I have a Thor washer/dryer combo with a stuck door. I don't believe it is locked. I heard the usual unlock click when the cycle finished. The handle seems like it isn't catching right. The
SOURCE: Door Lock Clicks/Makes noises Washer does not agitate/spin
Sounds like very worn motor brushes to me, as its trying to turn the drum but has'nt the power needed to maintain any momentum,and the blinking door light is because of the bad cotact from brushes to motor.About £20 for a set of brushes or get an engineer to fit new brushes,but get a price first.
Posted on Apr 19, 2007
  • 3 Answers
SOURCE: Broken door handle on Splendid 2100 RV Washer/Dryer Combo
The Splendide distributor in OR sells handles for about $45.
Posted on Jan 28, 2009
  • 37 Answers
SOURCE: Equator Washer dryer combo......door wont open.
You will have to follow the drain out procedure and then the reset procedure.
Please see the link :http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Be careful, if you try to open the door by pulling the door handle too hard it may break.
Do let me know if this resolves the problem or else I may suggest something else.
Posted on Mar 27, 2010
  • 6277 Answers
SOURCE: need user manual for thor washer dryer combo TH
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jul 05, 2011
Testimonial: "hi john. good advice, Kelly has found this model was made in china & distibuted in austraia. looks like mission immposible. ahh thems the breaks. Ian"
  • 81 Answers
SOURCE: have a whirlpool AWO 3551 washing machine. Door
My daughter had the same problem for about two years. A repair man came out and told her to call the company and tell them she wanted it fixed under a recall. She said the computer board had to be replaced and it was recalled due to a flaw in the machine. The service man came back again after she called, and he fixed it for free.
Posted on Jul 16, 2011
Wfw97hexl0-door is locked and won't unlock or run a cycle just makes a buzzer noise every couple of seconds.
did you try to press the stop button then change the cycle to another then press the power button then press and hold the start button again that works most of the time.
Mar 11, 2013 | Whirlpool Duet WFW97HEXL Lunar Silver...
WASHER DOOR STUCK
Not all that uncommon on some front loaders. Yes, it is trying to lock and unlock. You can try two different things that might work. 1) Unplug the unit and let it set for 5 minutes and see if it then unlocks itself. Some units have a bi-metal timing that can take from 2-4 min. to release after the spin stops. 2) Wake up unit by pressing start or any button that starts the lock clicking. Have your hands on the door with some gentle pressure because if it unlocks you can pull the door open. Sometimes these things get mixed up and lock, unlock, and lock again. Once you get it open it usually clears up and does not happen very often.
May 17, 2012 | Daewoo DWD-WD3011WW 4.0 cu. ft. Capacity...
My Samsung VRT washer was working fine. The cycle appears to be finished but the door remains locked. I get no response from any of the buttons. You would think that the washer wasn't getting any...
I don't know if I have the same model SAMSUNG front loader, but I have a similar problem. The door has decided to stay locked at the end of the cycle. I can turn it off and on and even send it through another cycle, but at the end of the washing, it drains, goes to END but does not go the extra step of unlocking, like it usually would about 1min after ending the cycle.
My clothese have been through about 6 different cycles, hoping it will magically clikc open at the end. I assume they are very clean, but getting dizzy.
Any help out there?
Aug 12, 2011 | Samsung WF337AA Front Load Washer
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
I started a load of laundry and a moment later remembered I wanted to add something, I paused the washer, waited for the door to unlock, i added an article of clothing , but the door would not lock and...
You can manually release the door lock by taking off the dispenser assebly holder (bezel) on the top, left, and pulling on the door lock release cord you will find inside.
Richard Roth
The FixYa Team
Aug 04, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Splendide 2000 combo stops midway in the wash cycle. What is the cause and how can I fix it please?
If it doesn't go from the wash to the dry, check to make sure that both the washer and the dryer are set before the start of the cycle. It also could be blowing a fuse.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 13, 2010 | Splendide 2100 Vented Washer-Dryer
E13 error- can't unlock the door
To manually unlock the door lock system, perform the following steps:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a teardrop shaped tab. Gently pull the tab down approximately 1/4 inch, or until a click is heard.
5. The door may now be manually opened.
Apr 08, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Control lock is on but door opens it finished the cycle but the control lock wont shut off can you help thanks
Try some WD40 spray on the door
lock; on machine, not on door. And open & close for a few times with the power off.
Apr 13, 2008 | Whirlpool GHW9150 Front Load Washer
Door jam!
Probably you need a new doorlock. I really dont have a good answer how to open the door with this problem.
Jan 24, 2008 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
