Question about Dishwashers
My Flavel FDW45 dishwasher keeps filling with water when its switched off?
It seems to be coming in from a filter hole inside the machine which is continuously seeping water.
Rotu
  • 175 Answers
SOURCE: washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Posted on Nov 23, 2006
SOURCE: figidare dishwasher
I have a diswasher problem
type GSIP 6598 from Bauknecht
The reset button keeps blinking
what can I do?
Regards
Annick
Posted on Apr 07, 2008
SOURCE: dishwasher keeps running
I have a similar problem. On the main program the dishwasher starts but stops during the cycle leaving the motor running. I have had the problem before and called a repair man out, he traced the fault to a broken wire leading from the control unit / timer to somewhere under the machine. The break was located where the wires went under the door, I would tend to suggest that this fault has re occurred and your fault may be the same.
Posted on Jun 10, 2008
  • 409 Answers
SOURCE: bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
Posted on Sep 25, 2008
futureloginn
  • 734 Answers
SOURCE: Kenmore Dishwasher 665.1671590 Leaking water at fill funnel.
Step1
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Step
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Step
Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
Step
5
Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Posted on Dec 02, 2008
The machine will not refill, I did the water softner yesterday and have been having problems since. Now the machine will not fill at all and turns itself off.
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Dishwashers
Machine is not filling and making a hissing noise
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Feb 13, 2011 | Bosch 24 in. SHX46A05 Stainless Steel...
Dishwasher leaks-can't seem to pin it down to a certain situation-sometimes it leaks, sometimes it doesn't. Also, the filter hole seems to have more standing water than normal
Do you know where it pools the most ? Most leaks occur around the pump housing and the door. over filling with water can cause seepage to a full blown flood. Check your water level switch.
Oct 10, 2010 | Kenmore Dishwashers
KitchenAId KUDK02CR does not fill in water . Neither switch nor motor sound coming out of the unit
1.Check main water inlet.
2. Check filter located near the machine body hose pipe inlet.
If these are OK Solinoid valve inside the machine to be checked for functioning.
Mar 29, 2010 | Dishwashers
Dishwasher is not completing the cycle, and water remains in the tub. I've cleaned the filter and that doesn't seem to solve the problem.
check you float switch at the back to see if it is sticking ,and it should always have at least an inch of water in it to keep the motor seal wet or it will dry up and leak creating another problem
Dec 25, 2009 | Dishwashers
My dishwasher won't fill with water. I've checked the float assembly inside the washer and it seems to work fine. I've been looking for the float switch and water inlet valve inside the bottom panel in...
if hot or both cold and hot fill try to switch the pipes
if not filling it may be a problem with program and or filter blocked
check also the pump
did you check the water is on as sometimes people forget to swith it on
if the motor has carbons as in the washing machine and if they are worn the water will not fill or better the motor is not going to turn and will not pump in water
as it is possible the pump may not work
this will make a sound like emptiness and with air in it
Sep 27, 2009 | Dishwashers
We lost electricity very briefly today which caused the dishwasher, washing, drying, clean buttons to blink when the electricity came back on. I opened the door to do a load of dishes hours after the...
it seems unit fill valve is stuck open and water is coming in even when machine is off.fill valve opens up only when u start the unit.2 chks this u can open the door and look at the hole inside from where water comes in.if water is coming in with dooe open then 4 sure valve is bad and needs 2 be replaced.
Aug 11, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Bosch 9925 - water comes in and drains - but not enough pressure to make water comes out of rotating arm more than about 6 inches. Do I need a new pump? I cleaned all holes and filters. How do i access...
DO YOU HAVE AN ISSUE WITH HARD WATER IF SO TAKE 1 GALLON OF VINEGAR START MACHINE LET MACHINE DRAIN THEN WHEN IT STOPS DRAINING OPEN DOOR AND FILL WITH VINEGAR THIS WILL PUT ADIQUATE AMOUNT OF LIQUID IN MACHINE TO RUN
DON
262-893-4840
Jul 20, 2009 | Bosch Dishwashers
Bosch Exxcel Auto option
There should be a float switch inside the dishwasher sometimes these get hung up on the full position which in turn keeps the solenoid from allowing the water to come on. remove the bottom rack and check to see if this is the case. Dislodging the float should fix the problem. If not listen to see if the solonoid Clicks when you turn the cycle to fill position if not it could be either solonoid or the timer. if you hear click and still no water check strainer in water line could be clogged or water is turned off some where.
Oct 19, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Check water light comes on
is your appliance a miele? normally this is causeb by blockages ( bit of plastic or paper wrapping/ milk bottle tops etc) inside the impeller of the main circulating pump (motor) restricting the flow of water the only solution is to fisically remuve the obstraction by temporarelly remuving the motor and cleaning not a simple job
Jul 25, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
