I tried taking apart a AT835b shotgun condenser mic without tearing wires but ended up tearing the wires. So how? do I solder the wires to which spots
2 Suggested Answers
  • 417 Answers
SOURCE: Audio Technica PRO-35: need wiring diagram for mic end
If you feel the shield goes to the middle, try red on one terminal and white on the other. If not, reverse it.
If it's labeled on the circuit board...pin 1, pin 2, pin 3, then pin 1 is usually ground, pin 2 is hot (red), and pin 3 is cold.
Posted on Apr 15, 2010
How do I disassemble a sony ecm-nv1 microphone?
remove the sony sticker and you reveal 2 screws.
unscrew them with a small cross screwdriver then take apart the 4 parts shell (2 sides, top cap and rubber bottom) running your nail trought the border.
now you can access the electronics :D
Feb 07, 2013 | Sony ECMNV1 Microphone
Just bought a 29 LTD Classic every thing works but I can not get any sound from it. My p/a works and when I key the mic the sound comes from the radio. Do I need better antennas?
Hi k,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
It sounds like you have a Mic issue. Take the Mic cord end apart,
it has just three(3) tiny screws holding it. May just have to swap two(2) wires.
You will need a soldering iron for this. On the end of the plug face you will see
the pin numbers i,2,3,4. Here is the wiring.
1- shield
2- audio(white)
3- transmit(red)
4- receive(black) Then re-assemble and enjoy
Thanks for choosing FixYa. Happy Holidays.......John
Dec 26, 2010 | Cobra 29 LTD CB Radio
How many rca wires do i need what kind of mic and will it work off a soundblaster external soundcard and if possible i'd like to have a drawing to show what goes where
We have no way to enter drawings on FIXYA.
Figure 3.1 in your user manual has everything you need to know.
You would need 4 cables with RCA plugs at the 1202 end and whatever your soundblaster interface takes at its end to handle STEREO signals to and from the unit.
Almost any type of mic will work, and the choice of mic depends on what you are using it for and how much you have budgeted for. If you are in a studio without monitor, then one typically uses condenser mics AND for those you turn on the "phantom" power on this mixer. If you have speakers tied to this or where the mic can "hear" the speakers you likely cannot use condenser mics as they will cause feedback.
Sep 22, 2010 | Behringer Rx 1202fx 12 Channel Line and...
How to fix feedback in radio or squeal
Hi, my name is John. Sounds like you have a wire off the mic. plug and its touching another wire. Try another mike, or take and see if it works on PA. To take the end apart off the mike, remove the tiny screws, should be three(3), careful not to misplace them. Slide the end back, and see if any wires are off or touching another wire, if so, re solder, then put the screws back in place and your done. May have to relocate the unit, to get rid of squeal......hope this was very helpful....
Aug 27, 2010 | Cobra Radio Communications
I keep getting disruption in audio. at first i thought it was a squelch problem, but everytime i wiggled the mic the audio would come back. I bought a replacement mic, but still does it. Obviously its...
Hello, My Name Is John, Lets see if I can help you. First you will need a soldering iron, screw driver, solder. Unplug the radio, take the cover off, notice where the pins are at the mike connection, re-solder them and that should do it, but look at the joints on the circuit board, that they are not cracked , if so, re-solder them also ....hope this helps...
Jul 16, 2010 | Maxon MCB-40 40-Channels Handheld CB Radio
I've had a Marshall MXL 2001 mic for seven or eight years, and it's worked without a problem. Yesterday, it stopped working. I opened it and don't see any loose wires. Where should I take it for repairs?
mics are very delicate . a lot bundled into a small area. If you are handy..take it apart. All you may be able to do is check for loose solder joints..mics are dropped, moved a lot so they go through a lot of physical stress. My last mic repair ended up being a bunch of loose solder connections. if not..if its of value to you..send it in. Trace Electronicss..Canada.
May 06, 2010 | Marshall MXL 2001-P Professional...
Mar 31, 2010 | Audio Technica Audio-Technica AT2020...
I have a shure sm58 wireless microphone when i switch it on everything seems normal but i dont have sound coming out of the receiver... after the troubleshoot i made i learned that the problem is the mic...
Unfortunately the sm58 capsule is very hard to get apart without damaging the contact surface.
You would have to take the contact side apart 1rst
bend all the little tabs away which hold the brass plated disk in place
then its a matter of edging the disk out....CAREFULL any scratch is bad!
Once you have the disk out you will need a 1/4" socket to remove the shaft bolt,
unsolder the green and yellow wires taking note where they were soldered.
Then the element can be pulled out.
What to after that, I'll let that up to you.
Be wary, you will void warranty.
Jun 22, 2009 | Shure SM58 Professional Microphone
Can i take apart the drum somthing keeps tearing my clothes
The best access to inside the tub is through the lid/door. Going in through the back will not give you any better access.
If the wire is tearing yur clothes, maybe you can see the end of it poking through a hole. If you can, put a pair of vise grips on the end of the wire and try pulling it back through the hole.
Apr 29, 2009 | Washing Machines
Dead md421
Ignore GazllFixIt...
If it's dead, a connection is already broken inside.
Much more unlikely is that the capsule is at fault - and if it is you can't make things any worse anyway.
Who cares if you break a connection when you take it apart - as long as you can use a soldering iron, it's easy enough to fix. If you can't, why would you be taking apart in the first place ;)
You'd be mad to send it to Sennheiser to solder 1 or 2 points then send it back to you! Waste of time and money.
Try learning something yourself, especially if it only cost $10 and doesn't work to begin with.
Remove the capsule assembly - desolder and disconnect the wires at the base of the mic (not from the capsule) yourself (see, opposite of last advice), then connect them directly to a cable with an XLR on the other end. Forget about ground for now.
Now plug it in...do you hear anything? If not, get a multimeter and check continuity between capsule and your XLR. If you have continuity, throw the mic out. If not, replace those wires. Still nothing - chuck it out.
If you are hearing something (it should sound absolutely fine, clear, loud etc), ...find the broken connection elsewhere...but also, be happy because it definately still works and is definately fixable and you can do it yourself.
Jan 05, 2008 | Sennheiser MD421-II Professional...
 Grubhead
Grubhead
