Question about Toshiba Portege Z835-p360 Ultrabook I3 4gb 128gb Ssd 13.3 Hdmi Widi
PXE-E61 toshiba portege z830
Impossible reboot error message PXE-E61
SOURCE: Trying to start my computer
http://www.hitachigst.com/hdd/support/download.htm has a Disc Fitness Test programme. It produces a floppy to boot from DOS into Windows. My Satellite 1110 has the same error message, PXE-E61. The BIOS shows "no HDD". The DTF  found no fault on the HDD. (full test took 45minutes)    Give it a try.  I know, you need a working computer to down load it-- and DOS and a floppy drive on the faulty one. There are USB adaptors for floppy drives.  Tomorrow I prise the 1110 apart and will clean all the cable and connectors. Good luck.
Bryan
Posted on Oct 21, 2007
SOURCE: toshiba satellite p20, pxe-e61, pxe-mof
cable plug possible defective, if possible plug into another computer and see if error occurs. since you did not state OS go into the Device Manager and insure 'network adapter' has driver installed and working. Is there an external media hooked up?
Posted on Jun 16, 2008
  • 10406 Answers
SOURCE: My tosiba a70-kl1 starts up with a black screen
You haved enabled the capability for your computer to "boot" itself by reading from a boot-server connected to your network-cable.
But, the network-cable is unplugged, resulting in the "check cable" message.
What this _could_ mean is that the computer primarily tried, and failed, to boot from your disk-drive, and secondarily tried, and failed, to boot from your CD-ROM, and so it made a tertiary triy, which failed, to boot from the "network", i.e., that your hard-drive is not functioning.
Reboot, and enter "BIOS setup", and disable the "boot from network" option, to get rid of those error-messages. But, it's still possible that your disk-drive is malfunctioning.
Posted on Sep 14, 2009
  • 161 Answers
SOURCE: I am replacing my Toshiba Satellite A35-S159 hard
In the BIOS, look in the boot options and take the "other devices" or "other" out of the boot sequence. Also check to see if boot from LAN is enabled. If it is, disable it. PXE is a protocol that will enable you to boot from a network drive or server. When it says that it failed, it is because it could not find an OS on the network
Posted on Jan 17, 2010
SOURCE: Toshiba Satellite PC ... Operating System not found
Enter BIOS by hitting F2. Go to Boot tab and change to default boot. I had the same problem and it worked for me.
Posted on Mar 13, 2010
Toshiba portege 2000 windows xp invalid system disk.
When booting, try going to the Boot Menu by pressing F12 when you see the Toshiba logo so you can select your hard drive as your boot device. After doing so, if you still get an "Invalid System Disc" error, then your hard drive may be shot.
Jan 04, 2014 | Toshiba Tecra 510CDT (P000224080)...
Error message on dv 1000 pxe-mof and pxe-e61
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Apr 17, 2013 | HP Pavilion dv1000 Notebook
ACER 4630z will not boot up
Feb 17, 2013 | Acer Extensa 5620 Notebook PC
Laptop won't start up
Aug 12, 2012 | Toshiba Computers & Internet
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
Apr 22, 2012 | HP ProLiant DL180 G5 Server
My Toshiba Tecra 9100 gives me an error message of PXE-E61: Media test failer, check cable. Then it says PXE-MOF: Exiting Intel PXE.ROM. It's asking for a system disk, but this was given to me and I don't...
The error message is caused by a failed hard disk. Replace that then borrow a Windows install disk from a friend and install with it and the key on the sticker.
Mar 17, 2011 | Toshiba Tecra 9100 Laptops
Toshiba portege 3500 tablet saya tidak bisa booting lewat external cd room .. yang ada di layar monitor terbaca : intel(R) boot agent version 4.1.06 copy right (C) 1997-2002, intel...
It means that the BIOS cannot find a disk to boot.
Make sure you selected the hard drive in the boot settings of your BIOS
Remove all external DVD drives or floppy drives or ethernet cables
If you get an error message, you should start troubleshooting your hard drive.
Feb 27, 2011 | Toshiba Portege 3500 Tablet PC
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
PXE-M0F: Exiting PXE ROM
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
Nov 02, 2010 | Toshiba Qosmio G15 Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Try resetting the BIOS to the default settings and reboot
Nov 28, 2009 | Compaq Armada E500 Notebook
Toshiba Portege Z835-p360 Ultrabook I3 4gb 128gb Ssd 13.3 Hdmi Widi Logo
632 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
