Question about Dell Inspiron 1720 Notebook
Dell laptop lid latch problem
It appears the lid latch spring has came off or broke as the latch now moves freely. I need instructions to replace the spring. Thanks in advance!!!
  • christi2shl Jan 05, 2009
    Thank
    Thank you very much. This is exactly the information I was seeking.
  • 748 Answers
The spring and latch are available from Dell but this is a very hard repair. I do this for a living and screen repair is always a challenge. If you want to tackle it then call Dell first to get the parts. Once the parts have arrived put the laptop on a non static mat (placemats work well). Take out the battery and do not connect the AC power. If you're lucky on your screen there should be four rubber bumpers. Peal these off and there should be a screw behind each one. Now the bezel has to be unlocked from the back. You'll need a couple of plastic pry devices. I like to use plastic bike tire irons. Once the bezel is off you'll see the catch and where the sping goes. Make sure you find that old spring, you don't want it ending up in the electronics. Now just reverse everything to put it back together. You'll need to put a little rubber cement to put on those bumpers. If you're machine doesn't have the screws you'll have to use those plastic tire irons to pry apart the screen. Be careful and don't force it.
Posted on Jan 05, 2009
How do I open the lid of laptop to use for the first time?
It generally slides to the right, spring loaded, and you have to pull up on the lid after sliding it to the right. It opens easy so don't force it.
Sometimes there is no latch. You just lift the lid while holding down the base.
Sep 03, 2014 | Dell Computers & Internet
Lid doesn't open
you could always try a butter knife or something along those lines to move the switch over
Jul 18, 2012 | Fujitsu Siemens Computers & Internet
The latch on the laptop broke How do i open it?
you need to mimic what the latch did most latches are like arrows in this case get two thin items ( blunt butter knifes) and move the latches both left or right if its a middle type latch then try pushing in were the broken latch was .get what i mean if the old latch pushed in then its a middle latch if it slide then is double arrow latch ounce the laptop is open if you dont want to spend $$ fixing the lach just cut of the locking arrows to stop it locking again
good luck
email me if need further assistance
Jun 25, 2010 | HP Pavilion dv1000 Notebook
Acer aspire does not open
Do you mean that the lid doesn't open or that your operating system doesn't open? If it's the lid, then the latches attached to the slider are jammed up. You can force them back with a small flat-head screw driver or a butter knife, or some other thin object that you can slide in there. Be careful not to scratch your LCD with whatever it is that you choose to use to open the lid. Once you get it open, move the slider back and forth to see if the latch hooks are moving with it. If they are then there is something going on with your lid that is preventing them from moving back after it's be closed. Sometimes this is due to the lid being slightly bent so that it causes the latches to lock in tightly and then not move back to unlatch when moving the slider. If you were meaning that your operating system won't open then you may need your system reinstalled. MADHATTER COMPUTERS
Mar 22, 2010 | Computers & Internet
UNABLE TO FIND THE RELASE TO OPEN LID ON NEW TOSHIBA TECRA A10-S3551. HOW DO I OPEN LID?
By looking at this model on Toshiba's website there does not appear to be any latch to open the laptop. It should just pull open. Most laptops are now using lids that are held closed by magnets or very stiff hinges or in some cases, spring type hinges.
Dec 24, 2009 | Toshiba Tecra A10-S3511 Notebook
Top of my new laptop won't open Help
If you have the Acer 5570 model, there are two latches on the lid.....one on either side and I believe they both have to be moved together to open the lid. Move the slides to the right and the lid should open. If they don't and if perhaps a latch has broken from the release, try taking a credit card and swiping left to right you might be able to unlatch the catch.
Dec 02, 2009 | Acer Aspire 5500 5570-2609 Laptop
Keyboard on my Dell studio 15 is locked
Use your touchpad or mouse to save all open documents and close all programs. Shut down the computer. Be sure to click "Turn Off" instead of "Restart."
Unplug your Dell Inspiron 2600 and close the lid.
Carefully turn the laptop over. Remove the battery. The battery has a sliding latch and lock. Unlock the battery by sliding the lock to the unlock position. Slide the latch and remove the battery when the left edge pops up.
Wait one minute and replace the battery. Slide the lock back into the locked position.
Connect your adapter and restart your system.
Sep 13, 2009 | Dell Computers & Internet
CAN'T REMOVE THE BATTERY
You need to disconnect the laptop battery from the computer and also the ac adapter so there is no power.
Then you will need to unscrew the generally 2 screws on the memory cover to get to the ram. I will have to get a service manual for your unit and confirm how its done.
Jan 19, 2009 | Compaq Presario M2000 Notebook
Dell Inspiron 1720 Notebook Logo
822 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
