Question about Cisco Computers & Internet
I recently bought a CISCO SPA 303 phone and cannot pick-up an IP address, it stays on initializing network.
The phone is plugged into a Lynksis Wireless-N Broadband Router (Model No. WRT160N) with an RJ-45 Ethernet Cable.
SOURCE: Ethernet Disconnected message in POE 7941G IP Phones
the first problem will be to check or replace the cable that you use to connect the phone or check the jack that you use
Posted on Jul 12, 2007
Cameron07
  • 110 Answers
SOURCE: change ip address of recently installed router
The 192.168.0.1 is the device IP.
Your trying to change the "Default Gateway" mine is set to 192.168.1.1
Let me explain (:
1.Go to start>run>type "cmd" without quotes and press enter.
The black screen should appar, in that screen type "ipconfig/all" without quotes.
And press enter.
This is what mine looks like:
I took out some things to my security, but basically this is what some of these things represent.
For you, your IP it shows would be something like:
192.168.1.101
Each device hooked up to your network gets its own IP it will start at 192.168.1.101 for the first device, then 192.168.1.102 then the next device gets 192.168.1.103,etc...
Your default gateway, 192.168.1.1 is where it starts, to change this go to:
  1. Open your browser
  2. Type in the browser 192.168.1.1
  3. Login to your router panel (the user an pass sometimes are admin/admin look in your manul for more info)
  4. Look where you can change your default gateway.
Here is a example of what mine looks like:
I hope this educated you, and helped you fix your problem for more help visit www.pc-fix.us or just reply here.
Thanks,
Cam
Posted on Oct 18, 2007
fcollingwood
  • 58 Answers
SOURCE: Inline power problem: cisco ip phone 7941G
You need to ensure that each port that has a phone plugged into it is configured with power over ethernet configured switched on.
Posted on Mar 21, 2008
  • 70 Answers
SOURCE: USB Broadband to wireless router through desktop PC
If I get you right you are useing a 3g Internet connection and have a router wich conets the 2 computers together, the problem is that you can't share the internet connection.
Without any information about the operateing systems I can tell you the idea:
First you need to disable DHCP server on the router and use static IP addresses on both PC, the IP address should be something like
PC1:
IP: 192.168.0.2
Network mask:255.255.255.0
PC2:
IP: 192.168.0.3
Network mask: 255.255.255.0
Default gateway: 192.168.0.2
In this IP configuration above PC1 has the 3g modem connected.
This was the easy part, hard part is to share the internet connection on the network, that's a little different ritual on every operateing system, try to use google to get your specific one.
However there's a much more easier way to solve all your problems if you can't make it work, but it costs money. All you need to buy is a 3G router and that will do the same thing for you what your old router did.
I did a little search for you on Australian Ebay to see what you can get.
But I'm sure you have your own cheapbfavourite source of computer hardware as well.
Hope this will help you sorting out your porblem.
Regards
Imre
Posted on Nov 26, 2008
patemi
  • 366 Answers
SOURCE: Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Posted on Feb 09, 2009
Netgear fs516 default ip address
switches do not normally have ip addresses as they are layer 2 network devices. They work on the MAC address of each network card attached to it to direct the network packets of data to the correct Network card.
Cisco Switches have an IP address but it is a virtual ip address used to remotely log into a Cisco Switch via IP but has nothing to do with the switching function however this is not a cisco switch.
Routers have IP addresses and use them to switch IP addressed packets to other Networks that have Routers connected to Switches.
Jun 30, 2014 | NetGear FS516 Networking Switch
Tip
Cisco IP softphone - one way audio - fix
Using the Cisco IP soft phone via VPN can sometimes cause audio to drop. To fix this:<br /><br />Right click the Cisco IP Phone and select Preferences...<br />Select the Audio tab<br />Click on the Network button<br />In Audio IP Address select Use this address<br />then set it back to Detect Automatically<br />Click OK and OK again.<br /><br />Give it 5-10 seconds and this will auto reset the audio on the IP phone and will correct the issues with one way audio.<br />
on Mar 08, 2011 | Cisco IP Communicator (SWIPCOMME1CH1)
Why cant use the phone?
See if this solution helps from Cisco's website:
https://supportforums.cisco.com/discussion/11385276/spa-303-stuck-initilizing-network
May 13, 2014 | Cisco 303 Ip Phone
Cisco SPA504G Firmware update issue
You need to make sure that your laptop and IP phone are on the same network subnet. For instance, if you IP phone's IP address is 192.168.2.24 than your laptop must be on the same network addressing scheme, such as 192.168.2.23.
<a href="http://www.ciscopowercube.com">Cisco CP-PWR-CUBE3</a>
Sep 07, 2012 | Cisco SPA504G IP Phone
Hello, I recently brought in a few Cisco 7961 VOIP phones into our office. The phones register when I first plug them in but when I pick up the handset to dial there's no dial tone. I tried swapping the...
You need to verify that the Cisco phones are obtaining the proper IP address from your DHCP server. You need to make sure that you create a DHCP Pool of addresses for the VoIP phones that you have and configure the DNS settings in the scope to point to your DNS servers and configure the router settings in the scope to point at the IP of the router. You may need to also configure the TFTP settings in the DHCP scope. Check the IP address settings on the phones that aren't connecting, if they are receiving a 169.x.x.x address then it is having problems reaching the DHCP server to get and IP address. Hope that helps to point you in the right direction.
Cheers!
J the Guru
Oct 15, 2017 | Cisco 7961G IP Phone
CP 7941G issue
Try configuring CCM IP address either trough DHCP parameter, or Network configuration on the phone.
Oct 08, 2008 | Cisco 7941G-GE IP Phone
Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
  1. Press Settings.
  2. The Network Configuration lock symbol must be unlocked. If not, exit to the main window and press ** # again.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) to Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
May 18, 2008 | Cisco 7910 IP Phone
Cisco 7960G IP Phone Problem
Try to manually reset the phone - **#"Settings" (this will unlock the configuration) + Network + menu under number "33" - erase the configuration. Then the phone configuration will be erased. Also you can manually set IP address and TFTP server
Sep 11, 2007 | Cisco 7940G IP Phone
Computers & Internet Logo
1,517 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
