Question about LG LSU246HV Ductless Outdoor Heat Pump 14.7 SEER 24,000 BTU 2 Ton
EVAP BLINKING CH 46 UNIT will not run - LG LSU246HV Ductless Outdoor Heat Pump 14.7 SEER 24,000 BTU 2 Ton
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: operation lamp showing - error CH 46 - unit not
CH46 Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor. Helpful?
Posted on Dec 30, 2010
LG air conditioner model number LMN095HVT units keep on flashing with error code CH 46 and with no response at all. How can I fix it? Thanks for your help in advance!
ERROR CH46:
Sep 01, 2015 | LG Heating & Cooling
I have CH Problem in sharp ar 5316 machine. How can I solve my problem?
CH - open cover in the paper feed area CH blinking - Dev unit is not properly installed For the 'CH' check the covers and make sure all covers are closed properly. For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly seated. The developer unit is the unit you slide your ink cartridge into.
May 11, 2011 | Sharp AR-5316 Advanced Digital Imager...
Runs intermitanly at one time it had a hc46 code appear in window
Ch-46-Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor.
Helpful?
Jan 21, 2011 | LG LA185HV Split System Air Conditioner
Lg split system ch 46 error? help!!!
Ch-46Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor
Jan 07, 2011 | LG Art Cool LA181CNW Split System Air...
My copier is showing CH what do i do to it
CH are in two forms steady and blinking CH. Steady CH is associated with door switch for either front cover or side cover. Make sure that the front cover and the right side cover are closed properly.Secondly, Blinking CH
is associated with the toner cartridge or the developer unit not being sensed by the machine. Make sure that the developer unit is well locked in the machine. Pull out the toner cartridge and insert back with some force into the machine, it should clear this sign. If it does not, replace a new cartridge Sharp AR016FT. Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 22, 2010 | Sharp AR-5316 Advanced Digital Imager...
My sharp ar-5316e error code CH please help me
Hope you are fine, ch are in two forms steady one and the blinking ch.
Steady CH
This is associated with door switch for either front cover or side cover. Check that the front cover of the copier and the right side is well closed.
Blinking CH
This is associated with the toner cartridge or the developer unit not being sensed by the machine. Make sure that the developer unit is well locked in the machine. Pull out the toner cartridge and insert back with some force into the machine, it should clear this sign. If it does not, replace a new cartridge Sharp Ar016ft and you are done. Good luck.
Nov 23, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Unit does not operate code CH 46 shows in panel
CH46 indicates that the suction pipe sensor is missing or faulty.
Apr 30, 2009 | LG Art Cool LA181CNW Split System Air...
Sharp ar 250 copier error code CH
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Mar 03, 2009 | Sharp AL-1641CS Laser Digital Copier
Blinking error light CH will not let machine turn on
side door of copier is open just close it properly .if error stills just check by pressing start key what is sub code if 00 developer unit is missing if 01toner catridge is missing .just check all connectors of developer unit and toner unit.code will bi removed
Jan 20, 2009 | Sharp AL 1631 Copier
LG LSU246HV Ductless Outdoor Heat Pump 14.7 SEER 24,000 BTU 2 Ton Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
