Question about Altec Lansing VS2221 Computer Speakers
Scratchy loud noise when volume dial is turned
We just hooked up these speakers, the Altec Lansing VS2221 to our mac computer. We are getting a very spasticy scratchy noise when we turn the volume dial up and down. I am wondering what if any insight anyone might have. Thank you very much for your time.
  • 1 more comment
  • martinclowes Feb 02, 2009
    same problem loud noise when I turn volume pot up or down. I can't figure how to get in to unit to repair /replace the volume pot though. Help!
  • Rodney Feb 08, 2012
    I got the same problem and think it is a bad connection in the cable plug (the cable from the small speakers to the sub-woofer). That is my theory and I'm trying to look for a new set of just the small speakers.
  • ronald worrell Jan 26, 2014
    i am having the same problem when i shake the cable or turn the volume up or down, i would like to be able to get in the sub and change the s-connector
  • 341 Answers
It means that the volume pot is dirty.You need to find a way to get some WD-40 into the pot.This usualy requires that you take the access to the inside off and spray right inside the pot.Once you do this move the volume dial from min to max a few times and it should fix it.
Posted on Jan 05, 2009
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
ALTEC LANSING ADA745 WILL NOT POWER UP
check whether the adapter is fine or not..
that may also be a problem...
Mar 26, 2008 | Audio Players & Recorders
Makes a loud noise when i turn on and no sound plays. I don't think i need drivers but either way they're impossible to find. I have Altec Lansing ADA215 Computer Speakers.
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 31, 2010 | Altec Lansing ADA 215 Computer Speakers
Very low volume coming from speakers
i have exact same problem i think its got something to do with volume controller on front right speaker damn shame as the sound was awesome
Jun 02, 2010 | Altec Lansing ADA745 4 Speakers
Static when I turn on speakers or adjust volume
The problem is that the switch/volume control is dirty.
This is what I have done.
Dismantling Altec Lansing VS 2221 speakers to clean the switch/volume control
Tools: a medium Phillips screwdriver, a craft knife & a can of CO contact cleaner & extension.
1. Remove switch/volume control knob by pulling it off
2. Pull out the base for the stand if attached
3. Unscrew the 2 screws beside the wires
4. Remove the front gauze by prising it out from one of the bottom corners. Keep the gauze straight as it will need to be put back from the bottom to the top.
5. Remove the 2 screws at the top and the 4 long screws holding the speaker. The back will come apart from the front and sides. If it has been glued then use the craft knife to carefully cut the back away from the sides and/or prise it away with a little pressure on the sides.
6. Attach the extension to the can of contact cleaner.
7. Lift the circuit board out and squirt only the switch/volume control. Ensure you squirt the shaft and the internal parts of the switch/volume control. Turn the shaft a few times.
8. Allow the contact cleaner at least 1 hour to dry.
9. Test the speakers. If the noise is still there then repeat steps 6-9.
10. To assemble the speaker do the steps 1-5 in the opposite order.
I hope this is helpful
Jan 26, 2010 | Altec Lansing VS2221 Computer Speakers
When power supply pluged in the wolfer makes loud noise
Try turning the volume down on your computer or on the woofer itself.
Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
Loud static sound comes from computer speakers and the phone
Uninstall and reinstall new drivers for your sound card from the soundcard manufactures website or if its onboards from the PC makers site. If your using vista their has been widespread issue's related to the static "bug" and numerous solutions that sometimes work or do not work have been tried. ex; if is a soundblaster card try Creative.com's forums.
Apr 16, 2009 | Altec Lansing VS2221 Computer Speakers
I LOVE MY SYSTEM BUT...
hey sir
it s easy .. and there s two ways to buy one ..buying it directly from a shoping or by internet online from same
business online shoping
Aug 24, 2008 | Altec Lansing VS2221 Computer Speakers
Scratchy noise?
Are the speakers old? The only thing that can make a random scratchy noise on the speakers as far as I know is a dirty volume knob. Try turning it all the way up and all the way down (with nothing playing) and see if that helps. If it does, blow them out with some compressed air. I'm thinking your issue is probably software / driver related though, does the scratchiness happen in other programs? WinAmp? Windows Media Player? .. if it does, you've narrowed it down to a driver-related issue, go to your sound hardware's manufacturer website and download the latest drivers.
Jun 15, 2007 | Altec Lansing 641 Computer Speakers
When truning up t3h volume...
volume control knob is damaged inside ,try to put 3drops of kerosine mixed with edible oil in equal amount.care should be taken not to get it on the electronic board and adjust the knob continuously ,if this doent work u must replce the volume controll
Dec 18, 2006 | Altec Lansing VS2221 Computer Speakers
Altec Lansing VS2221 Computer Speakers Logo
1,566 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Ryan S
Ryan S
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
