Question about LG Microwave Ovens
LG MP9287NL microwave not working ideas? just stopped working does it have an internal fuse?
MicrowaveSvc
  • 9047 Answers
SOURCE: delonghi combi microwave
It may be the internal fuse, or the thermal fuse / thermostat / thermal cutout on the magnetron. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
  • 579 Answers
SOURCE: Microwave stopped working
Magnatron is suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing the magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Posted on Jan 01, 2008
jsrock516
  • 5911 Answers
SOURCE: ARE THERE INTERNAL FUSES IN
There's usually an input line fuse on a small circuit board (part of an input line filter circuit) in most microwave ovens. This is usually a 20 amp appliance fuse that you can purchase at most major hardware stores (you would need to look at the fuse to verify the rating). You would need to remove the exterior cover to access the fuse. Its usually located near where the power cord enters the unit. Make sure you unplug the unit prior to attempting any repairs to the interior circuits. Microwave ovens are particularly dangerous as the the voltage potentials in the high voltage network are in the 3000-4000 volt range. In addition, most manufacturers provide a schematic drawing with troubleshooting advice behind the operator console, or inside the interior cabinet wall. I hope this helps you.
Posted on Aug 01, 2008
fieldy14
  • 456 Answers
SOURCE: spare parts search ProlineST44 Microwave
your after what i call in australia, is a high voltage fuse, readily availableeither online or from any electronics spares dealers.
Posted on Jul 06, 2009
  • 472 Answers
SOURCE: my LG LMVM2055 just stopped
yes there is a fuse behind the control panel area. where the cord goes inside the unit there is a fuse bloack and a 20 amp fuse ...may have lucked out and just need to replace fuse...unfortunately you have to do some disassembly to get to it ...good luck to you
Posted on Jan 09, 2011
LG LMV1813ST MIRCOWAVE STOPPED WORKING?
The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
If the microwave is not working the thermal fuse may have blown.
When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Aug 02, 2014 | LG LMV1813ST Microwave Oven
My LG over the range microwave and vent stopped working. The outlet it's plugged into is fine.
it may be an internal fuse that popped. try a lamp or something in the outlet. if that's ok, it's probably a fuse inside the microwave.
Oct 17, 2013 | LG Microwave Ovens
Way causes a kenmore model 721.80043700 to just stop working?
Microwave ovens may have an internal fuse that can open. Unfortunately, it it not easy to get at.
Sep 08, 2012 | Kenmore Microwave Ovens
Microwave is making humming noise and started to smoke and stop working
sounds like the fan inside oven seized, causing the smoke and popped the internal fuse. If you have any appliance repair shops around, they should be able to fix it for you cheaper than replacing the entire unit. Make sure you leave it unplugged, I know thats abvious but had to mention. Good Luck!
Apr 18, 2011 | LG LMV1630ST Microwave Oven
My LG LMVM2055 just stopped working. i have checked the fuse box and everything is fine. i unplugged the microwave and plugged it into a working outlet and it still does not work. is there an internal...
Jan 09, 2011 | LG LMVM2055 Convection/Microwave Oven
Dead Microwave - Internal Fuse?
After replacing the internal fuse (see other posts to see how I did it) the microwave is working fine (so far). We have used it 5 or 6 times without any issues.
Jan 23, 2010 | KitchenAid KHHS179LSS Convection /...
Ok , I replaced the fuse checked all connections and checked plug for power ! Still my lg lmv1630st will not show any power at all . What gives?
by replacing the fuse you meant the house circuit fuse or the microwaves internal fuse? and by conncetions your talking the internal wiring inside the case of the unit or wiring from the plug? if not its your 15 or 20 amp ceramic fuse inside the unit,if thats blown replace,but chk h.v.diode,v.v. cap,triac,control board, mis-adjusted interlock safety door switch,and lastly the mag could be defective
Aug 15, 2009 | LG Over-the-Range Microwave
Spare parts search ProlineST44 Microwave
Jul 06, 2009 | Sharp R-242 Microwave Oven
Microwave just stopped working
  • Internal fuse may have opened
  • Door interlock may have failed
  • Magnetron may have failed
  • Control panel may have failed
Jun 19, 2017 | Sharp R-1492 Microwave Oven
LG MS-283MCG Microwave - had a fault when we first bought it, engineer replaced an internal fuse. Stopped working again years ago in the same way, been sitting in a cupboard since then. Hardly used since...
Microwaves usually have a small ceramic fuse inside. White with metal caps about 1 inch long. You can change it yourself but please follow these rules:
  • Always make sure the unit is unplugged when doing this.
  • Replace the fure with the same type of fuse. Don't use a glass fuse if the original is ceramic.
Other than that, I hope that fixed ya...
Geno
Apr 02, 2008 | Microwave Ovens
Microwave Ovens Logo
22 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
