Question about Samsung Computers & Internet
Samsung syncmaster SA23550H not switching to analog
The display will not show anything, except that it is set to HDMI as the source. The OSD noes not display and the source button does not function. I have a Macbook Pro running the latest version of Mountain Lion. I connect the monitor via an analog PC cable attached to an analog/DVI adapter. This setup has been running perfectly for nearly 18 months until last week. I have tried the Samsung troubleshooting steps by switching cables and resetting the monitor to its native resolution. Is there a way to force the monitor to switch to analog mode?
MicrowaveSvc
  • 9047 Answers
SOURCE: No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Posted on Jan 12, 2007
Riziel
  • 116 Answers
SOURCE: Samsung Syncmaster 245BW, can't get it up and running !
Most of the time when this happens it is due to a bad monitor, if you have another pc try to hook this monitor up to that one to see if it actually works, these monitors sometimes get damaged during shipment!
Posted on Nov 26, 2007
  • 300 Answers
SOURCE: "No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Posted on Sep 14, 2008
CreativeTECH
  • 1719 Answers
SOURCE: samsung syncmaster 2033sw monitor, till
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Posted on Nov 15, 2010
termistor
  • 82 Answers
SOURCE: My Samsung 940t stopped working,
I'm thinking of would be a problem with your PC not booting, try to connect to a computer monitor to know that it works
Posted on Apr 04, 2011
Do i need a converter box for a samsung syncmaster 940 mw
It depends. What are you using the monitor for? If you want to watch digital TV, you need a digital to analog converter. (It has an NTSC tuner.) Note: the digital to analog converters that were subsidized by the US government coupon only gave SD out.
If you are connecting to a PC, it has DVI-D (21 pin SCART) and VGA connections (15 pin SCART). (An HDMI to DVI cable or adapter would connect to HDMI video cards.) Most other set-top boxes will connect to the component, composite or S-video connectors.
I hope this helps.
Jan 07, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung syncmaster 2033sw monitor, till now i was using a vga cable for the display, but recently i bought a dvi cable and connected it. but its not detecting the display of dvi cable. if i remove the vga...
Hope this helps!
CreativeTECH
Nov 15, 2010 | Samsung Syncmaster 2033SW Monitor
No display on a brand new Samsung EX2020 monitor.
mcdevito75 here Refer to the instalation instructions that came with your new PC and monitor, Also you cantry to hit the auto switch on the monitor or check with the menu on the monitor, press menu and see instructions / options.
Jul 03, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Problem is i cant adjust colour and size because of showing "LOCK
This is how:
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
User manual:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=2233BW&prd_ia_sub_class_cd=P
Apr 23, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
No 1440X900 Resolution Option in Display Settings
Windoze is not detecting the monitor correctly. Right click the desktop as you had before to get to the display settings. Click the "advanced" button at the lower right, on the next window, click the "Monitor" tab, and remove the check from the box from "Hide modes that this monitor cannot display". That should add to the settings the 1400 X 900 resolution you are looking for.
Jan 24, 2009 | Computers & Internet
Monitor width distorted
Components in the deflection circuit CHECK those.
Jul 08, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung 931B SyncmMaster
DO YOU MEAN WONT SWITCH FROM ANALOG TO DIGITAL!!!
THE ONLY WAY THIS WILL CHANGE IS IF YOU HAVE A DIGITAL INPUT SOURCE CONNECTED to this mointor like HDMI AS THIS MOINTOR AUTOMATICALLY SENSES ANALOG SIGNALS AND DIGITAL INPUT SIGNALS if a digital signal is available it will switch over if a digital input singal is not available you will only be able to use the analog option
Jan 11, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Computers & Internet Logo
55 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
