Question about Microsoft LifeCam VX-1000 Webcam
Can't get everyone to see my video - some do others can't
The "show my webcam is not highlighted when I try to select this feature, and some of my friends are able to see me while others can't. What should I do?
  • cwood518 Jan 26, 2009
    I have installed the VX100 webcam but when on skype, I can see the contact but they cannot see me. Please help or I will be taking the webcam back for a refund !
    President:
  • 8,637 Answers
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Posted on Jan 28, 2009
Error during capture error code 800706f8
The very first step is of course to check your webcam connection. Most webcams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in webcams this steps does of course not apply. Many new laptops have a build-in webcam. Also try connecting your webcam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
windows-xp-other-device.jpg If the device is not recognized in Windows XP, it will be listed under Other Devices.
windows-vista-device-error.jpg In either case you can try to update the drivers. Right-click the device, and in the popup menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the webcam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to uninstall the software that came with your webcam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party uninstaller.
After uninstalling the software, restart your PC and then reinstall the webcam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your webcam during the software installation.
If the drivers and webcam software are correctly installed, and you still cannot see any video, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the webcam feature. If you have multiple devices that qualify for video, you might need to select your webcam device as the source for the webcam feature in that program.
Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
Lastly, if your webcam's image is not sharp, check to see if it has a focus ring. A blurry image can sometimes simply mean the webcam is not in focus. Adjusting the focus through the ring can solve that problem.
Other picture quality problems with webcams can be addressed by changing the video capture properties for the webcam. Most programs that can use a webcam will have an option to access the properties of the video source, which will bring up the video capture properties window.
video-capture-properties.jpg Do keep in mind that not all settings will be enabled depending on the webcam and the webcam driver installed on your computer. In the example you can see that some settings are disabled. The example shows the video capture properties for an Acer Crystal Eye webcam.
What else to try: download missing webcam drivers! If you are using your webcam for instant messaging with one of the popular chat programs, have a look at EatCam, which allows you to record your webcam chats from MSN, YM, ICQ, Skype, AIM and a few more!
Mar 05, 2011 | Computers & Internet
I have a Compaq Presario CQ56-115DX with a built in webcam. It is a Cyberlink Youcam. I tried getting on a messenger, and it said my webcam was paused. I went to the Youcam window and it says I don't have...
Click the following link to download and install Windows Live Messenger from the Microsoft web site. Before downloading the program, you should setup a user account. There may be a fee for some advanced features. After launching Windows Live Messenger, to setup the webcam, select Tools , and Audio and video setup ... . c02457134.gif During the set up, verify the microphone and speakers are active, and click Next to configure the webcam. c02457135.gif Use the drop-down menu to select the desired webcam video capture device. If one driver does not display the desired image, select a different driver. If there is no webcam image or there is no webcam device listed, verify that a video device is listed in the Device Manager. see one of the documents listed above on Fixing Webcam Problems by operating system. After the webcam is tested, you can initiate a video conference using the webcam.
  1. Sign into Windows Live Messenger.
  2. To invite someone else to view your webcam, click the down arrow that is located in the upper-right corner of the Windows Live Messenger window. Select Actions , then select Video , and then click Show your webcam .
  3. If prompted, verify the setting in the Audio and Video Setup window.
    1. Verify that the speakers or headset that you would like to use is selected, adjust speaker volume as necessary, and continue.
    2. Verify that the microphone that you would like to use is selected, adjust microphone volume as necessary, and continue.
    3. Verify that HP Webcam is selected and finish.
  4. Select the contact to whom you wish to send an invitation and click OK .
  5. You will see a stamp in the chat window indicating that you have invited your selected contact to start viewing your webcam. You will also see yourself in the webcam in the bottom-right corner of the chat window.
Dec 26, 2010 | Computers & Internet
When i start video it is showing "Can't start video renderer. Check you've got a a valid direct x installation.
Everyone seems to love the fact that laptops now come with built-in webcams as a standard feature, but what about your desktop PC? In most cases, you'll need to buy a separate webcam and install it yourself. This is sometimes easier said than done, especially when it comes to choosing the right model, installing the proper software, connecting it to your computer, and finding an appropriate placement for filming. Luckily there are helpful installation guides for webcams like this one to explain step-by-step exactly what you need to do in order to turn your desktop computer into a place to video chat, record video diaries or vlogs, or take snapshots of your life.
Check out this simple how-to guide for connecting and installing a webcam on your desktop computer.
Jul 20, 2010 | Microsoft LifeCam VX-1000 Webcam
My webcam is not working.i can't buy other webcam because my webcam is attached to my laptop on upper portion of the monitor.pls help me to recover my webcam.my teacher said its because of the virus coz my...
Dont worry just follow the easy steps
Steps to solve the webcam problems The very first step is of course to check your webcam connection. Most webcams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in webcams this steps does of course not apply. Many new laptops have a build-in webcam. Also try connecting your webcam directly to your PC instead of through a USB hub (if you are using one).
Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Lastly, if your webcam’s image is not sharp, check to see if it has a focus ring. A blurry image can sometimes simply mean the webcam is not in focus. Adjusting the focus through the ring can solve that problem.
Jul 02, 2010 | Computers & Internet
Cant access show my cam
I had the same issue, all i did was select sign out from the menu, then i signed back in and presto, show webcam feature was enabled.Hope it is as easy for you
Jan 02, 2010 | Microsoft LifeCam VX-3000 Web Camera
HOW DO I USE THE CAMCORDER AS A WEBCAM?
You can use the USB mode to connect to a printer or a host PC. Before connecting to a printer or PC, refer to Installing software and drivers on the page 76 of the User Manual.
When the video camera is connected to the computer or printer using the USB cable, one menu displays in your monitor.
Use the joystick to highlight an option and press the scroll wheel inwards to confirm.
You can select PC Camera feature, when you set in this tag, the video camera can be used as a webcam for video conferencing.
I hope helped with this.
Dec 04, 2009 | DXG Technology DXG-565V Flash Media...
Tried to install ez video chatkit but i got program blocked due to compatibility issues. i have windows vista
have you try to run in win xp mode ??. Highlight the icon at the desktop, right click on your mouse, select properties, there on one of the tab´s there is compatibility mode for other operating system, try ex with windows xp :O)
Hope that helps
Have a nice day
Please rate my answer
Nov 27, 2009 | Ezonics EZVideo Chat Kit Webcam
We cant record a video clip with sound - only picture
You need to go into the recorder options ant tell it the sound source to us is the USB Mic. on the webcam, or what ever the source of the Mic. is. There are several sources in Skype that allow changes to be made. Use the drop down menu for the selection and select the one you are using for the mic. Good Luck, RAC
Mar 28, 2009 | Logitech QuickCam Connect Webcam
How do you access the special features on a DVD?
If you can see them when the disk starts,the one that says play is probably highlighted, try pushing
the fast forward button and see if it highlights the other choice's before pushing play.
Any other questions please post back and everyone is more than happy to help you.
Mar 25, 2009 | Televison & Video
I have a Logitech Mic (Communicate STX)webcam but when i go into windows live messenger to show webcam it says no webcam detected it is greyed out and only video calling is highlighted. When i look in...
Very particular to install....if you done wrong everything goes wrong
Do not install the web cam before installing the program (very pikké)
Reinstall following the steps then Reboot
Feb 24, 2009 | Logitech QuickCam Express Web Camera
Microsoft LifeCam VX-1000 Webcam Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
