Question about Boston Acoustics MCS 130 LCR Main / Stereo Speaker
Boston acoustic mcs 130 subwoofer parts - Boston Acoustics MCS 130 LCR Main / Stereo Speaker
4 Suggested Answers
lynchms
  • 93 Answers
SOURCE: how do i connect my boston acoustics pv800
You need to use the LINE LEVEL connection on the pv800 (usually a rca type connector cable) and run this cable into the back of the HK 520 Subwoofer PRE-OUT connector, be sure the HK Receiver menu speaker set-up option is set to SUBWOOFER "YES"
Posted on Jun 12, 2010
  • 7 Answers
SOURCE: The amplifier module in my Boston Acoustic PV1000
Here is information from the factory repair company for this product.
For repairs that are out of warranty: The Boston Acoustics PV1000 has a $130 flat fee that covers parts and labor regardless of the problems you are having with the unit. Return shipping is figured (with your zip code) at the time of return and added to that fee.
When packaging the unit please include a detailed problem description and
full contact information (name, address, phone). For this particular model you can send in just the amplifier pcb, and keep the cabinet in your possession, (to save immensely on shipping)
Upon arrival here at LAS, your name first and last will become the RA and
future communication will be referenced by that name.
We will contact you for payment of $130 +return shipping. We accept Visa and Mastercard over the phone, or check or money order via mail. Turn around time is generally 3-5 days
after receipt of the unit.
If you have any questions or uncertainties don't hesitate to call the number below or respond to this email.
The address for return is:
LeMars Audio Service
1889 24th St SW
LeMars, IA 51031
712-546-1644 opt2
Posted on Dec 29, 2010
SOURCE: I have a TVee model 2 from Boston Acoustics
Hi jdmowen,
I see that you need help since you lost the hardware for setting up you TVee Model Two Speakers.
What hardware are we speaking of? check the links I have provided, one of the links will be the manual and the other links will be where you can get the parts that you might need.
Manual
Parts Boston Acoustic Website
Parts Reseller
Parts Other Resellers
I hope this will help.
send me a message if you need a specific part maybe we can get info for it.
mvincentc
Posted on Jul 04, 2011
How do you repair blown Boston Acoustics Subwoofer MCS Amp?
Most often this unit goes dead because of zener diode ZD3 shorting. It is a 18v zener. replace this and you should be back in business.
Feb 20, 2017 | Boston Acoustics Audio Players & Recorders
My mcs 90 speaker isn't putting out any sound. Swapped with another speaker to eliminate the chance of it being something other than the speaker.
Use A =DMM check the speakers omhs.if the ohms are not correct or very close to it speaker is bad is there any rubbing sound when you push down on the cone ..also indication of blown coil.
Oct 19, 2014 | Boston Acoustics SC95 6" x 9" Coaxial Car...
Subwoofer not working
There may be an internal fuse that's blown. I'd take it to a repair facility and have them check it. Could also have a bad connection inside. Good luck!
Feb 15, 2014 | Denon DHT-1513BA Home Theater System
Avr 1513 no signal to subwoofer
Check its speaker connections. Check the speaker using a dry cell. If it is found OK, check the sound settings. If you wish to get more details, check this link.
Mar 22, 2013 | Denon AVR-1513
Mcs 160 subwoofer no power
I had the same problem with my subwoofer unit. I found the zener diode ZD3 was fried. The pic below shows the diode and its clearly tagged ZD3. You need a multimeter to check this before you order anything. This diode should only transmit power in one direction. Its size and spec is 18v .5w zener diode. (that's 1/2 w) It's very inexpensive and the whole repair took about an hour. This is from a Boston Acoustics subwoofer MCS 160
Ok..the procedure is easy.
1) unplug the unit and bring it to a well lit work area.
2) remove the panel from the back and locate the board that is held to the panel by 4 screws and has the ZD3 diode. The pic below shows the diode at the end of my test lead. Note the direction of this part and reinstall the new one in the same direction. Its a simple de-solder and re-solder project. I elevated the new diode about 1/8 " from the board with a small strip of copper. This acted as a heat sink during the soldering and elevated the part above the board to help it dissipate heat later when in use.
3) re-install the board and plug in all the connections.
4) this worked for me and I'm enjoying my sound system again!..good luck0482b949-8492-43a6-91df-0fb2f0e6888b.jpg
Jul 24, 2012 | Denon Audio Players & Recorders
Zd 3 diode value on boston acoustic soundware xs 5.1 subwoofer
Hello
Did you find the value of ZD3.
I need it too.
I have the same problem, and I take out the ZD3 and the subwoofer works. But I'm not sure that is correct. I think it may be the circuit stand by.
May 27, 2012 | Boston Acoustics SoundWare XS 5.1 Speaker...
I have a Boston MCS130 surround sound system, have had for about 2 yrs. Was woken up during the night with the subwoofer making feedback noise. Had to turn off to keep from making noise. Have checked...
mine had the same problem until it completely quit. unplug the sub and turn it over, press gently on the speaker cone, does it move freely, or do you hear a sort of scrapping noise? if it moves freely with no noise, its a dif problem than mine. if you do hear the scrapping noise, then theres a short in the voice coil, from what ive read you have to replace the driver (actual speaker part), its basically blown
Feb 06, 2011 | Boston Acoustics MCS 130 LCR Main / Stereo...
How can I take apart my Boston Acoustice MCS 130 speaker. It was dropped and now does not work. I want to look in it and see if I can repair it.
there should be panels or rubber feet with screws underneath. or the speaker part can come off. that would be where the mesh would be or holes for the sound to escape.
Dec 12, 2010 | Boston Acoustics Audio Players & Recorders
The amplifier module in my Boston Acoustic PV1000 Subwoofer has fried itself. According to the New Zealand importer, a new module is not available. Any ideas? Would there be a wiring diagram avail? Maybe I...
1889 24th St SW
LeMars, IA 51031
712-546-1644 opt2
Nov 14, 2009 | Boston Acoustics PV1000 Subwoofer
Boston Acoustics MCS 130 LCR Main / Stereo Speaker Logo
474 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
