Question about Lands Phones
Phone has been making high pitch noise and the land line and cordless phones did unplug and its still not working, now no calls coming in or out. what to do next
SOURCE: cordless phone does not connect
You may need to reset the Telephone Answering System. Complete the following steps to reset the Telephone Answering System:
Step 1: Disconnect the power to the telephone base.
Step 2: Wait a few minutes and then reconnect the power to the telephone base and charger.
Step 3: Set the day and time.
Posted on Apr 03, 2008
  • 3 Answers
SOURCE: Phone won't hang up
I solved this exactly problem by doing this:
1) unplug base station from phone line
2) unplug base station from power cube
3) open each phone and disconnect battery (do not replace phone in charger; just let it sit)
4) wait 30 minutes (per instructions from Uniden)
5) reconnect batteries in phone sets
6) reconnect power cube to base station
7) reconnect base station to phone line
8) test: make a call. Hang up. Wait one minute. Pick up line and see if you get a dial tone.
(Basically you're "rebooting" the system. You don't know where the fault lies, so you power down every component to make sure you get it. The '30 minutes' is longer than I'm used to, but after being on hold with Uniden tech support for 20 minutes and finally getting through, the instructions from them were very clear: AT LEAST 30 minutes. OK! I did it - and it worked!)
Posted on Jan 21, 2009
SOURCE: I have a Tesco Cordless
Maybe a little bit late, this is the solution for registering the handsets: hold the button on the base until it starts beeping, then, on the handset, go to the Register menu, select base number - in my case it's 2, then it will ask the PIN - the default is 0000, and that's it.
Posted on Jan 30, 2009
SOURCE: EnGenius DuaFon 1X
Registration:
a. Press MENU-6 to enter the registration mode
b. Press and hold the base’s Registration (REG)
button for 2 seconds until 4 LEDs light up. (Located on the base where you plug in the phone jack)
c. Press handset key “1”, this completes the
registration process. When you register the
handset to BASE 10, the base will assign a
handset ID between 11 and 19. The assigned ID
will be displayed on the handset LCD, indicating
successful registration.
d. Repeat above steps for all additional handsets.
e. The first two handsets registered will be given ID
11 and 12, which gives them administrator
privileges.
Posted on Aug 11, 2009
SOURCE: Have new CD155 cordless phone. phone does not
I'm having the same problem. My temporary solution is to turn on the speakerphone on the cd 155. Also if you happen to have an older phone laying around, you can use a phone jack splitter and use the old phone to alert you of incoming calls.
I just noticed this problem today, i'm still working on it. I'll let you know if I come up with a better solution.
Posted on Feb 23, 2010
Cordless phone set problem
Look below or on the side perimeter of the phone there is switch marked Hi and Low, select the low option and you will have a lower tone on your phones.
Mar 25, 2008 | Lands Phones
My phone stop the ring
This phone unit it is a cordless phone hand set unit phone,it is a home land line base phone wright?Yes? Did u tries ring high ring low on the phone hand set functions up and down of the phone itself have a ring functions so u make sure is it not the phone unit functions itself.Did u try other phone unit on that phone land line to make sure it is not the land line phone line problems.U can tries take the corless hand set nocking it on a hard surface lightly a couples times.This could clean some dust and dirt loosen or stuck function buttons.The cordless phone hand set battery it is charging?Yes? Phone might have a weak or dying or a dead litium battery.Tries the phone unit itself unplug/replug it back like about and hour later for phone unit to reboot itself.
Oct 04, 2011 | Lands Phones
Telephone making a high pitch sound when answered like a fax but we dont have a fax
do you have an alarm system....it will sound like a fax machine
if so there should be a phone jack inside the alarm panel in the
closet....unplug it and see if the fax noise goes away
Feb 12, 2010 | Philips SE7452B Expandable Cordless Phone...
Can I use Bluetooth headset on Bluetooth enabled land-line phone?
Sorry sir those over the head are the only ones to date that i know of
Dec 12, 2009 | AT&T Blackberry Curve 8300 Smartphone
See:http://www.testfreaks.com/blog/review/vtech-ls6245-cordless-phone-with-bluetooth/. Looks like you could at least with this one. I am also looking to do the same.
Dec 12, 2009 | Vtech Lands Phones
"Line in use" message on Motorola 450 cordless phones
Call your ip internet provider ATT etc.
your dsl is incorrectly wired
May 28, 2009 | Uniden Cordless Phone
Home phone giving a high pitched dial tone .
This normally happens when the exchange junction box nearby has some problem... do call the line man to clear the problem
Feb 18, 2008 | Uniden Cordless Phone
Lands Phones Logo
200 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
