Question about Pentax ME Super 35mm SLR Camera
The film advance lever on my ricoh kr-5 broke
The film advance lever physically broke. the plastic on the top broke. the arm is loose and hangs down a bit, but is still attached. it will advance often, but not always. can i replace this? where can i buy a new part? can i replace it myself?
    Problem Solver:
  • 17 Answers
Plenty of these cameras are on ebay sold for parts
Posted on Mar 07, 2009
How do I remove film from the camera?
wow a film camera!!!! , didn't know any of these still existed (less than 60mm) anyways you'll need to rewind the film back into housing , this is done with tiny crank on top of film advance wheel (don't go to fast !!!) slow and steady wins the race!! you'll also need to activate the shutter release lever (around the crank someplace) DO NOT OPEN CAMMERA TILL YOU HAVE REWINDED ALL THE FILM INTO HOUSING !!!!!!!!!!!! it will ruin all the photos
Dec 01, 2015 | Ricoh KR-5 SUPER II 35mm SLR Camera
My advance lever is stuck o my Ricoh camera. I had a roll of film get stripped in it and took it out in the dark room and developed it but now even with no film in it the lever won't advance. I've looked...
Your camera is in cocked position with shutter fully cocked and that is why you cannot advance the film advance lever. Set the shutter to x position ( on your shutter speed dial on the right hand side and top of your camera ) . The shutter should release and then you should be able to advance the film advance lever.
Oct 18, 2013 | Ricoh KR-30SP 35mm SLR Camera
My Ricoh kr-5sv's rewind button is still pressed in after i rewound andd took out the film. how do i get it to pop out again?
The rewind button will usually pop out once you turn your film advance lever. In order for you to be completely familiar with your camera, here's a link to a user's guide in pdf format:
http://www.butkus.org/chinon/ricoh/ricoh_kr-5sv/ricoh_kr-5sv.htm
Hope this helps.
Mar 25, 2011 | Ricoh KR-5SV 35mm SLR Camera
Film advance lever will not advance
Sometimes film jamming in the film can cause the shutter to be very difficult to **** . I had an Pentax years ago that was similar in design to the Ricoh and loved it.
Using a little, but NOT a lot more force may help you to complete the cocking action. Other than that I would remove the film and blow out the mechanism with compressed air. Don't know if this will definitely solve the issue. But hopefully it will.
Best Regards, Mark
Jan 23, 2011 | Ricoh KR-30SP 35mm SLR Camera
My cameras advance lever will not spring back and allow the film to move to the next frame. How do i fix it?
push the film release on the bottom of the camera and try to continue forward then. If you are trying to get 27 pictures on a 24 exp. roll you may have advanced your film so far that it is stuck on the piece of tape that attaches the film to the spool. Take only 24 pictures.
May 20, 2010 | Ricoh KR-5 SUPER II 35mm SLR Camera
Film advance lever goes back and forth putting no tension or movement inside the camera to advance the film. Was working fine, then after taking my last shot, lever is just sort of loose., couldnt load new...
first make sure the rewind button is not stuck down. open the back door and rotate the advance sprocket back and forth to release the button. if that did not work take the bottom cover off and check the white plastic gear near the take up shaft. if that gear broke it will have to be repaired by a camera repair person.
there are no new parts for this model so get a cost estimate first.
Jul 07, 2009 | Minolta X-370S 35mm SLR Camera
Sears ks-2/ricoh xr-7 film advance and shutter release problem
You probably need to take the camera in for repair. It sounds like the film transport is not connected to the shutter/mirror cage ***'y.
Jan 26, 2009 | Ricoh KR-5 SUPER II 35mm SLR Camera
Ricoh XR-10 35mm SLR camera
stevdan,
take the screws off the bottom cover. there is a small lever pointing toward the front of camera with a black screw on it. gently move it to the left, this will release the lock lever. Now advance the lever and the shutter should fire. if not, it is not repairable. no parts
Sep 12, 2008 | Ricoh XR-10M 35mm SLR Camera
I dont know how to put the film in the ricoh kr-30sp
Please go to this link and scroll down to number 6 under the picture of the manual. It says"insert film". Click on that link and follow instructions! Thank you for using Fix Ya!
http://www.butkus.org/chinon/ricoh/kr-30sp/kr-30sp.htm
Aug 16, 2008 | Ricoh Cameras
The film won't advance
Look on the shutter release button, there is a lock switch on bottom of the button. turn it toward the prism.
Jul 08, 2008 | Ricoh KR-5 SUPER II 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
211 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
