I need instructions to programme a PRF 52 remote thermostat
I have a Room Thermostatic PRF52 fixed to the wall but I do not have instructions as to how to adjust or programme it. Does anyone have any information as to where I could look at, or download, thse instructions.
SOURCE: reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
Posted on May 30, 2008
  • 92 Answers
SOURCE: source for installation insrtuctions
they normally come in the box but i beleive the valve body is marked. they are not on off valves they are a mixing valve make sure you have volume controls or they wont work in most cases
Posted on Feb 23, 2009
frcs68
  • 1605 Answers
SOURCE: I need user's manual for Danfoss Randall Thermostat TP4000
go to the following link.
download and print the user namual.
http://randall.danfoss.com/PCMPDF/40811v01.pdf
Posted on Apr 06, 2009
  • 3 Answers
SOURCE: Lost Instructions for Hampton Bay remote control 838956
Go to www.kingoffans.com and follow the site. They are the makers of Hampton Bay.
Posted on May 24, 2009
  • 10865 Answers
SOURCE: I need a sheme how to install Hudson reed Astbury
here is a link which will show you http://usa.hudsonreed.com/catalog/Thermostatic_Complete_3_Way_Shower_Set/688.html
Posted on Oct 15, 2009
I have a 9610 thermostat turns on and off to frequently
I am guessing but the thermostat is either faulty or is in conflict with another thermostatic device in the system. The room thermostat measures the air temperature in the room but with a modern intelligent boiler there will be other sensors measuring all sorts of things including the water temperature.
Personally I prefer to have thermostatic radiator valves rather than a room or zone thermostat.
Jan 02, 2017 | Heating & Cooling
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
Why is Hunter thermostat temp is wrong ?
The most likely problem is the wall on which the thermostat is mounted. The thermostat is designed to read the temperature of the space in the room, but if the wall is exceptionally warm or cold it can really throw off the actual reading.
Options might be to stuff insulation into the wall behind the thermostat, or relocate it to a wall that is more consistent in temperature with the actual temperature in the room.
May 11, 2014 | Hunter Fan Company 5/1/1 Programmable...
CALIBRATE THERMOSTATIC HEAT CONTROL
Honeywell part number is needed to determin which procedure to use.
Nov 24, 2013 | Honeywell Programmable Thermostat Heater
Skytech 3301 thermo
Check to make sure your thermostat is set at a temperature that will turn the fireplace "on".
Double-check what your "swing" temp settings are set at, as this may effect how quickly the unit shuts off because it thinks it's too close to the target temperature.
If needed:Skytech's Tech Support number is 1-888-672-8929They are available Monday to Friday, 8am to 5pm EST.
If your remote needs to be replaced, the 3301 is available here:
Skytech 3301 Fireplace Remote
If you are looking to replace it, I would also highly recommend looking at Skytech's new 3301P2 remote. It adds a programmable thermostat, and a much nicer back-lit LCD screen. This unit is available here:
Skytech 3301P2 Fireplace Remote
Dec 15, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
Fan remotes
mcdevito75 here, If the thermostatic switch was controlling another ceiling fan then yes it should work, it"ll have to hook up to the wall switch. I'd double check with a hardware store in the area for more advise.
Jul 19, 2010 | Hampton Bay 24002 Ceiling Fan
Indoor temp is 5 degrees colder than display reads on digital thermostat
Where are you measuring the indoor temperature?
To compare it to the thermostat temperature you have to measure both temperatures at thermostat.
The thermostat will only control the temperature at the thermostat, not any where else in the room.
The room temperature depending on insulation in walls and ceiling and distance from outside wall and outside temperature, can be as high as 10° difference from outside wall to inside wall of house.
The lower the outside temperature, the greater the room difference in heating. The higher the outside temperature the greater the room difference in cooling.
Feb 13, 2010 | Honeywell Programmable Thermostat Heater
I dont know how to programme my invisible heating
If the boiler is working fine for the rest of the house, you may want to check the thermostat for the living room or the water zone valve for the living room, you should call a heating expert to find out why living room is cold.
Dec 05, 2009 | KDS Valiant 6380iPTD-01 Notebook
Apr 01, 2009 | Hampton Bay 52 In.Carriage House II in...
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
