Question about Lexmark X5470 All-In-One InkJet Printer
Power cord I need a power cord for the back of my printer its a lexmark all in one x5495 its that black box behind it with the cord attached. I need one baaad. email me at desirae_mccollough@yahoo.com please!!!!
    Master:
    Sergeant:
  • 482 Answers
You can get one at radio shack or ebay, model # on ebay 12V
Posted on Jan 05, 2009
Lexmark x5495 not feeding paper
There could be something that's blocking the paper path. Try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects inside the feeder - try to use a flashlight to look into the paper feeder.
  2. Remove the cartridges from the printer. Check the cartridge area and make sure there are no foreign objects blocking the paper path and the cartridge carrier path. Close the printer.
  3. Re-brick your printer. Remove the power adapter from the printer (it's the black box found behind the printer where the power cord is plugged into). Re-plug the power adapter after 30 seconds. That should give enough time for the printer to reset itself.
  4. When the printer turns on, re-insert the cartridges and load some paper.
  5. Try to print a document again to verify that the problem is fixed.
Should the problem continue, please contact Lexmark Technical Support for additional assistance.
Nov 15, 2011 | Lexmark X5495 Printer
How to change my lexmark 4650 printer back to English
Unplug the power supply(the black box behind the printer where the power cord is attached).
Hold down Start and Cancel buttons at the same time while plugging back the power supply.
Keep on holding down the 2 buttons firmly until English Language Selection appears on the the display.
Jul 21, 2011 | Lexmark X4650 InkJet Printer
The printer won't turn on. Is there aq reset button that I can use to get it to work?
Try to unplug the power adapter from the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Leave the power cord attached to it and the other end plugged in straight to the power outlet in the wall. Bypass any surge device or power strip. Wait at least 20 seconds before plugging it back in the printer. If the printer won't automatically power on, press the power button. If this doesn't help, I strongly suggest you contact Lexmark technical support to further investigate the problem. thanks.
Aug 11, 2010 | Lexmark X7170 All-In-One InkJet Printer
I have a lexmark x125 all in one printer, it dosnt turn on ,y tried changin the conection cord all th troubleshotters but nothing happens please help me
Great job on changing the connection cord. Also, try removing the power adapter from the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging the power adapter back in the printer. Properly secure it behind the printer. If that doesn't help, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks
Jul 20, 2010 | Lexmark Pro X125 All-In-One InkJet Printer
No power
Unplug the power adapter from the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Leave the power cord attached to it with the other end plugged in straight to the power outlet in the wall. Bypass any surge device or power strip. There should be a green LED light on around the adapter's contacts. If LED is off, properly secure the power cord. If that doesn't help, either the power adapter or the power cord is the problem. If LED is on, plug it in the correct position back in the printer and properly secure it. If printer won't automatically power on, press the power button. If that doesn't help, the printer itself is the problem. I suggest you contact Lexmark Technical Support to further investigate the problem.
Jul 18, 2010 | Lexmark X5470 All-In-One InkJet Printer
Printer is dead
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave the other end of the power cord attached to the power outlet. Bypass any surge device or power strip, plug the power cord straight to the power outlet in the wall. Properly secure the power cord in the power adapter. There should be green LED light on on the power adapter. Plug the power adapter back in the printer. Make sure it's plugged in securely and in the correct position. If it won't power on automatically, press the power button. If that doesn't help, it may be a hardware problem. If that's the case, I suggest you contact Lexmark Technical Support to further investigate the problem.
Jul 15, 2010 | Lexmark X2600 InkJet Printer
Hi, my lexmark x2600 paper load light keeps blinking. I think my daughter was messing with the buttons.
Try to remove all sheets of paper. Then unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave the other end of the power cord attached to the power outlet in the wall. Wait at least 30 seconds before plugging back the power adapter in the printer. When the printer's ready, load some papers and check if it's working fine now. Keep me posted by leaving a comment. Thanks.
Jul 08, 2010 | Lexmark X2600 InkJet Printer
Lexmark 2350 seems to have no power
Try this. Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Make sure the other end is plugged in straight to a known working power outlet in the wall. Bypass any surge device or power strip. Properly secure the power cord in the power adapter. Then plug it back in the printer. Plug it hard and in the correct position. If it won't power on automatically, press the power button. If this doesn't help, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jun 22, 2010 | Lexmark X2350 All-In-One InkJet Printer
My Lexmark x9350 only turns on and off if I plug and unplug...
This, probably, is a power issue on the printer. Unplug the printer from the computer. Unplug the power supply from the printer (it's the black box behind the printer where the power cord is attached). Try not to use any power strips or extensions for the power cord. If possible, plug the power cord straight to the wall outlet. With the power cord plugged in straight to the power outlet, plug the power supply back in the printer. That should refresh the printer. When everything's powered on, plug printer to computer. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 13, 2010 | Lexmark X9350 All-In-One InkJet Printer
Can't find plug for power cord
On the back left end. Identified as item 4 below: c8d8f7d.jpg
Aug 26, 2009 | Lexmark X2500 All-In-One Printer
Lexmark X5470 All-In-One InkJet Printer Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
