Question about Muratec F360 Plain Paper Laser Fax
How do you reset drum counter on muratec f-360
3 Suggested Answers
SOURCE: How do I reset the drum counter on a Muratec F320?
Ok, this is how I resolved it for my fax machine.
I powered down the fax, removed the new drum and reseated it.
When I powered it back on the counter reset itself as it is supposed to.
Posted on Dec 13, 2008
SOURCE: Drum resetting
Press Menu button
Press * (3 times)
Press Menu button
Press * (once)
Press # (once)
Press * (2 times)
Press 77
scroll down to "Drum life monitor clear"
Press Enter (once)
Press Enter (once to confirm delete)
Press Enter (once)
Press Stop or Reset
Posted on May 19, 2009
Reset code for muratec mfx 2010
Is it the drum counter? You can only reset when you put a new drum it it.
http://www.fixya.com/support/t18621752-muratec_mfx_2010_reset_drum_amp
Jan 04, 2016 | Muratec Office Equipment & Supplies
Just installed a new drum. and still get the change new drum message.
The new cartridge came with some paper work and you have to reset the life counter. I should be under the user funcation. Or you may have to have the cover open and turn it On. and follow the instructions
Sep 14, 2010 | Muratec - MFX-1300 Copier
Muratec mfx 1300>> CAN I reset A "replace
YES....try the following...... Press PROGRAM,*,*,I(thats capital letter i) then press ENTER.
SHOULD RESET IT.
Jun 16, 2010 | Muratec - MFX-1300 Copier
How do i fix lite copies on a muratec 2850? What should i check?
Drum and Developer have a life of approx 80,000 pages. Ensure these are not at their lif'es end by checking counter.
Next step is Mirrors under the Glass..depending on environment they can get dusty causing "Faint" copies. Don't just look..take the glass out and clean the mirrors with a soft cloth. If needed last step is to reset background level,...Press Setting, * ,0, 9. Select "Background Level"...Put a piece of 11" x 81/2" paper in the ADF...Select "Both"then Press Start. After resetting the background level then mahine will return to normal.
Apr 08, 2010 | Muratec Copier
How do you reset memory board for muratec f-320 . I am trying to get rid of an error message"Replace drum unit printer not useable". Installed new drum unit and still gives the same error message.
Before doing complete Memory clear try the following...
Press..PROGRAM,*,*,I(thats the letter I),then ENTER.
That should reset it. Only replace the new drum into the machine when the machine says "Replace Drum"...NOT when it says "replace drum soon".
As a last resort a complete memory clear is PROGRAM,*,3.....but be warned this will clear all memory back to factory defaults "except" the Life Monitor which has the counters.
Oct 29, 2009 | Muratec F320 Plain Paper LED Fax
Reset drum counter on a muratec mfx 1430
Drum counter is reset by installation of a "NEW" drum.
There is a small fuse at the rear of the drum on the top( you will see the 2 brass contacts) When a new drum is installed, the fuse blows and resets the drum counter. Installing a used drum will not reset the counter as the fuse is already blown.
Sep 15, 2009 | Muratec MFX-1430 Copier
Muratec 2830 drum cartridge problem.
The drum cartridge is different from the toner cartridge. The drum has reached its life cycle and must be replaced. This is normal for any copier of that class.
The drum is not too expensive and not difficult to replace.
Hope this helps!
Sep 09, 2009 | Office Equipment & Supplies
Nov 12, 2008 | Muratec F320 Plain Paper LED Fax
Muratec F360 Plain Paper Laser Fax Logo
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
