Question about Tristar SB Steam Buggy Vacuum
Need Water reservoir Cap for Model # EK 8005 - Tristar SB Steam Buggy Vacuum
2 Suggested Answers
guru_fixya
  • 944 Answers
SOURCE: I have a steam buggy
You can buy it in the nearest customer service center only.Get your location customer care
address
Customer Service hours Monday - Friday 9:00 am till 8:00 pm Eastern Standard
Customer Service hours Saturday - 9:00 am till 5:00 pm Eastern Standard
Customer Service hours Sunday - CLOSED
Time Phone: (973) 287-5100
To check the status of your order 24 hours per day, seven days per week,
simply click on www.customerstatus.com
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 03, 2011
Ek-8031 steam bullet user manual
check the internet for the manual. You can usually find it with just the model number.
Sep 23, 2016 | Vacuums
The steam comes out of the water reservoir cap instead of the steam Jet Nozzle.
I can only guess since I have never worked on one of these units, but I think you lost a gasket on the cap. Pressure must build in the reservoir before being forced out the nozzle.
Jul 13, 2015 | Tristar SB Steam Buggy Vacuum
Steam cleaner ek8005
It would be most helpful to at least post the brand name of the unit, and you obviously have a computer, run a search for the parent company, call them and ask if replacement parts are available. If so, can you get a new switch. That simple.
Oct 22, 2013 | Vacuums
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    I'm looking for replacement parts for tristar sb ek-8005.steam buggie. I bought it many years ago on hsn. Thanks for your help! karen USA
    Sorry for the delay in responding. I have done many searches and also contacted the maker of Tri Star vacuum products; they did not market the Tristar Steam Buggy.
    Before you consider investing more money in your machine you may like to view this video:At this point the only source of replacement parts is likely the secondary or used market. If you search you will find some products offered in places like ebay. For example:
    http://www.ebay.com/itm/Steam-Buggy-/150699580656?pt=LH_DefaultDomain_0&hash=item2316651cf0
    Trust this is helpful. Thank you for using FixYa!
    Feb 21, 2012 | Tristar SB Steam Buggy Vacuum
    He filled the reservoir, turned on the switch and pressed the handle to get soap and water and nothing came out does not spray
    Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
    - Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
    - Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
    - Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
    - Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
    - Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
    - Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
    Nov 23, 2010 | Bissell 1699 ProHeat Clear View Upright...
    I need to buy a replacement Water Reservoir Cap for my steam buggy. Any lead as to where I can get this part?
    www.ApplianceZone.comLowest Prices On Appliance Parts Same Day Shipping Only $5. I found this place, they claim they have the parts.
    I hope I helped.
    Nov 07, 2010 | Tristar SB Steam Buggy Vacuum
    Steam buggy water reservoir cap has apparently been cross threaded, and cannot be removed by twisting or other "encouragement." If I cut it off, where can I get a replacement? Can the machine be used as...
    You need to completely annihilate the plastic cap by cutting it off and destroying the remaining plastic to expose the stainless steel insert/plug. You can use either a pipe wrench or 11mm wrench to turn the insert counter-clockwise to unscrew. You will need to use some force to get the plug out since it's basically glued shut by lime deposits in your tap water.
    Do not move the slotted cap or else this will need to be adjusted so that all your water doesn't squirt out before turning to steam.
    Next time only use distilled water. Store with the cap off. Grease the inner and outer threads after every use and wipe it off completely before use so it doesn't mix with the steam and turn to vapor.
    Sep 23, 2010 | Tristar SB Steam Buggy Vacuum
    Tristar SB Steam Buggy Vacuum Logo
    Top Tristar Vacuums Experts
    JoeVacs
    Thatvacguy.com
    Are you a Tristar Vacuum Expert? Answer questions, earn points and help others
