Question about Canon P23-DHV Calculator
Calculator Canon p23-dh v - E showing on screen, left side in the print mode and calculator won't function
SOURCE: my Canon P23-DH calculator is printing out weird symbols
I also have a Canon P23-DH 111 that is printing strange symbols. This has happened after an electrical storm.
I contacted Canon Support and they verified that the board inside has been corrupted by a power surge.
I now have a new Canon P23-DH V and I invested in a surge protector.
My grandaughter is playing with the old machine.
Posted on Apr 03, 2009
SOURCE: We can't figure out how to feed the new paper into
The calculator wouldn't take the paper but when he cut the corners off the paper to make a blunt "V", it grabbed the paper right away and pulled it through.
Posted on Nov 07, 2009
  • 5 Answers
SOURCE: how do I load paper in my canon p23 dh v printing calculater
Put paper roll on paper arm with the end of the paper coming down from behind. Cut paper on a diagonal. Insert the paper into the **** at the back of the calculator. You need to really look to see it. Use the feed button to feed the paper through..
Posted on Nov 09, 2009
  • 102366 Answers
SOURCE: I need to set the date on my Canon P23-DH V
Press and hold the ClockDate Set button for three seconds until the display shows the date with the first digit blinking. Enter a two-digit month, a two-digit date, and a four-digit year, followed by the ClockDate Set button.
Press and release the ClockDate Set button. Press and hold it for three seconds until the display shows the time with the first digit blinking. Enter a four-digit time, press AM/PM as appropriate, then press the ClockDate Set button. Press CE/C to finish and return to calculation mode.
If you can't find yours, you can download a new copy of the manual from the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Posted on Jun 16, 2010
Moe2010
  • 62 Answers
SOURCE: need to know how to insert printing tape into
Install paper roll with end coming up from rear. Insert end of paper into slot at back of calculator until it stops. Then press feed button until paper advance thru slop at top.
Posted on Jul 17, 2010
Order tape for printing
Lorena, Staples will have it in stock, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Calculator Plain Paper 2 25 150 Pack of 3 Calculator And Cash...
Canon 1904B001AA P23 DH Printing Calculator Staples
How to Load Paper Into Canon P23 DH eHow
Mar 05, 2016 | Canon P23-DHV Calculator
I will be adding up multiple things, it is printing great, and then the screen goes blank except for a small "e" appears in the lower left hand corner and I have to start all over. WHY?
our calculator is beyond repair. You can use it in no print mode ohly. The printer is not working, causing the error code.
Turn it off and back on and only use the display mode.
Oct 22, 2015 | Canon P23-DH III 12 Digit Printing...
Common Issues with Canon P23-DH Calculator i have a e
The same thing happened to me. Wouldn't feed paper and the printer function didn't work. The E was in the lower left of the screen. I tried the reset button on the back, but that didn't help.
I took the ink cartridge out and reseated it and that fixed the problem. It was installed incorrectly direct from the factory as my calculator was new out of the box.
Feb 17, 2012 | Canon P23-DH Calculator
E on screen of canon p23-dh v
SOLUTION: I was just having this problem with mines but I was able to fix it. The I don't much about any memory overload or anything (I only do simple add and subtract computations). First I removed the cover and removed the paper from the feed (its a pain I know to reload but you want you're calculater fixed right?). Next I removed the ink roller (it's marked 'PULL UP'). Then after some tinkering, nudged the numerical stamp to the left 2-3 times which immediately started the feed right up. My explanation is that the printer had gotten jammed/off track causing the FEED to stop working. You'll know it definitely if you hear a low quick hum each time you switch to the print function which is probably the little motor saying 'hey, umm I would print if I was connected to a printer!'. Happy Calculating!
Feb 13, 2012 | Canon P23-DHV Calculator
Need to know how to insert printing tape into Canon P23-DH color printing calculator?
Jul 17, 2010 | Canon P23-DH Calculator
I need the instructions for a canon P23-DH V calculator
Apr 16, 2010 | Canon P23-DH Calculator
Forgot how to load paper
Hello.
From FixYa Support:
While looking at the front of the P23-DH printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then, cut the paper on the roll straight across. Then, feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed through and you are ready to go.
Hopes this helps.
Mar 14, 2010 | Canon P23-DH Calculator
My Canon P23-DH calculator is printing out weird symbols
Mar 09, 2009 | Canon P23-DH Calculator
Canon p23-hd v
download the user manual (P23-DH III) from here:
http://rapidshare.com/files/181603396/P23DHIII.PDF.html
Dec 04, 2008 | Canon P23-DH Calculator
Canon P23-DHV Calculator Logo
old marine
old marine
