Question about Lexmark X5470 All-In-One InkJet Printer
How do i buy a power cord for the back with that box cart thing
    Master:
    Sergeant:
  • 482 Answers
Radio shack or ebay, locate the Volt, 12V? give the model # on ebay
Posted on Jan 05, 2009
How do I know what size janitorial cart to buy for the office?
To decide on the right size janitorial cart, you need to take a few things into consideration like the size of the office, the size of the hallways, and he size of the space where the cart will be stored. It's also a good idea to take a look at all the cleaning equipment that will need to be stored in the cart to make sure the cart you buy can handle all the equipment.
Jul 24, 2013 | Furniture
Bretford iPad Cart Static Electricity problem
This was straight from a Bretford tech:
There are no capacitors or anything that can hold a charge on the cart itself. The only thing that we've been able to come up with thus far is that dry air in the schools may help generating static electricity. Common precautions would be 1. make sure the ground plug is still on the cord. (This can get broken off if the cart is moved with the cord still plugged into the wall.) Plugging the ground cord in won't help however if the person has to grab the door handle to open the door to get to the wall outlet. 2. If the air is dry (ie: people get shocks even without the cart or the problem goes away in the spring when the humidity goes up), gently push the metal of the cart handle against the door frame prior to reaching for the door handle. This will discharge any static electricity that was built up as the person walked with the cart safely to the door jamb prior to the person reaching for the door handle.
Nov 20, 2012 | Apple Computer Apple Bretford PowerSync...
I want to purchase, how & how much?
LOL Good choice. Personally I like the N75 better though. Things are usually cheeper when you buy them straight from the manufacturer. I suggest going to nokia.com type in the cell phone name in the search box on the webpage (not the one on your browser), click search, then look for a button that says buy or add to cart, then look for a button that says check out, put in your credit card information and fallow the steps. If you're looking for something cheeper try amazon, craigslist, ebay or some other websight that seles used phones.
You can also use your own search engin that's located obove the web page. Type in "buy N70", click search and check each web page to compare prices. Just click the back arrow button above the search engine to go back and check a different web page. Once you fined the best deal click on the web page you found it on, click buy or add to cart, check out, and fallow the instructions. Unfortunetly you can't buy anything from this web page, but good luck on your search.
Sep 30, 2011 | Nokia N70 Cellular Phone
Print cartridge in right stall not supported !. was working fine for a long while with the same cartridge. still has ink. took it out, put it back in. is there a known glitch with these things or what?...
There are a number of known glitches with these models. Without having a known good or new cartridge to try, you should remove both of the carts, close the lid, and pull the power cord out of the back. This will reset the printers ram, and force it to reload. Wait 10 minutes, plug back in and power on. When it finishes making noises, insert the carts, black first, and if it clears, you're good. If not, you will need to buy another cart to go any further.
Sep 29, 2010 | HP OfficeJet 7310 All-In-One InkJet...
My wii won't turn on!
Disconnect all the cords from the system. You will need to unplug the A/C adapter/power cord from your wii system and from the electrical socket/or power surge protecter bar. It should not be connected to any thing! Let it sit unconecteded for about ten minutes. This should reset it. Then replug the adapter/power cord back in to electical outlet and to the wii system. Then press the power button on the wii, it should turn back on. Replug the rest of the cords back in for the system. If this does not work I suggest that you buy a new ac adapter/power cord, there could be a short in the one you have before you send in your system to be fixed You can buy a new A/C adapter/power cord on ebay for about 5 to 10 dollars, usually with free shipping.
Apr 09, 2010 | Nintendo Wii Console
I just moved and can't find power cord for J6480. How much is a replacement if it "never" shows up in the moving boxes?
http://partsurfer.hp.com/Search.aspx?type=PROD&SearchText=CB029A
Under electronic parts, you have power cord option, the part number for it is 8121-1023, you can add it to cart and order it on line directly. If you are not from US you change the country settings at the top.
Any clarifications please comment.....
Sep 29, 2009 | HP OfficeJet D135 All-In-One InkJet...
LEXMARK X63 NOT RECONIZING LEFT CART.
I did find a procedure online to clear the memory and that did the
trick. Here it is, may help someone in the future:
Open lid, take both cartridges out. Physically remove the power cord from outlet or back of unit. While pressing the Stop/Clear button, plug cord back and kee pressing until a message saying "clearing memory" comes on. Reinstall ink. You're done, the message should go away.
May 03, 2009 | Lexmark X63 InkJet Printer
My xbox 360 wont turn on
It may be a problem with the cord. I recommend you get a replacement cord. If it still does not work after that, you'll have to get the system looked at. Bring it back to the retailer. Don't forget your warranty. If the warranty did expire, then you'll have to buy a new one.
Jun 08, 2008 | Microsoft Xbox 360 Console
Lexmark X5470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
