''Blew'' my power strip and can't reset it.
I have a MonsterPower Home Theatre Power Center HTS 950 power strip/surge protector. I ''blew'' it when I added a portable heater to it. It usually has just the tv/dvr/dvd/speakers plugged in. I can't reset it. Any suggestions?
    Problem Solver:
  • 21 Answers
Open it up and on the inside is a fuse replace it check outlet in wall to make shure it is working
Posted on Jan 05, 2009
My hdmi ports aren't working when tried blank screen comes on I can plug the cable connection in and have cable
If you don't have it plugged into a surge protector box it may have fried your connections. If you do have a surge protector, try reseting or push power button on surge protector unit.
Aug 15, 2017 | Televison & Video
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
Humming/bussing
In most case power-outlets do not have problems,so the problem maybe with the surge protector it's self.Please try it maybe at friends house and see
Jan 09, 2014 | Monster Powercenter Hts 950
Montster Power hts 350 power conditioner
it depends on where it is and where to find a bulb may have to contact the company itself
Jan 04, 2014 | Monster Power HTS 3500 MK11 Home Theatre...
My panasonic SC-HT17 home theatre system was working in the morning and afternoon, then when it was switched on again for the evening news it would not work. I changed batteries and checked the batteries...
sounds like you had a power surge. yhou need to unplug your system from the wall for about 30 minutes to reset the on board surge protector. also if your comfortable you may wanna open it up and see if you blew a fuse on the board PLEASE LET ME NOW IF HELPED YOU OUT.*KEYBOARD STUCK ON CAPS SORRY
Mar 17, 2011 | Panasonic SC-HT17 System
We had a power surge in our living room while the TV was on. It was also plugged into a surge protector, however, everything else turned back on but the TV. There is no power going into it at all, as if...
Sounds like it might have blew a fuse on the AC input to the power supply, have to remove the back and look for a fuse near where the AC wires go from the plug on the tv. If the fuse is good
the power supply board will have to be checked or replaced..Next time consider buying a surge
protector that starts clamping at a lower voltage. Panamax brands usually start going to work
at 150v rms, where most others start at 330v rms..
Oct 21, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
We didnt have a surge protector on our tv we purchased from home shopping net. and lihtning came in the line and i guess hit our tv can it be fixed or is it worth fixing price wise i hate to throw it away...
Look at the power supply module, most of them will have a surge protection devices (called MOV, same as used in common surge power strip but cannot handle big surge that power strip can handle) installed to protect minor surge, it should blow the fuse. Once MOV blown, it will more likely stay short circuit, if you put the new fuse in it will blow the fuse right away. You need to see if the MOVs blew up any sign of blown up components.
Nov 01, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
Vizio L32 HDTV - Blew Out, No Power
Yes, I do in home warranty work on vizeo, it sounds like you need a power board and perhaps a main board. The power board is what pooped.
Nov 13, 2008 | Vizio L32 32 in. LCD HDTV
Mitsubishi WS- 65809 65 INCH
If your TV is not powering on you probably blew the power supply. These TV are sensitive to power surges. Be sure to use a power strip with power filtering technology (different from a surge protector) costing around $80.00
Sep 06, 2008 | Mitsubishi WS-65809 65" Rear Projection...
RCA g36788LV TV
check fuse n power supply section
Oct 27, 2007 | RCA G36788LV 36" TV
Televison & Video Logo
761 people viewed this question
Top Televison & Video Experts
Electro Med Services...
