Question about Dell Televison & Video
W2606c lcd tv
When turned on no pictureor sound.
    President:
  • 846 Answers
Nothing appears on my LCD TV display
1 Ensure the LCD TV display is turned on.
2 Verify that all the cables are properly connected to the LCD TV
display, including the power cable.
3 Check to see if there is a blue or amber light on the lower,
right-hand corner of the LCD TV display. A blue light indicates
the LCD TV display is on. An amber light means the LCD TV
display is in power save mode.
4 Ensure the proper source is selected in the Input Select menu.
See "Input Select Menu" on page 24 for more information.
5 Reconnect any devices that are currently connected to the LCD
TV display. If you are using multiple devices, connect and test
one device at a time.
6 Connect another device that you know is working properly.
7 Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset.
Problem Possible Solution No sound
1 Ensure mute is not turned on. Pressing the Mute button on
the remote control turns the mute function on and off.
2 If only certain LCD TV channels do not have sound, then you
need to correct the Input Select menu in the TV Menu (see
"Input Select Menu" on page 24).
3 Verify that the audio cables are firmly connected to both the
audio input connectors on your LCD TV display and audio
output connectors on your devices. Ensure that the cable colors
match the connectors colors.
4 Also, ensure that the audio cables are connected to the same
row as the video cables. See "About Your LCD TV Display" on
page 5 for the location of the connectors.
5 Reconnect the device using the same type of connector. For
example, if you are using the composite connector on the
bottom, try connecting the device to the composite connector
on the side of the LCD TV display. See "About Your LCD TV
Display" on page 5 for the location of the connectors.
After you connect the device, change the input source in the TV
Menu. See "Input Select Menu" on page 24 for more
information.
6 Connect the device using a different connector. For example,
if you are experiencing the problem using a composite
connector, try using the component connector.
NOTE: To connect to a different connector, you need the
appropriate cables for that connector. See your device
documentation for a list of supported connections.
information.
7 Test the device on a different TV.
Posted on Jan 05, 2009
  • Quickfx PC Repair Jan 05, 2009
    Let me know if this helps or not, maybe youll get some more info after trying these things. Hope we can figure this out, dantechcom
My Dell LCD Model W2606C will not process a cable TV signal suddenly. All else seems normal. Any idea what could cause that to happen.
Welcome to Fixya. If your tv cant process a TV signal most likely you are on the wrong input. We can check if the input that has been set to the LCD is correct. Can you please provide if the LCD is connected to a cable box and what cable is connect from the box to the LCD.
Thanks
Jun 22, 2011 | Computers & Internet
Looking to replace my Power Source to my Dell W2606C. No power anymore . Looking for an after market part if it exists? someone please help..
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board.These two sources,u have the best chances.Dell dose not make many sell in tvs.Dell LCD monitors yes.
May 18, 2010 | Dell W2606C 26 in. HD-Ready LCD Television
Truns off by self
Check sleep timers make sure you have non set in the menu or setup if not the timer inside is gone south on you and will need repair.
Apr 23, 2009 | Dell W2606C 26 in. HD-Ready LCD Television
I have a dell w2606c lcd tv no picture or sound when turned on what can be wrong
when u turn the unit on, if u get a flashing yellow light, its your mainboard. otherwise, its your powerboard, its burnt out. must replace.
Jan 05, 2009 | Dell W2606C 26 in. HD-Ready LCD Television
No picture no sound
main board needs replaced with the proper updated firmware version. look on ebay for replacement. I saw them listed.
Dell W2606C intermittent power issues
yes there is, however you should check the voltages on ur power board. look at the top right for sticker with va, vset, ve, etc.. each one has a voltage next to it in VDC. ground the neg lead, and test each lead with the red tip. if mismatches in 2 or more settings, it is the power board. otherwise, its the main board. remove the board, and ebay the board id stamp for a replacement. should resolve concerns.
Dec 20, 2008 | Dell W2606C 26 in. HD-Ready LCD Television
W2606c picture scrambled
Um...well when mine does that i unplug it and hold the power button for ten seconds and then plug it back in. Always works for me ;-) hope it works for u.
Aug 19, 2008 | Dell W2606C 26 in. HD-Ready LCD Television
Dell w2607c
Had same problem too with my w2006c. Died after 6 month, replaced, then died after 8 month !!  Patrick Québec Canada
May 08, 2008 | Dell W2606C 26 in. HD-Ready LCD Television
Televison & Video Logo
504 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
