Question about Lexmark C935dn Laser Printer
940.00 service mpf failure
I bought a c935dn second hand, and when I start it come this message "940.00 service MPF Failure" what can I do? what does it mean? I fuond anytingh abuot this error tnk martina
5 Suggested Answers
  • 10 Answers
SOURCE: Lexmark x642e MPF Reset maintenance
Power printer off. When printer is powered off, hold down the check button and the right arrow button and hold these down while powering printer back on. Hold the buttons down for 10-20sec....
When printer is finished you are at the config menu. Hit down once, and you will see reset maint counter. Hit menu twice... and you will see resetting...
Then hit back twice to get to the main menu and use your up/down arrows until you see exit config menu. Hit enter and it will reboot printer back to the regular menu.
Posted on Mar 11, 2009
ichtuscheeky
SOURCE: Lexmark x642e MPF Reset maintenance counter
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Posted on Sep 11, 2009
ArgusFixer
  • 51 Answers
SOURCE: My Lexmark T620 is giving me the following
replace the engine board...local service center that works on Lexmarks can change in under an hour.
Posted on Feb 17, 2010
  • 78 Answers
SOURCE: WHAT DOES 954 SERVICE, MVRAM FAILURE MEAN?
error 954 Indicates the NVRAM experienced a CRC failure.
Usual solution is to replace the engine board. (part number 99A1923)
Posted on Dec 31, 2010
When I go to print I get message load mpf 024-969
This error typically means that the Size of paper defined in the print job being sent from the application does not match the size of the paper the printer has set for the MPF. (in this printer, MPF = Manual Feed)
For example: If you send a Letter size job to the printer from, lets say MS-Word, but the printer currently has Legal size paper assigned in the MPF, this error will result.
Change the Windows printer to default settings
Apr 03, 2014 | Dell 3010cn Laser Printer
My dell 3130cn printer giving the message load mpf?
The MPF is your Manual Paper Feed.
If you specified specialty media like envelope or card stock, the printer expects that to draw from the MPF.
It is also possible that the MPF isn't sensing when paper is present and you will need to replace that sensor.
Whit
Item, Inc
Aug 10, 2010 | Dell 3100cn Laser Printer
MPF 024-969
Is the paper pushed all the way back into the MPF?
If yes, what type/size paper is your application sending?
If you try to print the internal Printer Settings report, does it print?
This error typically means that no paper is sensed in the MPF OR that the wrong type/size paper is in the tray. (MPF settings do not match job specs)
Oct 27, 2009 | Dell 3010cn Laser Printer
My Dell Color Laser Printer 5110 cn won't print. It keeps saying ''Load MPF Letter'' then ''Load MPF Plain'' then ''Load MPF 020-969
it's asking for paper in the manual Paper Feeder (MPF). Somewhere in your settings you have it printing to the MPF. Check the settings in the printer prefrences, the printer itself and the software you're using.
Cheers.
Sep 23, 2009 | Dell 5100cn Laser Printer
Mpf error
MPF is refering to Manual Paper Feed or bypass tray. This tray should fold down to enable loading of paper. It is mostlikely above tray 1.
Sep 15, 2009 | Laser 3115cn All-In-One Printer
Can't print. message load MPF won't go away
There is a print job waiting, either in the printer's memory or on your computer's memory. This print job is set to go to the Manual Paper Feed (MPF) which is accessible from the front of the printer by flipping down the little MPF door.
You can change settings for new print jobs, but once one job is submitted with "Please Print Me On The MPF" set, there's no way to change that job.
The easiest fix is to put some blank paper into the MPF and let it print out.
If it's spooled on the printer, you can turn the printer off and back on again to clear the job.
If it's spooled on your computer, you can view it by bringing up the Printer settings:
Start->Settings->Printers and Faxes
Find your 3100 and double-click on it.
Find the print job, select it and pick "Cancel" from the "Document" menu.
Mar 31, 2009 | Dell 3010cn Laser Printer
Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Sep 25, 2008 | Dell 5100cn Laser Printer
H.E.L.P!!!!!!!!!!!! PUHLEZE!!!!!
I had the same problem with mine. All you have to do is search these keywords: Virgin, MPF-1000, Driver, Download
When you search those keywords you should have quite a few options to download the drivers needed. Anyway, here are a few links to the software and/or drivers needed for you to be able to get your Virgin Pulse MPF-1000 working.
http://www.soft32.com/download_172979.html
http://www.versiontracker.com/dyn/moreinfo/win/39151
http://wareseeker.com/Utilities/virgin-mpf-1000-2.6.0.28.zip/1fbd18a12
http://pcdrivers.es/vp-mpf-1000-driver/download-2785.html (This download website is in Spanish for those of you that can only read/speak in Spanish)
http://www.drivers-software-download.org/virgin-mpf-1000-26028/
That will be all you need to do. Once you have installed the driver, plug the MP3 into the USB. Once you plug it in the autoplay should come up and just go from there. Please let me know if this solves your problem.
Thank You & God Bless,
MadHatter25
Sep 13, 2008 | Virgin Pulse VP-MPF-1000 (256 MB) MP3...
3010 dell color laser
Ok,
I've went around and around with the same problem (bug) and finally found a solution. Here is the deal. You have to exactly match the settings for the MPF tray in the aplication softwares to the MPF tray settings set from front panel on the printer.
I found this problem when trying to print on gloss paper. The MPF tray had to be set for "Coated 1 Side 2" in both the application and on the front of the printer.
Lets say I'm printing a Word Document. Go to file, print, select the Dell printer, then select properties, select paper tray, set paper source to MPF, set MPF settings to ""Coated 1 Side 2". Click OK.
Now do the printer setup. From the front panel on the printer.
Press Menu, press the down button to Tray Settings
Press center button to select.
Display now asks for paper type. Press center button.
Displays MPF. Press center button.
Push down button until you see Coat1 Side2
Push center button to select.
Press Menu to exit.
I only print on gloss so I have to set the MPF tray to Coated 1 Side 2. I was told this slows the feed and that is needed for coated papers. Now you could probably use another setting as long you set both the MPF tray in both the application and the control panel to match exactly.
Aug 19, 2008 | Dell 3000cn Color Laser Printer
My virgin pulse need driver
I can't find my software for my Virgin MPF 1000 where can I get it?
Sep 11, 2007 | Virgin Pulse VP-MPF-1000 (256 MB) MP3...
Lexmark C935dn Laser Printer Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
