SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
SOURCE: john deere 2305/ the throttle lever goes back to
remove throttle lever assembly and if it is put together with a rivet?
take vise grip pliers and put in its jaws where it is connected or pivots at the rivet and squeeze it tighter at that point as it has worn with use. You will have to put out on it to make a difference
or if it is put together with a bolt ? its obvious
or if the throttle has indentations built in at certain points of travel then be sure the throttle assembly is tight enough to hit those and stay in that position
SOURCE: Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from [email protected]
SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
SOURCE: john deere 300 garden tractor will not go forward or backwards
Make sure the neutral lever (rod) back by the right rear tire is pushed ALL the way in.
