The oven runs about 50 degrees hoter than is sseet on the dial
SOURCE: Calibration
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
SOURCE: Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
SOURCE: Viking DED0530TSS oven calibration?
With a small screw driver and a steady hand. Set the knob to the temp u want then pull knob off. Inside the stem there is a little screw. Try and regulate it slowly also allow it enough time to reach the desired temp. Good luck.
