Question about Pool & Spa
I have a 1991 J1000 Jamestown pellet heater. I have read the start up manuel but it keeps dropping the pellets and they just keep piling up n running over the sides. Then I have flame all over the box
After reading the start up manual and following the directions everything works fine for about the first 1/2 hr. then the pellet box fills to overflowing n the burning pellets fall all around the small box and into cleanout area and everything is burning. It is like once the box fills n they burn the more that drop have no place to go but around it.
  • Dave
    Dave Dec 23, 2013
    Open the air to max-the slide on the right side and see if this makes any difference, I find that if I keep the air low that the combustion can't keep up with the fuel. Just a thought.
My jamestown was doing the same thing. a thorough cleaning of the pellet stove solved this. Look in the manual under Cleaning and maintenance.
Posted on Dec 15, 2013
  • 10865 Answers
SOURCE: stove trips breaker
Begin by unplugging the pellet stove and using an extension cord, plug the pellet stove into a different circuit, with a different breaker. It is possible that the breaker itself is faulty. If you prove that the problem is in the breaker, replace it. If the new circuit also trips, then you will have to assume that the stove cord, or the stove mechanism is faulty and either repair or replace it. good luck with it. let me know.
please mark this answer as a fixya! ty.
Posted on Mar 11, 2009
protek480
  • 1714 Answers
SOURCE: purchased a used earth stove mp240 pellet stove
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
Posted on Jul 01, 2009
protek480
  • 1714 Answers
SOURCE: AUGER IN PELLET STOVE NOT CONSISTANTLY TURNING
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
protek480
  • 1714 Answers
SOURCE: auger on pellet stove doesn't turn
The thermostat inside on the back of the combustion chamber has a manual rest that needs to be pushed and reset.
Posted on Jul 08, 2009
  • 279 Answers
SOURCE: combustion fan isn't running
Ther is a guy names Murphy that it resposible for that. Go back through the steps you used to change the auger motor and see if maybe there was a wire left out or if the combustion motor is also out. What caused the outage? If a voltage spike, it could have taken them both out. The only other thing I can think of is a main switch somewhere. Good luck...Lee
Posted on Nov 16, 2009
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
What is causing the ready light to flash red twice when I try to light my pellet stove
[PDF]INSTALLATION AND OPERATION MANUAL - Wood Pellet...
woodpelletheat.com/WinslowManual.pdf
by P Stoves - ‎Related articles
Please read this entire manual before installation and use of this pellet fuel-burning room .... FLY ASH BUILD-UP: For all wood pellet fuel-burning heaters, the combustion ......Ready Light - lights up when stove is ready to operate. Igniting Light ..
Sep 27, 2015 | Pool & Spa
We have a heilsa pellet stove model#QCPS-28000 ,its dropping pellets to fast ,how do I adjust the feed.
  1. SET THE AIR INLET DAMPERS
It is not possible for the manufacture to factory set your stove to work properly without some adjustments. The dampers help control the amount of airflow supplied for combustion.
A damper PUSHED IN all the way, maximizes concentrated air flow to the burn pot. This will maintain a robust fire.
The Auger timing is designed to be run, in most conditions, with the dampers closed.
In some areas/conditions, it mybe necessary to adjust the damper open slighty in order to slow down the flame and allow the pellets to keep pace with the rate of burn. This should be monitored closely to ensure you have the propoer feed rate established. If dampers are opened too much, the rate of burn will be very slow and the pellets will build up.
This setting needs to be fine tuned to according to your location and elevation. It is recommended that you start with the dampers pushed in to start.
Feb 20, 2013 | Northern Tool and Equipment Pellet Stove -...
Je cherche le manuel pour operation du poele a granules Jamestown Pellet stove
Voici un lien où vous pouvez trouver des Manula du propriétaire de votre poêle à granules Jamestown. Cliquez sur l'onglet Support et vous verrez les manuels qui sont availabble. Vous aurez besoin du Modèle de Numbre à vous de choisir la bonne.
http://www.jamestownpelletstoves.ca/
J'espère que cela vous a aidé et merci d'avoir choisi FixYa.
Sep 20, 2011 | Heating & Cooling
Our napoleon stove barely heats the room it is in and it is new first year used,,
Try this....before starting the stove, place a handful of pellets into the burn pot. Start stove with feed rate about 2-3. Let the pellets ignite fully, then turn pellet rate to about 5, less then max. Let a good flame develop for 5 minutes or so, then turn on the fan. I set the fan at about 3-4 as advised by the tech. Reduce feed rate to about 4. I keep my damper on 2 1/2 to 3 to supply air intake. Napoleon is not the greatest stove, and I'm having an issue with mine after 3 years, but hopefully this helps. It will never give the heat of a wood stove, but get a strong fire going first, then tune it down after the room gets warm.
Jan 16, 2011 | Napoleon Auburn Pellet Stove Heater
Stove trips breaker
Mar 11, 2009 | Napoleon Auburn Pellet Stove Heater
I have a 1985 Whitfield pellet stove that has problems
Check the basics first fuel (supply and quality of) Air flow and ventilation. If nothing obvious google {whitfield pellet problem]. My guess is that something is plugged up.
Mar 03, 2009 | Napoleon Auburn Pellet Stove Heater
Pellet stove
i have a goodman furnace 1 yaer old and the burnner mainly late at night keeps cycaling on and of no codes present
Oct 21, 2008 | Heating & Cooling
Pool & Spa Logo
453 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
