Question about Pioneer VSX-D511 Receiver
Reciever display changing by itself
My reciever when turned on the display jumps from the normal display of the current selected input to the tone controls and speaker configuration display then jumps back to input with anyone touching any of the buttons that corespond to those settings being pushed anyone have any thoughts on this issue?
    Problem Solver:
  • 8 Answers
Sounds like a bad microcontroller. First check on the function selector knob if there is one and make sure it is not stuck - move or rotate it back and forth. Also, if the remote is nearby, try removing the batteries from it.
Posted on Feb 02, 2008
What does SABB mean on ge french door refrigerator
Sabbath mode someone pushed some buttons and caused this or touch panel shorting. Need to read owners manual to clear
Jun 20, 2015 | GE Refrigerators
Stop the beeping noise when a print job is done
Here is how to do this :
1.Login as the System Administrator or Key Operator.
2.Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed.
3.Select the [Tools] tab on the Touch Screen.
4.Select the [System Settings] button.
5.Select the [Common Service Settings] option from the Group section.
6.Select the [Audio Tones] option from the Features section.
7.Select the required option to configure or modify, and then select [Change Settings] button.
8.Select the required audio tone. Audio tone options include: [Off], [Soft], [Normal], [Loud].
9.Select the [Save] button.
10.If necessary, repeat steps 7 - 9 to configure each option.
11.Select the [Close] button.
12.Press the [Log In / Out] button on the Control Panel. An "Are you sure you want to logout?" message will be displayed.
13.Select the [Logout] button on the Touch Screen.
Sep 04, 2014 | Xerox Workcentre 5335/p 5335 Mono Advanced...
How to change message tone on Samsung gt s 3653
Dear,
The msg alert tone depends on the current sound profile of your phone (like normal, silent, driving etc).
1. Go to main menu -> settings -> phone profiles. You should find all the profiles available in the phone. For example, we will change the msg alert tone for 'normal'.
2. Tap on the box with the double arrow (>>) symbol next to normal. You should enter a screen saying call alert type, voice call ringtone etc.
3. There is a drop down menu at the top right side of the screen. Tap that and select 'new messages'.
4. 'message alert type' should be melody or vibration & melody, depending on your preference.
5. now select 'message alert tone'. The phone has a number of tones already stored. Select one of these.
6. Or select 'sounds' at bottom right and browse to any file you want to set as message alert tone instead..
7. Save and exit !!
----pls rate if you find it useful-----
Regards,
Samy
Aug 10, 2014 | T-Mobile Cell Phones
B&k avr 7 with SACD inputs needs independent tone equalization settings
For your stereo configuration, refer to the preamp they are connected to for tone controls.
For your center and surround channels, refer to the B&K setup menus for those controls.
Feb 04, 2012 | Denon Audio Players & Recorders
I HAVE A VTECH PHONE THAT IS ON PULSE AND I WANT TO CHANGE IT
Press MENU/SELECT to display menu when in idle mode.
Press up/down to reach Setup BS. Press MENU/SELECT.
Press up/down to reach DIAL TYPE. Press MENU/SELECT
A checkmark is shown next to the current selection. Press up/down to choose between tone and pulse. Press MENU/SELECT.
The screen displays Stored and youll hear a confirmation beep.
Nov 19, 2011 | Vtech Cordless 6041 Phone
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
How to change my message tone to my samsung gt s3653
7. Save and exit !!
Jan 10, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
How to change Message Alert tone
7. Save and exit !!
Jan 05, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
My STR-DE925 reciever isn't giving me any sound. When i turn it on everything works like normal, kicks on, and there is a click; but after a few seconds the display switches from whatever input it was on...
check speaker connections.sounds like the system is trying to stop some thing more serious happening by shutting itself down.a pain yes but saves blowing something up.if no luck,then definately send in for repair
Oct 17, 2010 | Sony STR-DE925
Pioneer VSX-D511 Receiver Logo
64 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
