Question about Aprilaire 550 Humidifier
I have a Aprilaire 550 Humidifier. The feed tube is cracked and leaking. How do I go about replacing it. When I use a wrench to remove the copper end, will water come pouring out?
  • aretk Jan 08, 2009
    I have the same problem - need to shut off the main supply line to the humidifier and remove the cracked line - I am having a tough time finding the line in our local plumbing supply stores...they are all recommending copper tubing specifically since mine is set up such that I have hot water going through my humidifier. If yours is the same set up - you must ensure to get the proper tubing for replacement.
    Novelist:
  • 88 Answers
Thanks for your question,
what you need is called an ( Ice maker kit ) any hardware store or appliance store should carry these, the copper tubing is 1/4 in, the kit comes with the service valve for turning on the water once installed, be careful, turning it on before the line is hooked will get ya soaked, it has compression fittings, make sure you dont cross thread the nuts when installing, you may have to shut the main water supply off to the house before doing this, the instructions are fairly easy to read, you can get 25ft - 100ft ice maker kits, you are going to need a tubing cutter and a cresent or box end wrench, and a big flat head screw driver, hope that help ya, lets us know, thanks again for the question,
mr.grzz
Posted on Jan 21, 2009
Aprilaire 550 Changed the water panel and the water distribution panel. There is a little u-shaped cradle for the feed tube. But the feed tube is not secure and sprouts water everywhere. Now what?
On the water distribution panel there is an "L" shaped nozzle that the water hose plugs into, this directs the water into the top of the distribution panel. Your's is obviously missing. Look for this part on the parts you removed.
Dec 28, 2010 | Aprilaire 550 Humidifier
What is the saddle valve?
Your humidifier will have either a copper or plastic tubing attached to it. This tubing is the water tubing. If you follow that line to where it "taps" into a water line (near the water heater or a water line under your house), there should be a water shut-off valve. The water shut-off valve could be any type of valve but is normally a saddle valve. You could skip the step of shutting off this valve; however, it is good practice to shut the valve off for two reasons: 1. in the event of a water leak, you will be able to easily locate the valve to shut off the water. 2. if the valve is not "excercised" from time to time, the seals will dry rot and the valve will not be capable of doing it's job when the need arises.
Here is a video showing you how to trace your water line to your saddle valve. There is additional information on the video that you might find helpful as well.
May 07, 2010 | Aprilaire 550 Humidifier
What controls how much water flows into an Aprilaire 550? It was fine until a couple of days ago. I replaced filter, but it still appears to be too strong. It not only runs out the drain tube but is...
In the water line where it connects to the solenoid is an orifice. You can install a smaller plastic orifice or you can install a manual feed valve to where you can control the flow.
Feb 12, 2010 | Aprilaire 550 Humidifier
A strong continuos flow of water flows through the unit when on. flow is too stong is orfice or solenoid valve broken?
orfice is plugged with calcium and its like a sprayer hose nozzle you need to either clean out copper water tube or replace it
Dec 18, 2009 | Aprilaire 550 Humidifier
The unit leaks water on the floor
you need to replace the pad every season. if you are using a generic pad maybe more often. it also must be level and the drain coming off bottom clear. i suggest getting pads from aprilaire.com . not the generic from hardware store. also if its got a black feed tube going from the solinoid valve to the top of the humidifier pad you may want to replace that aswell, they have been known to crack the new ones are grey.
Aug 10, 2009 | Aprilaire 700 Humidifier
Water Leak
there is a nozzel at the end a black tube at the top of the hummidifier that has come off or the tube is cracked
Dec 24, 2008 | Aprilaire 550 Humidifier
Water feed tube and nozzel seems to plug
What type of plumbing do you have? Galvanized, copper or pvc?
Dec 15, 2008 | Aprilaire 700 Humidifier
Routing waterline to pad
1/4" flexible copper pipe. Tap into your cold water line using the included saddle valve (pierces the pipe), attach the 1/4" flexible copper pipe to the saddle valve on the cold water pipe and the solenoid valve on humidifier unit using the included compression fittings. Tada!
Dec 10, 2008 | Aprilaire 550 Humidifier
No water flow to the humidifier
Turn that pin to the left and that will open the valve to allow water to flow through it. If it starts to leak the all you need to do is tighten the nut that were the water is coming out with a wrench, be carefull it wont take much to tighten.
Dec 02, 2008 | Aprilaire 600 Humidifier
Humidifier leaks water when turned on
Humidifier water pad comes w/ a mark in one end, that mark should be on top. Also check your feed tube they tend to crack some times. if if still leaks water change the water pad
Nov 14, 2008 | Aprilaire 550 Humidifier
Aprilaire 550 Humidifier Logo
135 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
