Question about Dell Inspiron 1501 Notebook
A white line across my screen
I brought my monitor at a computer show in nyc and a white line across the screen appeared days after using the monitor. It hasn't dropped or anything and this line is starting to get on my nerves. I have the reciept and everything I just don't know where to go from there and i'm wishing I just brought my monitor in a regular store. I have a one inch wide white line from the top of my screen to the bottom, you can see through it sort of
  • margsievert Jan 07, 2009
    thanks for trying, my laptop is a Dell Inspiron 5160 which was not listed on your dropdown.
  • 748 Answers
A chip died in the LCD screen. Definitly take it back or contact the manufacturer for a warranty replacement.
Posted on Jan 05, 2009
AOC monitor black screen how do I fix it?
I have a couple AOC i2353ph monitors. One day, one of them booted up with a single vertical white line moving slowly back and forth across the screen that kind of looked like a scan or radar. Once I reset the monitor from the OSD it went way. Use "Extra > Reset" from the monitor menu.
Oct 22, 2013 | AOC 917Sw 19" LCD Monitor
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
AOC vertical white line moving across the screen
I have dual AOC i2553ph monitors. One day I came into work and notice one of them had a single vertical white line moving slowly back and forth across the screen that looked like a scan or radar function. I reset the monitor from the OSD and all is well again. Use "Extra > reset" from the OSD on AOC monitors.
Jan 31, 2012 | AOC Computers & Internet
(external monitor AOC LM765 flickers white lines) My laptop screen is damaged. I plugged an external monitor (AOC LM765 via RGB), works fine for the past three days but suddenly ghostly lines appear. Any...
Hook up that monitor to another laptop or computer. If it works then its an issue with the vga port on your laptop. If the monitor still shows those lines then you know for sure the monitor is bad and it will have to be replaced.
May 15, 2011 | AOC LM765 (Silver) 17" LCD Monitor
Screen Works With One Computer But Not This Mine
Soundes likw interference do you have electrical high lines near that area.
Feb 13, 2009 | Gateway FPD1765 17" Flat Panel LCD Monitor
It could be one of three things, the first two could be an easy fix, the last one calls for a qualified repair person and could cost you
-first, The lcd cable assembly is loose, make sure it's seated properly. if problem still exists try to Disconnect the monitor cable from the computer and turn the monitor on leave it plugged in to the electric socket.it will display a diagnostic colorbar are the lines still there. if not your problem might be a cable or video card. if they are still there have a technician evaluate the monitor.
-second, The inverter card may need to be reseated
-last, The lcd has a thin line crack and needs to get replaced
It would be helpful to know about the inner workings of an lcd screen and how to access them. It shouldn't be to difficult if your computer savvy. I want to caution you about getting shocked. an lcd still has power stored in capacitors. you should be able to drain those capacitors by leaving the monitor on and unplugging it from the electrical plug wait 10 sec or until all lights go out on the monitor.
If none of this works then Your monitor is defective, and nothing you can do to fix it... Call where you got it from for a replacement
Jul 11, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
Thin line across computer screen
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Mar 08, 2008 | Gateway FPD1975W 19" LCD Monitor
I got the same problem, I'm going to return it to the store today...
Nov 27, 2007 | ASUS VW192S Monitor
White screen with thin black line
it is the problem with the lcd itself just call the customer care they will be replace it.
Sep 05, 2007 | Samsung 710V 17" LCD Monitor
Dell Inspiron 1501 Notebook Logo
483 people viewed this question
Alun Cox
