Question about HP L1906 19" LCD Monitor
Hp 1902 lcd monitor is black screen power light blinking
bammbammfran
  • 159 Answers
SOURCE: Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Posted on Oct 18, 2008
  • 644 Answers
SOURCE: do lcd monitors over heat and shut off screen
It is possible that your the lcd inverter board is failing or possibly the back light, i suggest taking the back cover off the monitor and checking the power board for leaking or slightly buldged capacitors, to spot this youll have a dark liquid traces on the cap or on the board, the top of the cap must be flat not bulged, if there are any they'll need to be replaced, you can get them from electronic stores like Maplins, and if you are able to use a soldering iron desolder the the ones of the board and solder the new ones on. Make sure you get the exact farad rating of the caps, it dosent matter to much about voltage as long as it is equal or above the voltage stated on the cap. Also insure that they are replaced the correct way around, check this before desoldering from board.
Posted on Jan 24, 2010
Testimonial: "JIM,i removed board and there was a bad cap. replaced it and i am in business. money is so tight, i would have done w/o. thank you, rick"
  • 88 Answers
SOURCE: Hp l1906 LCD MONITOR SCREEN WONT DISPLAY. power
It is possible that the video card in cpu is bad, try hooking up another monitor to the cpu (computer) if you have one that will let you know if it is the monitor or the computer video card, Could be as simple as the driver is missing.
Posted on Feb 01, 2010
  • 12 Answers
SOURCE: Monitor power light blinks, then goes out. PC screen goes black.
Unplugging the power cord repeatedly is not a good idea! I hope this helps: 1- After you get a picture, go to "Device manager" (Click on Start-Programs-settings-device manager) and make sure that there is not question or an exclamation mark next to Monitors. If that is the case you might need to reinstall the driver! 2- Make sure that your video card is not faulty by hooking up a different monitor and see if it is working ok. If you still have the same problem, then you need to replace the video card. 3- Check all cables and power cords and make sure that there's good connectivity on all ends (before powering up the machine) and that there are no nicks or cuts. If possible try replacing the monitor's data cable as well. Good luck
Posted on Apr 24, 2010
issken
  • 1472 Answers
SOURCE: 1902 MONITOR NO PICTURE BLINKING
onecatinahat
If you are having trouble with your monitor it can be several things that can be causing the problem. The common problem is something happens to the drivers on the video card and this causes it to send a signal to the monitor that is out of rage for the monitor. So you see a blank screen. Normally when the power light is flashing this is what the problem is. The question I have for you is what color the flashing light is.
I would also try connecting the monitor to another computer because if it work we know the problem is with your video card and/or drivers.
If it is your computer what you will need to do is try to connect a CRT monitor to the computer because they are not as picky with the signal as LCD monitors are. If you get display then you will want to reinstall the drivers for your video card.
Note in some cases you have to reinstall the monitor drivers. The link below will show you how to do this in Windows 7.
http://www.fixya.com/support/r4290666-install_monitor_drivers_in_windows_7
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Oct 26, 2010
My power light just blink green. screen remain black
Three possibilities: bad caps in the power supply, bad inverter circuits, or bad lamps. You need to open it up and inspect the caps first. Post back what you see so we guide you more. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 06, 2010 | HP L1906 19" LCD Monitor
When i plug in the switch "on" my HP COmpaq LCD 15" monitor can not respond. black screen and the power putton light GREEN show but not display. after 1 minute the green light off. when i soon "on" monitor...
ysm7862001, Monitor has possible problem lighting-up cold cahtode fluorescent lamps that provide lcd panel with white light from rear(reverse side) of the panel. No white light= black or blank n black screen. Read my fixya profile for all options you might have open to you.
12fixlouie
Mar 01, 2010 | HP Compaq 1501 15" LCD Monitor
Green light blinking , no display ,,
look inside for bad caps, see example of failed Viewsonic monitors here: http://s807.photobucket.com/home/budm/allalbums
You should have 5v and 12v in the power supply sections.
Jan 17, 2010 | ViewSonic : 19" Graphics Series Flatpanel...
Fran
Oct 18, 2008 | HP vs19 (Silver) 19" LCD Monitor
F1523 power light blink
resit your ram if the problem perssit then remove the video cable which is attaching to the cpu,check for any message in the monitor(monitor should be power on),if you are getting any message then your motherboards's display adapter has malfunctioned, send it for repair
May 14, 2008 | HP Pavilion F1523 15" LCD Monitor
Black screen
how can u fix this black screen? the green power light is on, shows vista for a bit then turns black and stays black. any solutions or do i have to send it back?
Apr 03, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Black screen; blinking power light
are using dvi cable did u try to hit the input botton on screen itself thx nick
Feb 07, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Hp vs15, black screen, power light goes on and off like it is in sleep mode
Monitor is dead. The LCD inverter board probably went out and needs replacing. More than likely, it will cost you over $100 to get it fixed. It's better to spend the money on a new monitor.
Jul 13, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP L1906 19" LCD Monitor Logo
106 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
