Lamp Timer Reset procedure Panasonic Projector PT-L759E
Need instructions to reset the lamp timer to zero.
Manual and service manual don't show how to do this - Panasonic can't help either.
Currently lamp turns on - is very bright but screen display says it has reached 0 hours and will turn off in 5 mins. I can turn unit on off and into standby and can shift cooling fan to high speed by pressing the < > keys.
Apparently, I can not use any button on the unit until the timer is reset using a combination of the buttons.
HELP PLEASE
  • just-ice Jan 05, 2009
    Found Solution in HK. PWR on STnBY - Press INPUT and then press PWR for 5 secs+. Screen comes on as Blue with the word FOCUS and cnr marks.
    MENU Bt'n will now work and timer is reset to 0 hrs.
    Thanks for looking and thanks for trying and thank to Panasonic HK -
  • just-ice Mar 10, 2009
    Thanks guys fpr trying - but I had already posted a comment on Jan 05 saying I had found out how to do it.
    Scholar:
  • 56 Answers
Greetings!
It's been a while since I did one of these, but if I remember correctly:
- Turn on the set
- Push volume down on remote and at the same time....
- Push Split on the remote and hold both for 5 seconds
This should do it. The display should reset to "0".
Rob
Posted on Mar 09, 2009
  • wing_guy_196 Mar 09, 2009
    Forgot to mention that on a few of these the sequence:
    - Must be performed AFTER the reset lamp message is cleared off the screen
    and/or
    The volume button on the set must be used instead of the volume button on the remote
    Sorry if there was any confusion.
The only confusion I have is my remote don't have pip or split button so I press volume - on tv and???? on remote GRRRRRRRR.
Posted on Sep 05, 2010
  • 928 Answers
Since you did not indicate the exact model number ill give you a generic solution. can you try the steps below.
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
Posted on Jan 05, 2009
How to reset the hour meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic PT-52LCX16
How to reset the lamp meter on a panasonic pt-52lcx16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
Can't reset lamp timer after lamp replacement on Panasonic PT-AE40000
I have a Panasonic PT-AE4000U and could not reset the timer after replacing the bulb with a, non-Panasonic branded bulb. Calls to tech support were not very helpful. It was another bad customer service experience. Through troubleshooting it myself, I discovered the solution was simply to unplug EVERYTHING (serial cable, hdmi cables, etc.) from the device, power it off and back on. Follow the procedure in the manual, the timer immediately reset!!
Feb 11, 2012 | Panasonic Office Equipment & Supplies
Reset timer panasonic d6000
Hello!
Have you bought bare lamp? Probably, yes. And not from "Panasonic"? yes. The timer's reset procedure is different for every model of Panasonic, including TVs. when you buy lamp with housing from Panasonic, they will give you the directions, how to. If it's "aftermarket", nope!
http://www.manualowl.com/m/Panasonic/PT-D5600U/Manual/52045
that's where you will find the procedure. it's quite complicated, page 45.
follow the directions.
good luck,
Alex.
Dec 27, 2011 | Panasonic PT-D5600U DLP Projector
I have the Panasonic pt -l759u multimedia projector the lamp timer has reached zero i need to know how to reset it i currently cant even get to the menu
You cannot reset the lamp timer. This is an indication that your lamp is at the end of it's life and must be replaced. Contact Panasonic for a replacement.
Feb 27, 2011 | Panasonic PT L759U Multimedia Projector
Reset lamp counter on my panasonic pt-52lcx16k
I can help you reset the lamp timer for your Panasonic PT-52LCX16 Projection HDTV.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Mar 10, 2010 | Panasonic TYLA1001 TYLA1001 Projector Lamp
PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
May 25, 2008 | Panasonic PT-F100NTU LCD Projector
3,519 people viewed this question
jasbo
jasbo
