Question about Dryers
Ctd80 hotpoint dryer error code f08 - Dryers
SOURCE: ctd80 hotpoint dryer error code f10
If you remove the back cover of the drier with the appliance un pluged, you will see the heater bracket.
un screw this from the back panel, and at the top you will see three thermostats. There is a brown one with a small hole in the middle, if you use a pin and press in, you should hear a click. This resets the thermostat and you should be able to use the drier again.
Apparently a common fault on these indicit based driers.
it worked on mine
Posted on Oct 28, 2007
SOURCE: dryer won't start up
Does it beep 3 times when you try to switch it on?  If so the door switch is faulty.
Posted on Feb 23, 2008
  • 101 Answers
SOURCE: condensor hotpoint ctd80 drier WON'T GET HOT
Check vent from dryer to outside.
Posted on May 11, 2008
ngfam1
  • 639 Answers
SOURCE: My Hotpoint Ultima CTD80 condensed
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
CALL FACTORY SERVICE NOW!!!! YOU HAVE A 1 YEAR WARRANTY OR YOU WILL HAVE TO PAY FOR THE REPAIR!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
SOURCE: F10 error code on Hotpoint ctd80. How do I fix ? Thanks
remove 2nd largest panel on back of dryer then remove the heater unit (two small screws) from inside panel,on the top of this you will see two small units with wires going in and out both sides looking closer one of these units has a small hole using a pin push it down into hole this resets thermal cut out,you should hear a small click.
Posted on Aug 22, 2009
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
By hotpoint ultima ctd80 tumble dryer has error code f11. What does this mean?
F11 - No pump connection. the pump that pumps the water up to the draw has gone wrong. hope this helps.
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Whats the error type for the hotpoint cdt40 error code - flashing on/off and flashing 'time delay'. I've got heat, the pump is working, the water resevoir is empty
went to a free forum and the experts there stated it was a code F08 fault and that one of the heater relays was welded open - to identify the correct relay was prohibitively expensive and a specialist card reader was also needed and that it wasn't worth the repair.
Dec 30, 2009 | Hotpoint Dryers
Ctd80 hotpoint condenser dryer not heating up at all showing error message f 14 think its thermastat
Error code 14 indicates dryer element fault.
Checkelement-connections-and control module.
Please leave feedback.
Thanks.
Nov 15, 2009 | Hotpoint Dryers
Stops near end of cycle and on/off light and drying high heat light flash
error code f08-htr relay stuck-ckeck htr not open citcuit-connections on board are clean especialy botton connecters-if still throws error then req new board
Nov 12, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Feb 02, 2009 | Hotpoint TDL15 Electric Dryer
Hotpoint CTD80 Tumble Dryer F03 error
hiya
sounds like you will need a thermostat kit and possibly a heater unit, if your getting them shipped to oz you will probably use them. i would change the thermostats first as this will more than likely be the cause.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj.
p.s if its still broken this time next year i'll come and have a look just waiting of my visa :)
Jul 24, 2008 | Hotpoint Aquarius WD63 Front Load...
Condensor hotpoint ctd80 drier WON'T GET HOT
May 09, 2008 | Dryers
Help me fix my dryer
Could be that the belt has gone. I think it does one cycle, then when it tries to reverse it gives the F-08 error and stops - and I think it cuts the heat out for safety.
Mar 09, 2008 | Hotpoint NWXR473EV Dryer
Dryers Logo
Top Dryers Experts
