Question about HP LaserJet 4345mfp Printer
HP m3035 MFP send rfu upgrade - HP LaserJet 4345mfp Printer
hansola
  • 279 Answers
SOURCE: How do i scan on HP LaserJet M3035 MFP from
Assuming your scanner is installed already, what you need to do is log into Windows Photo Gallery (Vista) and click on FILE at the top left. When the drop down bar engages, you should look for IMPORT FROM CAMERA OR SCANNER and click it. Then a new window will open up and you'll have to pick your device (HP Laserjet M3035). At this point check your settings, and make sure your scan is ready, then click on either PREVIEW or SCAN. Then when it is done scanning, you will have to go to the folder you saved it in to view it. (Xp Similar)
Hope this helps.
Posted on Jun 07, 2010
SOURCE: Hi I have an HP CLJ CP3505 it has stopped working
Hi I have an HP CLJ CP3505 it has stopped working and is asking me for a Send RFU Upgrade? Does anyone please know what to do?
Posted on Aug 09, 2010
seeker5211
  • 1089 Answers
SOURCE: INFLATE FAILURE DOWNLOAD FILE NOW SEND RFU
Were you upgrading the firmware when this happened?
Try it again. If it fails again try a NVRAM reset. Download the firmware and try installing it again. If it still fails, you need to replace the formatter.
Posted on Oct 25, 2010
  • 1751 Answers
SOURCE: downl file now SEND RFU
Hi
my friend your memory card is not working
you need to replace memory on printer
Posted on Nov 25, 2010
SOURCE: Downld file now SEND RFU UPGRADE ON
install printer Driver
change print port to "Virtual printer port for usb"
use usb line
down load the right firmware .rfu file
in CMD mode,type:
copy /b firmwarefilename.rfu \\pc name\printer name
waitting
it will be down
good luck!
Posted on Dec 11, 2010
From computer How can i scan document from HP LaserJet M3035 MFP
From the search I did that printer is not an all in one and does not hacv a scanner function
Feb 13, 2016 | HP Office Equipment & Supplies
Printer display error99.07.20 upgrade
99.00.07 Upgrade not performed error reading upgrade
Description
A remote firmware upgrade (RFU) was not performed.
Unexpected read error when reading rest of header.
Recommended action
1. Download the RFU file and attempt the upgrade again.
2. If the error persists, replace the hard disk.
99.XX.YY
Description
Firmware installation error
Recommended action
Reload the firmware.
Basically you should try to reflash the firmware. If that doesnt work then you may have bricked your printer and shoudl consider warranty support or replacement. Good luck!
Dec 02, 2015 | HP LaserJet Enterprise 500 Color MFP...
La impresora 4345mfp se bloquea y nose como hacer la actualizacion del firdware.
Upgrading the firmware
The MFP has remote firmware update (RFU) capability. Use the information in this section to
upgrade the MFP firmware. The overall process involves the following steps:
1 Determine the current level of firmware that is installed on the MFP.
2 Go to the HP Web site and find out whether a firmware update is available. If an update is
available, download the latest firmware to your computer.
3 Transfer the new firmware from your computer to the MFP.
Determining the current level of firmware
To determine the current level of firmware, view the configuration information on the MFP control panel. To view the configuration information, follow these instructions.
1 Press MENU.
2 Touch INFORMATION.
3 Touch PRINT CONFIGURATION. The configuration page prints.
4 The firmware datecode is listed in the section called Device Information. The firmware
datecode has this format: YYYYMMDD XX.XXX.X. The first string of numbers is the date, where
YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20040225 represents February 25, 2004.
Downloading the new firmware from the HP Web site
To find the most recent firmware upgrade for the MFP, go to www.hp.com/go/lj4345mfp_software.
This page provides instructions for downloading the new firmware version.
Transferring the new firmware to the MFP
Use one of the following methods to update the firmware.
Using FTP to upgrade the firmware on a network connection
NOTE The MFP can receive an .RFU file update as long as it is in a "ready" state.
The elapsed time for an update depends on the I/O transfer time, as well as the time that it takes for the MFP to reinitialize. The I/O transfer time depends on a number of things, including the speed of the host computer that is sending the update. If the remote firmware update process is interrupted before the firmware is downloaded (while Receiving Upgrade appears on the control-panel display), the firmware file must be sent again. If power is lost during the flash DIMM update (while the Performing Upgrade message appears on the control-panel display), the update is interrupted and the message Resend Upgrade appears (in English only) on the control-panel display. In this case, you must send the upgrade by using the parallel port. Finally, any jobs that are ahead of the RFU job in the queue are completed before the update is processed.
Follow these instructions to perform the upgrade by using FTP.
To upgrade the firmware on a network connection by using FTP
1 Take note of the IP address on the HP Jetdirect page. The HP Jetdirect page is the second page that prints when you print the configuration page.
NOTE Before upgrading the firmware, make sure that the MFP is not in Sleep mode.
Also make sure that any error messages are cleared from the control-panel display.
2 Open an MS-DOS command prompt on your computer.
3 Type: ftp <TCP/IP ADDRESS>. For example, if the TCP/IP address is 192.168.0.90, type ftp
192.168.0.90.
4 Press Enter on the keyboard.
5 When prompted for the user name, press Enter.
6 When prompted for the password, press Enter.
7 Type bin at the command prompt.
8 Press Enter. The message 200 Types set to I, Using binary mode to transfer files appears in
the command window.
9 Type put <filename> where <filename> is the name of the .RFU file that was downloaded
from the Web, including the path. For example, type put C:\LJ\4345FW.RFU, and then press
Enter.
NOTE If the file name or path includes a space, you must enclose the file name or path
in quotation marks. For example, type put "C:\MY DOCUMENTS\LJ\4345FW.RFU"
The following series of messages appears in the command window:
? 200 PORT command successful
? 150 Opening BINARY mode data connection
? 226 Ready
? 226 Processing Job
? 226 Transfer complete
Then, a message that contains the transfer-speed information appears.
10 The download process begins and the firmware is updated on the MFP. This can take
approximately five minutes. Let the process finish without further interaction with the MFP or
computer.
NOTE The MFP automatically turns off and then on again after processing the upgrade.
11 At the command prompt, type: bye to exit the ftp command.
12 At the command prompt, type: exit to return to the Windows interface.
Using MS-DOS commands to upgrade the firmware
To update the firmware by using a network connection, follow these instructions.
1 From a command prompt or in an MS-DOS window, type the following: copy /B <FILENAME>
\\<COMPUTERNAME>\<SHARENAME>, where <FILENAME> is the name of the .RFU file
(including the path), <COMPUTERNAME> is the name of the computer from which the MFP is
being shared, and <SHARENAME> is the MFP share name. For example: C:\>copy /b C:
\9200fW.RFU \\YOUR_SERVER\YOUR_COMPUTER.
in quotation marks. For example, type: C:\>copy /b "C:\MY DOCUMENTS\3500FW.RFU" \\YOUR_SERVER\YOUR_COMPUTER.
2 Press Enter on the keyboard. The control panel shows a message that indicates the progress of the firmware upgrade. At the end of the upgrade process, the control panel shows the Ready
message . The message 1 file(s) copied appears on the computer screen.
Jul 15, 2011 | HP LaserJet 4345mfp Printer
Printer hp m3035xs giving this error"download file
The only, and easiest way I have found to solve this is to replace the formatter PCA.
Dec 16, 2010 | HP LaserJet M3035xs MFP All-In-One Printer
Downld file now SEND RFU UPGRADE ON USB DEV PORT
use usb line
in CMD mode,type:
waitting
it will be down
good luck!
Nov 26, 2010 | HP LaserJet 4345mfp Printer
Bran new HP m3035 MFP.
Try replacing the toner if you have another one, even old one should be ok to test, if not the look at the toner drum and see if there is any marks on it.
Jul 09, 2010 | HP LaserJet M3035 MFP Printer
49 2f81- error
From the service manual:
A critical firmware error has occurred. This type of error can be caused by invalid print commands, corrupt data, or invalid
operations. In some instances, electrical noise in the cable can corrupt data during transmission to the MFP. Other causes include poor quality parallel cables, poor connections, or specific software programs.
To fix:
1 Turn the MFP off, and then turn the
MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs, disconnect all of the cables that
connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
To upgrade firmware:
The MFP has remote firmware update (RFU) capability. Use the information in this section to upgrade the MFP firmware. The overall process involves the following steps:
2 Go to the HP Web site and find out whether a firmware update is available. If an update is available, download the latest firmware to your computer.
1 Press MENU.
4 The firmware datecode is listed in the section called Device Information. The firmware datecode has this format: YYYYMMDD XX.XXX.X. The first string of numbers is the date, where YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20040225 represents February 25, 2004.
To find the most recent firmware upgrade for the MFP, go to www.hp.com/go/lj4345mfp_software. This page provides instructions for downloading the new firmware version.
This procedure requires that you install HP Web Jetadmin Version 7.0 or later on the computer. See Using HP Web Jetadmin software. Complete the following steps to update a single device through HP Web Jetadmin after downloading the .RFU file from the HP Web site.
1 Start HP Web Jetadmin.
2 Open the Device Management folder in the drop-down list in the Navigation panel. Navigate to the Device Lists folder.
3 Expand the Device Lists folder and select All Devices. Locate the MFP in the list of devices, and then click to select it.
If you need to upgrade the firmware for multiple HP LaserJet 4345mfps, select all of them by pressing the Ctrl key as you click the name of each MFP.
4 Locate the drop-down box for Device Tools in the upper-right corner of the window. Select Update Printer Firmware from the action list.
5 If the name of the .RFU file is not listed in the All Available images box, click Browse in the Upload New Firmware Image dialog box and navigate to the location of the .RFU file that you
downloaded from the Web at the start of this procedure. If the filename is listed, select it.
6 Click Upload to move the .RFU file from your hard drive to the HP Web Jetadmin server. After the upload is complete, the browser window refreshes.
7 Select the .RFU file from the Printer Firmware Update drop-down menu.
8 Click Update Firmware. HP Web Jetadmin sends the selected .RFU file to the MFP. The control panel shows messages that indicate the progress of the upgrade. At the end of the upgrade
process, the control panel shows the Ready message.
HP Web Jetadmin is a Web-based software solution for remotely installing, monitoring, and troubleshooting network-connected peripherals. The intuitive browser interface simplifies crossplatform
management of a wide range of devices, including HP and non-HP printers. Management is proactive, allowing network administrators the ability to resolve printer issues before users are affected. Download this free, enhanced-management software at www.hp.com/go/webjetadmin_software.
To obtain plug-ins to HP Web Jetadmin, click plug-ins, and then click the download link that is next to the name of the plug-in that you want. The HP Web Jetadmin software can automatically notify
you when new plug-ins are available. On the Product Update page, follow the directions to automatically connect to the HP Web site.
If installed on a host server, HP Web Jetadmin is available to any client through a supported Web browser, such as Microsoft Internet Explorer 6.0 for Windows or Netscape Navigator 7.1 for Linux. Browse to the HP Web Jetadmin host.
Replacing the formatter
1 Slide the formatter cover toward the left side of the MFP and remove it.
2 Remove two thumb screws (callout 1).
3 Slide the formatter toward the left side of the MFP, and then remove it.
NOTE Dislodging the formatter might require considerable force.
I hope all this information helps! Thanks and please take a moment to give this solution a rating of fixya.
Feb 17, 2009 | HP LaserJet 4345mfp Printer
HP LaserJet 4345mfp Printer Logo
107 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
