Question about Kenwood KDC-MPV8025 CD Player
Door Opens then closes and Powers Off
Radio has been working fine for quite a while. But, now, when the ignition key is turned (to start the car) nothing happens to the radio. The 'manual' method to turn the radio on will not do anything. If the 'Power Button' is depressed, the radio will act like it is powering up - opening the door.....but after a few seconds it closes the door and powers off. I have verified all needed voltages and grounds. ANY Assistance will be GREATLY Appreciated! ! !!
  • feijuejai Nov 09, 2007
    please help i have the same problem, any suggestions would be greatly appreciated thanks
  • Anonymous Nov 01, 2008
    HELP!!!!!!!!!
  • 3 Answers
Try holding down BUTTON [5], then press the RESET button (you'll need a ballpen between the AUTO and SCRL buttons). This worked on the KDC-MP825 (very similar to the MPV8025) when my wife had the same problem this month.
Posted on Dec 08, 2008
MY RADIO STAYS ON WHEN I REMOVE THE KEY and close the door
radio stays on after removing key from ignition - Car Talk
community.cartalk.com/.../radio-stays-on-after-removing-key-from-ignit...
Mar 4, 2012 - this just started today and when i turned off my car and removed the keyfrom the ignition, the radio stayed on.
04 F150 - Radio stays on after key removed & door open ...
www.f150online.com/.../323659-04-f150-radio-stays-after-key-removed...
Mar 2, 2008 - You know how you can take the key out of the ignition (after turning off), and radio continues until you open the door? Well, yesterday I opened ... More results from www.f150online.com
Oct 22, 2015 | Chevrolet Astro Cars & Trucks
The car is parked, turned off, and the doors locked. Came outside this morning and the radio was on with no key in the ignition. What would cause the radio to run without a key in the ignition?
The conveience delay module may have a problem if equipped. It is designed to operate some of the features with the ignition turned off( radio,wipers,power windows etc) until the driver opens the door and power is then cut to these features.
Jul 25, 2015 | 2002 Kia Sportage
My ford radio comes on when I open the door no key in ignition
Call Ford, it might be something that can be set to do that. Many cars have features that can be set up in that way. Other than that I have no idea? Good luck.
Jan 16, 2014 | Ford Cars & Trucks
Dash Gauges, tach, speedometer and radio dont work seconds after truck starts, dome light won't come on when door opens, and when using electrical door lock switch when the truck i sparked and turned off,...
possible bcm you have a on board computer that tells you when doors are open lights are on also after turning key off you can listen to radio or open close windows for a limit of time then the bcm cuts off the power to everything if you are not sure check with dealer if they have problems with bcms body control module
Jan 03, 2011 | 2005 Ford F 350 Super Duty
AAA advised me to open and close door with key
Yes. Because the security system was "set". You need the code to unlock the security system for the radio. It is like that for theft pruposes. Best bet is to go to the dealership to have them reset it or figure out how to get the code for your radio.
Oct 31, 2009 | 1999 Audi A6
I have a 1996 vw jetta and i turn off the ignition, remove the key and still have power to the radio and door sensor.
Some cars allow power to the radio, etc. even after the key is turned off and taken out of the ignition. If everything turns off when the door opens, then it is most likely normal for your car. I know the newer VW Jetta's do this.
Jul 22, 2008 | Volkswagen Jetta Cars & Trucks
Sub display screen
It's usually the flexible pcb that connects the fascia to the main board that needs replacing, because the fascia opens and closes each time the ignition is turned on and off the connector flexes and eventually some of it snaps, sometimes if you pop the trim off you can see the snapped pcb on the bottom right hand side of your radio
Dec 11, 2007 | Sony CDX-M800 CD Player
No channels
turn power of the radio take keys out of the ignition open drivers side door for 30 seconds then reverce the process works good majority of the time
Aug 14, 2006 | Sirius Satellite Radio S50-TK1 Satellite...
Kenwood KDC-MPV8025 CD Player Logo
136 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
