Question about Panasonic PT-61LCX35
RED VERTICAL LINES PANASONIC PT-61LCX35
RED VERTICAL BAR LINES
techman
  • 3130 Answers
SOURCE: Vertical lines and big red spot on Panasonic PT-56LCX66
Return it my friend, it sounds like a problem on the display panel driver board, and boy is that expensive to replace! Good Luck
Posted on Jul 31, 2007
SOURCE: Vertical lines on Panasonic DLP
panasonic hdtv 1080i has a rainbow in the middle and shows shadow
Posted on Jul 27, 2008
welcomejee
  • 10594 Answers
SOURCE: panasonic pt-53wx53g vertical output ic
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
Posted on Jun 19, 2009
johnnydiode
  • 647 Answers
SOURCE: there are color spots all over screen-pt-61lcx35
This, sadly is getting to be a very common problem with all Projection LCD TV's
Colored Blotches on an LCD Projection TV are usually caused by defects or marks on filters or lenses or one of the LCD panels themselves which are all located in the light engine (or optical block) First confirm that the lamp or main lens is not discolored by removing the lamp (unplug set and let cool before removing!) and inspecting the lamp itself and the lens that it shine onto. The light engine is an expensive part ($600-$1200) to replace and requires major disassembly. Get an estimate -Be sure to vote/rate me if this helped Thanks!
Posted on Nov 06, 2009
SOURCE: panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Posted on Nov 13, 2009
Tip
PANASONIC WITH FUZZY SPOTS
FIXYA TIP PANASONIC
I hope this not AN old TIP, but I still see it asked and not answered properly by some.
TIP:
PANASONIC:
MODELS: PT-44LCX65, PT-52LCX15, PT-52LCX65, PT-52LCX35,
PT-61LCX65, PT-61LCX35.
SYMPTOMS:
1. FUZZY SPOTS
2. FUZZY SPOTS WITH STAINS
3. FUZZY SPOTS & UPSIDE DOWN
4.. FUZZY SPOTS WITH LINES
5. LOOK LIKE BAD LIGHT ENGINE.
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM CORRECTION TOOL; (LSUQ0100).
It is an easy repair (about 7 minutes), it takes longer to take the back off to perform this procedure.
Can't be purchased unless you have an account, customers can not purchase.
Thanks, Big IRISH.
on Dec 15, 2009 | Dishwashers
How do you reset the lamp clock on Panasonic model number PT-61LCX35 without an original remote?
We regret to inform you the original remote is necessary to reset the lamp hour meter. We recommend you use the below link to obtain the correct remote control for the TV. The remote part number is EUR7627Z70.
Parts Ordering
Mar 17, 2014 | Panasonic Televison & Video
Panasonic pt 52lcx35
We recommend that you test other inputs and devices on the TV to see if the lines appear only on 1 device or type of cable connection.
Keywords: thin, red, pink, line, lines, bars, bar, vertical, up, down
Oct 22, 2013 | Televison & Video
My panasonic pt-61lcx35 has red and green spots all over the screen. ii have changed the lamp and still have thr problem
Ur backlight video board is dead,not the lamp,it video prob. must change the backlight video board.
Dec 09, 2009 | Panasonic PT-61LCX70 61" HDTV
There are color spots all over screen-pt-61lcx35
Nov 06, 2009 | Panasonic PT-52LCX65 44" HDTV
Fuzzy red spot in screen pt-61lcx35
Good Day, djaryan;
Try contacting the manufacture or call 1-800-458-6053.
Good Luck big IRISH.
Aug 15, 2008 | Panasonic PT-52LCX65 44" HDTV
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
Good Luck, big IRISH.
Jul 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Jul 30, 2007 | Panasonic PT-56LCX66 56" HDTV
Panasonic PT-61LCX35 Logo
73 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
