also see the following for a more detailed description of how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
Posted on Jul 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite model 11015942401. Washer beginning
It appears your Pressure Switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
Our Kenmore top load model 22422 started having problems with the spin cycle. Once it gets to the spin cycle, it makes a terrible grinding like noise - it is not spinning. However it will drain if you let...
The double shaft motor does double duty. One direction for wash and another direction for spin. In wash mode the water stays put in the tub because the pump is running backwards. In spin mode the motors turns in opposite direction. This pumps the water out and spins the clothes dry. From what you have described the drive coupler is toast.
This video shows how to swap the drive couple out:
More HERE
Mar 01, 2011 | Kenmore 22422 Top Load Washer
Model 23832 Spin cycle doesn't spin
I believe this is the direct drive model. Your clutch is slipping. There is a quick easy fix available that I have used in the past. Remove cabinet from washer. Make sure you know the easy way to do this... 2 screws on top back of washer and 2 holding control panel. cabinet tips toward from of unit and off. Real easy... Remove wire harness from motor under basket. Remove 3 screws holding motor to basket. Remove agitator inside basket. 1 screw holds it in place. Remove entire motor and shaft from unit. Clutch is attached to shaft on top of motor. Pinch spring to remove clean everything with alcohol. Insert #10 washer between cup and spring to give a little more tension. Replace and viola.... all should work well.
Jul 10, 2009 | Kenmore 23822 Top Load Washer
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Washer not spinning - not timer
I have a Kenmore 80 series mode #2289400. It will wash but will not drain and spin. I have turned the knob to a different spin cycle put it won't spin. I have drained the water out of the tub thru the drain pipe so it's not plugged. When it's ready to spin and it making no noice. Any help would be great.
Sep 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
54 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
