Question about Intel CASE 350W PWRS ALLIED W/ 24PIN + BALL BEARING, LISTED, BLK/ SLV COLOR 2 FRNT USB MICRO ATX (TM16324)
Monitor heater smells like exhaust
We just changed the fuel pump and in looking for why the heater wouldn't work we may have messed up something else because although the heater works now it blows exhaust everywhere. thanks
  • cathy_conway Jan 23, 2009
    No, it is a Monitor 441 kerosene heater for a house.  And we finally discovered that it was the gaskets around the fire box.
    thanks
  • Thomas F. Schneider May 11, 2010
    You changed the fuel pump on a PC monitor? You may wnat to go to this sites home page and renteer your question. We don't  even know what piece of equiptment you are working on.
How do I fix the Monitor Lifter Pump 1103?
The pump is not drawing oil but only when when sucking. (You knew that). I would guess that moving the heater caused a small leak in the oil suction line or pluggage in a suction strainer/filter. When primed, everything is OK. So ignitor, nozzle, etc is OK when the prime fluid is present. But the pump cannot draw liquid. Look for a very small leak in the suction letting air in. Look for pluggage in a suction filter. It won't take much air inleak or suction restriction to stop a pump from lifting.
Nov 30, 2014 | Cars & Trucks
Burning rubber smell whilst going up hill
This sounds like an oil leak. Look for leaks at valve covers, and other areas above the exhaust. It often is the burning off of this small volume of oil, that makes the smell like you describe. Inspect the whole exhaust...Something is melting, somewhere.
Oct 09, 2012 | Toyota Avensis Cars & Trucks
Brand new 2011 impreza 2.5i once car is warm bad smell come form under the hood and out of the heater. does not smell exactly like oil but its pretty bad and gives me a head ache.
It is possible that something got spilled onto the exhaust manifold and is burning off. If the smell doesn't go away with a bit of time make sure there is not an oil leak or other fluid leak underhood. Another possibility is that an animal had climbed into the engine compartment and had made some sort of a mess - I have seen it happen before and critters can make a mess sometimes.
Mar 15, 2011 | Subaru Impreza Cars & Trucks
I have an MPI 41 Kerosene (K-1) monitor heating my home. Every time the monitor starts it gives off an intense smell of Kerosene. It lasts about 4-5 minutes after starting and then the smell seems to...
I would check all fuel lines, connections, and watch how long it takes to ignite. Kerosene heaters should atomize fuel meaning it should look like a fog not droplets, so that would point to fuel nozzle problems. That being said it should exhaust out side not in to the house, inspect the burning chamber real good for cracks or leakage? If this unit has a flue or damper make sure it has a good draft to exhaust the burnt fuel. This is purely speculation not a solution, these are things I would be looking for if it were in my home. Good luck
Jan 07, 2011 | Heating & Cooling
I smell an odor, but no one else in my family does. I have a carbon monoxide alarm, but that doesn't go off. It gives me a headache and a soar throat. Any suggestions of what I might look for on my MPI...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you have a Monitor heater you need to figure out right away what is making the odor. Any odor from a Monitor heater could be CO and that is not good. Look at the back of the heater where it connects to the exhaust. The little Z pipe should be all the way in at both the stove and the flue pipe. Take the front cover off the heater and look at the heat exchanger. This is the part on the right side that has either two or three chambers. Make sure there are no cracks anywhere. Also look at the back of the unit where the fuel connects. There should be no raw fuel any where. Beyond this you will need to get a service guy over and have a good look.
Tom
Apr 11, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My monitor 41 smells like kerosene when it sits idle, repair man came out and told me he fixed it, but it still smells
Does it smell like raw kerosene or exhaust. If it smells like kerosene it sounds like you may have a fuel leak. If you can remove the grill, look inside and check for any kerosene in the bottom and in the tray under the heater. You should also check your fuel line for leaks. If it smells like exhaust look inside and on back of the heater for any black soot marks. There are a couple of o-rings, 1 in the exhaust connection in back of the heater and 1 in the flue pipe where the exhaust from the heater connects. There's also several gaskets in the combustion chamber that could be leaking. Hope this helps. If you need any more info, you can send me an email (nitensheaterservice@embarqmail.com).
Jan 20, 2010 | Heating & Cooling
My reddy heater was running and ran out of fuel at which time it gave off a foul exhaust. Was this exhaust carbon monxide or just the sulfer smell associated with kerosene?
probably both and unburnt fuel also. when the unit ran out it still pumped a small quantity of fuel into the hot burner chamber where it turned to smoke and was expelled. carbon monoxide itself is odorless and what is normally referred to as c. o. odor are unburnt fuel products, some of which smell pretty strange.
Jan 14, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
My Toyostove OM-22 smells like exhaust gas in the room. I think its a gasket problem (fuel line looks OK; vent pipe is clean) I want to buy replacement gaskets for the burner, the flame sensor, etc....
There are some orings in the exhaust that might need replacing. Do you have a parts breakdown for the heater? I repair monitor and toyostove heaters and can get you the gaskets. I'm in NC. You can contact me at nitensheaterservice@embarqmail.com
Jan 11, 2010 | Rinnai Toyostove Direct Vent Heater:...
My toyostove is making the room stinks(burned dieseal ) smell. What is causing this?
Something to check would be the exhaust vent for leaking. We just replaced our old Monitor 40 because it was making some terrible exhaust smells in our house and it turned out their was a crack on the exhaust line just where it enters the stove. May be worth looking into. They are a lot cheaper than a whole unit!
Nov 30, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a 41 monitor k1
I'm not real familiar with Monitor heaters, but if they are like Toyos, you may need to replace the pump.
Dec 02, 2008 | Rinnai Toyostove Direct Vent Heater:...
Computers & Internet Logo
366 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
